1. Keyseat Cutter Geometry
Selecting and utilizing the right tool is often more complicated than identifying the right diameter and dialing in the speeds and feeds. A keyseat cutter’s strength should be considered carefully, especially in tricky applications and difficult materials.
As with any tool, a longer reach will make a keyseat cutter more prone to deflection and breakage. A tool with the shortest allowable reach should be used to ensure the strongest tool possible.
A keyseat cutter’s neck diameter greatly affects its performance. A thinner neck allows for a comparatively larger radial depth of cut (RDOC) and more clearance, but makes for a weaker tool. A thicker neck reduces the keyseat cutter’s RDOC, but greatly strengthens the tool overall. When clearances allow, a keyseat cutter with a thicker neck and larger cutter diameter should be chosen over one with a thinner neck and smaller cutter diameter (Figure 1).
keyseat cutter geometry
2. Radial Depth of Cut
Understanding a keyseat cutter’s RDOC is critical to choosing the correct tool, but understanding how it affects your tool path is necessary for optimal results. While it may be tempting to make a cut using a keyseat cutter’s maximum RDOC, this will result in increased stress on the tool, a worse finish, and potential catastrophic tool failure. It is almost always better to use a lighter depth of cut and make multiple passes (Figure 2).
keyseat cutter RDOC
3. Desired Slot Size
ideal keyseat slot
4. Staggered Tooth Geometry
Having trouble finding the perfect keyseat cutter for your job? Harvey Tool offers over 1,800 keyseat cutter options, with cutter diameters from 1/16” to 1-1/2” and cutter widths from .010” to ½”.
2. Ensure a Secure Connection
tool chatter
decrease tool chatter
Helical Part No. 33737
Material 4340 Steel
ADOC 2.545″
RDOC .125″
Speed 2,800 RPM
Feed 78 IPM
How to Avoid Composite Delamination with Compression Cutters
Using Compression Cutters in Composite Materials
delamination
compression cutters
Built-In CAM Applications
HEM Case Studies
Importance of Tooling to HEM
Best Tools for HEM:
High Speed Machining Vs. HEM
Introduction to High Efficiency Milling I How to Combat Chip Thinning I Diving into Depth of Cut I How to Avoid 4 Major Types of Tool Wear I Intro to Trochoidal Milling
With multiple techniques being described with somewhat similar terms, there is some confusion as to what each is referring to. High Efficiency Milling (HEM) and High Speed Machining (HSM) are two commonly used terms and techniques that can often be confused with one another. Both describe techniques that lead to increased material removal rates and boosted productivity.  However, the similarities largely stop there.
High speed machining is often used as an umbrella term for all high productivity machining methods including HEM. However, HEM and HSM are unique, separate machining styles. HSM encompasses a technique that results in higher production rates while using a much different approach to depth of cut and speeds and feeds. While certain HEM parameters are constantly changing, HSM uses constant values for the key parameters. A very high spindle speed paired with much lighter axial depths of cut results in a much higher allowable feed rate. This is also often referred to as feed milling. Depths of cut involve a very low axial and high radial components. The method in general is often thought of as z-axis slice machining, where the tool will step down a fixed amount, machine all it can, then step down the next fixed amount and continue the cycle.
Check out the video below to see HEM in action!
Titanium Varieties
Titanium 6AL4V
Titanium Concerns
Workholding
Heat Generation
cutting tools for titanium
Galling and Built-Up Edge
Titanium Solutions
machining titanium
Pre-Drilled Hole
tool entry predrill
Helical Interpolation
helical interpolation
Ramping-In
ramping
Hard/Ferrous Materials: 1°-3°
Straight Plunge
tool entry
Straight Tool Entry
tool entry
Roll-In Tool Entry
tool entry
How To Avoid 4 Major Types of Tool Wear
Defining Tool Wear
tool wear
tool wear
Abrasive Wear
tool wear
Chipping
tool wear
Thermal Cracking
tool wear
Fracture
tool wear
Corner Engagement
corner engagement
corner engagement
corner engagement
