ball nose
ball nose
ball nose
ball nose
KEY
ADOC = Axial Depth of Cut
D = Cutting Diameter
R = Tool Radius (Dia./2)
RDOC = Radial Depth of Cut
SFM = Surface Feet per Minute
Sc = Compensated Speed
ball nose
ball nose
ball nose
ball nose
KEY
Quick Definitions:
depth of cut
roughing depth of cut
slotting depth of cut
Traditional Strategy
  • Heavy RDOC
  • Light ADOC
  • Conservative Feed Rate
  • Light RDOC
  • Heavy ADOC
  • Increased Feed Rate
depth of cut
