Tag Archive for: corner radius
Harvey Tool Chamfer Cutters
What is a Drop-Hole?
graphic showing holes with and without drop hole allowance
5 unique machining operations with drop hole allowance
When Not to Drop Hole
machining operations without drop hole allowance
Drop-Hole Placement
proper placement of hole when using drop hole allowance
graphic showing the use of a drop hole for o-ring seals between high and low pressure areas
  • Traditional Roughing
  • Slotting
  • Finishing
  • Contouring
  • Plunging
  • High Efficiency Milling
Material:
Application:
graphic showcasing the tool face of end mills from 2 to 12 flutes
Length of Cut & Reach
Tool Profile
end mill graphic with dimension callouts
  • Prolonged Tool life
  • Improved Chip Evacuation
multiple end mills after being coated, zoomed in on cutting faces
face of a staggered tooth keyseat cutter
Three Key Benefits
Indexing
Increased Feed Rates
Better Part Finish
staggered tooth keyseat cutter working in a cnc machine
Opt for a Smoother Operation
The Importance of Tolerances
close up of a shaped of slot from a corner radius end mill and its tolerances
stacking tolerances
standard deviation
tolerance stacking
standard deviation
root sum
Click Here to Learn More
Use Worst Case Analysis:
For the left corner radius
.125” – .001” = .124”
For the flat section
.250” – .002” = .248”
For the right corner radius
.124” + .248” + .124” = .496”
.125” + .001” = .126”
.250” + .002” = .252”
.126” + .252” + .126” = .504”
Corner Rounding End Mill with dimension callouts
2 flute and 4 flute corner rounding end mills with 5° flares
Front or Back
harvey tool back Corner Rounding End Mill
These tools are often offered in 2, 3, and 4 flute styles.  2 flute styles are normally used for aluminum and non-ferrous materials, although 3 flutes is quickly becoming a more popular choice for these materials, as they are softer than steels so a larger chip can be taken without an impact on tool life. 4 flutes should be chosen when machining steels to extend tool life by spreading out the wear over multiple teeth. 4 flute versions can also be run at higher feeds compared to 2 or 3 flute tools.
infographic showing x, y and z axii
The Anatomy of an End Mill
Flutes
end mill flute patterns showing valley size
End Mill Profiles
Square Profile End Mills
Ball Profile End Mills
end mill with arrows showcasing cutter diameter and tool face
Shank Diameter
end mill neck comparison and strength with standard and reduced neck
End Mill Helix Angle
showcase of end mill helix angle compared to core
Pitch
infographic of variable pitch end mill face
