Helix Angles Rule of Thumb
Slow Helix Tool <40°
Benefits
Enhanced Strength – A larger core creates a strong tool that can resist deflection, or the force that will bend a tool under pressure.
Reduced Lifting – A slow helix will decrease a part from lifting off of the worktable in settings that are less secure.
Larger Chip Evacuation – The slow helix allows the tool to create a large chip, great for hogging out material.
Drawbacks
Rough Finish – A slow helix end mill takes a large chip, but can sometimes struggle to evacuate the chip. This inefficiency can result in a sub-par part finish.
Slower Feed Rate – The increased radial force of a slow helix end mill requires running the end mill at a slower feed rate.
High Helix Tool >40°
Benefits
Lower Radial Force – The tool will run quieter and smoother due to better shearing action, and allow for less deflection and more stability in thin wall applications.
Efficient Chip Evacuation – As the helix angle increases, the length of cutting edge engagement will decrease, and the axial force will increase. This lifts chips out and away, resulting in efficient chip evacuation.
Improved Part Finish – With lower radial forces, high helix tools are able to cut through material much more easily with a better shearing action, leaving an improved surface finish.
Drawbacks
Weaker Cutting Teeth – With a higher helix, the teeth of a tool will be thinner, and therefore thinner.
Deflection Risk – The smaller teeth of the high helix tool will increase the risk of deflection, or the force that will bend a tool under pressure. This limits how fast you can push high helix tools.
Increased Risk of Tool Failure – If deflection isn’t properly managed, this can result in a poor finish quality and tool failure.
https://www.harveyperformance.com/wp-content/uploads/2020/02/Helix-Angles-Featured.png4351155Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2020-02-05 16:07:562021-03-01 11:30:57Benefits & Drawbacks of High and Low Helix Angles
With the recent addition of the Micro 100 brand to the Harvey Performance Company family, we want to know how you have been utilizing its expansive tooling offering. Has Micro 100’s Micro-Quik™ system helped you save time and money? Do you have a favorite tool that gets the job done for you every time? Has Micro 100 tooling saved you from a jam? We want to know! Send us a video on Instagram and show us what you #MadeWithMicro100!
How to Participate
Official Contest Rules
Contest Dates:
The contest will run between December 5, 2019 to January 17, 2020. Submit as many entries as you’d like! Entries that are submitted before or after the contest period will not be considered for the top prizes (But we’d still like to see them!)
The Important Stuff:
Take a video of your Micro 100 tool in action, clear and visible.
Share your video on social media using #MadeWithMicro100 and tagging @Micro_100.
Detail the story behind the project (tool number(s), operation, running parameters, etc.)
Prizes
The top five entries will be sent Micro 100’s Micro-Quik™ tool change system with a few of our quick change tools. The top three entries will be offered a spot as a “Featured Customer” on our “In The Loupe” blog!
The Fine Print:
Please ensure that you have permission from both your employer and customer to post a video.
All entries must be the original work of the person identified in the entry.
No purchase necessary to enter or win. A purchase will not increase your chances of winning.
On January 28, 2020, the top 5 winners will be announced to the public. The Top 5 selected winners will receive a prize. The odds of being selected depend on the number of entries received. If a potential winner cannot be contacted within five (5) days after the date of first attempt, an alternative winner may be selected.
The potential winners will be notified via social media. Each potential winner must complete a release form granting Micro 100 full permission to publish the winner’s submitted video. If a potential winner cannot be contacted, or fails to submit the release form, the potential winner forfeits prize. Potential winners must continue to comply with all terms and conditions of these official contest rules, and winning is contingent upon fulfilling all requirements.
Participation in the contest constitutes entrants’ full and unconditional agreement to and acceptance of these official rules and decisions. Winning a prize is contingent upon being compliant with these official rules and fulfilling all other requirements.
The Micro 100 Video Contest is open to residents in US and Canada who are at least 18 years old at the time of entry.
https://www.harveyperformance.com/wp-content/uploads/2019/12/MadeWithMicro100-Featured.jpg6001599Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2019-12-05 13:13:002021-03-09 11:47:56Show Us What You #MadeWithMicro100
https://www.harveyperformance.com/wp-content/uploads/2019/11/Selecting-the-Right-Chamfer-Cutter-Tip.jpg6001599Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2019-11-22 08:20:372021-03-10 16:12:58Selecting the Right Chamfer Cutter Tip Geometry
Boring is a turning operation that allows a machinist to make a pre-existing hole bigger through multiple iterations of internal boring. It has a number of advantages over traditional drilling methods:
The ability to cost-effectively produce a hole outside standard drill sizes
The opportunity to create multiple dimensions within the bore itself
Solid carbide boring bars, such as those offered by Micro 100, have a few standard dimensions that give the tool basic functionality in removing material from an internal bore. These include:
Geometries
Defining the Geometric Features of Boring Bars:
Separating Two Pieces of Material
If an application calls for cutting a piece of material, such as a rod, in half, then a slitting saw will work well to cut the pieces apart while increasing efficiency.
Undercutting Applications
Saws can perform undercutting applications if mounted correctly, which can eliminate the need to remount the workpiece completely.
Slotting into Material
Capable of creating thin slots with a significant depth of cut, Slitting Saws can be just the right tool for the job!
https://www.instagram.com/p/BvwSC5IpqPV/
While it may look similar to a stainless steel circular saw blade from a hardware store, this tool should neverbe used with construction tools such as a table or circular saw. Brittle saw blades will shatter when used on manual machines, and can cause injury when not used on the proper set up.
https://www.harveyperformance.com/wp-content/uploads/2020/08/Slitting-Saw-Featured.jpg6001599Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2019-09-10 09:30:532021-03-10 16:16:29The Geometries and Purposes of a Slitting Saw
Downloading Tool Libraries
Selecting a Tool
Searching by Tool Number
Searching by Keyword
Searching by Tool Type
Searching by Tool Dimensions
Using Specialty Profile Tools
Tool Name
Fusion 360 Name
Back Chamfer Cutter
Dovetail Mill
Chamfer Cutters
Chamfer Mill
Corner Rounding End Mill – Unflared
Radius Mill
Dovetail Cutter
Dovetail Mill
Drill/End Mill
Spot Drill
Engraving Cutter/Marking Cutter – Tip Radius
Tapered Mill
Engraving Cutter – Tipped Off & Pointed
Chamfer Mill
Keyseat Cutter
Slot Mill
Runner Cutter
Tapered Mill
Undercutting End Mill
Lollipop Mill
All Other Specialty Profiles
Form Mill
Speeds and Feeds
If you have further questions about speeds and feeds, please reach out to our Technical Support team. They can be reached Monday-Friday from 8 AM to 7 PM EST at 800-645-5609, or by email at [email protected].
To access speeds and feeds information for your Helical Solutions end mills, we recommend using our Machining Advisor Pro application. Machining Advisor Pro (MAP) generates specialized machining parameters by pairing the unique geometries of your Helical Solutions end mill with your exact tool path, material, and machine setup. MAP is available free of charge as a web-based desktop app, or as a downloadable application on the App Store for iOS and Google Play.
To learn more about Machining Advisor Pro and get started today, visit www.machiningadvisorpro.com. If you have any questions about MAP, please reach out to us at [email protected].
If you have further questions about speeds and feeds, please reach out to our Technical Support team. They can be reached Monday-Friday from 8 AM to 7 PM EST at 866-543-5422, or by email at [email protected].
For additional questions or help using tool libraries, please send an email to [email protected]. If you would like to request a Harvey Performance Company tool library be added to your CAM package, please fill out the form here and let us know! We will be sure to notify you when your CAM package has available tool libraries.
Three Key Benefits
Indexing
Increased Feed Rates
Better Part Finish
Opt for a Smoother Operation
https://www.harveyperformance.com/wp-content/uploads/2019/09/featureimg_StaggerToothKeyseat.jpg6001599Jeff Rauseohttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngJeff Rauseo2018-09-19 10:35:552021-01-14 14:17:45Experience the Benefits of Staggered Tooth Keyseats
https://www.harveyperformance.com/wp-content/uploads/2018/09/machiningadvisorpro.jpg6001599Jeff Rauseohttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngJeff Rauseo2018-09-13 14:20:202021-02-25 11:53:48Get to Know Machining Advisor Pro
Delamination of composite layers
Uncut Fibers
Fiber tear-out
Uneven tool wear
Poor surface finish due to “competing” materials
These problems are all caused by unique conditions created by composite materials, and can be very tricky to correct. The simple fact of cutting a combination of multiple materials at the same time introduces many factors that make it difficult to strike the right balance of the proper tool for the job and appropriate running parameters. The following tool styles provide solutions for a wide array of composite concerns. Composite Drilling Applications can face the same issues, and proper drill choice can help as well.
Straight Flute End Mill
Compression Cutters
Chipbreaker Cutter
Diamond Cut End Mill
Composite Finisher
Coating or No Coating?
Composite materials, especially those with glass or carbon fiber, can be particularly abrasive and have a tendency to wear down the cutting edge of carbide tools. If one is looking to achieve the best tool life and maintain a sharp cutting edge, then choosing an Amorphous Diamond coated tool is the best option. This thin coating improves lubricity and wear resistance over its uncoated counterpart. Using a tool with CVD diamond coating can be very beneficial in extreme cases, when fiber fill percentage is very large. This is a true diamond coating, and offers the best abrasion resistance, but a slightly less sharp cutting edge as it is a thicker coating. PCD diamond tooling offers the best tool life. If it a solid diamond wafer brazed to a carbide shank, and can maintain the sharpest edge of any diamond tooling. However, PCD is limited to straight flutes, and can come at a higher price.
https://www.harveyperformance.com/wp-content/uploads/2018/05/Composite-Featured-Image-1.jpg6001599Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2018-05-21 15:10:122021-01-11 17:08:34Ideal Tooling for Machining Composites
What is a Tolerance?
A tolerance is an allowable amount of variation in a part or cutting tool that a dimension can fall within. When creating a part print, tolerances of tooling can’t be overlooked, as tooling tolerances can result in part variations. Part tolerances have to be the same, if not larger, than tool tolerances to ensure part accuracy.
Cutting tool tolerances are oftentimes applied to a tool’s most critical dimensions, such as Cutter Diameter, Length of Cut, Shank Diameter, and Overall Length. When selecting a cutting tool for a job, it’s critical to choose a brand that adheres to strict tolerance standards and reliable batch-to-batch consistency. Manufacturers like Harvey Tool and Helical Solutions prominently display tolerances for many critical tool dimensions and thoroughly inspect each tool to ensure that it meets the tolerances specified. Below is the table header for Harvey Tool’s line of Miniature End Mills – Square – Stub & Standard.
How are Tolerances Used?
Spotting Drills
Reamers
Be Wary of Deflection
Maintaining tolerances when machining walls is made difficult by deflection, or the curvature a tool experiences when a force is applied to it. Where an angle is appearing on a wall due to deflection, opt for a reached tool to allow for less deflection along the tool’s neck. Further, take more axial depths of cut and machine in steps with finishing passes to exert less pressure on the tool. For surface finish tolerances, a long fluted tool may be required to minimize evidence of a tool path left on a part. For more information on ways to minimize deflection, read Tool Deflection & Its Remedies.
Tolerances Summarized
https://www.harveyperformance.com/wp-content/uploads/2018/05/Tight-Tolerances-Featured-1.jpg6001599Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2018-05-15 09:22:382021-03-10 16:33:06Tips for Maintaining Tight Tolerances
