Tag Archive for: Cutter Stability
Harvey Tool Chamfer Cutters
How to Select a Spindle
properly selecting a spindle
harvey tool slitting saw
  2. Undercutting Applications
  3. Slotting into Material
What is a Tight Tolerance?
tolerances
How Are Tolerances Used?
tooling tolerance
Spotting Drills
spotting drills
Reamers
miniature reamers
Be Wary of Deflection
Tolerances Summarized
Deflection Can Result In:
  • Subpar surface finish
Tool Deflection Remedies
Minimize Overhang
extended reach tool
Image Source: @NuevaPrecision
Long Flute vs. Long Reach
tool deflection
tool deflection graph
long reach end mill
Long Reach Tool: Variable Helix End Mills for Exotic Alloys – Ball – Long Reach, Stub Flute
long flute tool
core diameter vs neck diameter
Deflection Summarized
Choosing the Right Pecking Cycle Approach
What are Pecking Cycles?
High Performance Drills – Flat Bottom
aluminum pecking cycles
hardened steels chart
prehardened steels chart
tool wear Shop Inefficient
Subpar Part Finish
Inefficient Coolant Usage
chamfer mills
Using Traditional Roughing
high efficiency milling
tool holding
variable helix
end mill coatings
Using a Long Length of Cut
flute count for tool life
Shut Up Tool Chatter With Harvey Tool’s Material Specific Tooling
helical reduced neck tool
Ensure a Secure Connection
