2. Ensure a Secure Connection
tool chatter
decrease tool chatter
Work Hardening and When It Should Scare You
Work Hardening Overview
titanium
Major Problems
work hardening
How To Avoid Work Hardening
Helical Part No. 33737
Material 4340 Steel
ADOC 2.545″
RDOC .125″
Speed 2,800 RPM
Feed 78 IPM
Speeds and Feeds 101
speeds and feeds formula
speeds and feeds
Speeds and Feeds In Practice
speeds and feeds
Spindle Speed Cap
Effective Cutter Diameter
Non-linear Path
non-linear path
adjusted internal feed
adjusted external feed
How to Avoid Composite Delamination with Compression Cutters
Using Compression Cutters in Composite Materials
delamination
compression cutters
Built-In CAM Applications
HEM Case Studies
Importance of Tooling to HEM
Best Tools for HEM:
High Speed Machining Vs. HEM
Introduction to High Efficiency Milling I How to Combat Chip Thinning I Diving into Depth of Cut I How to Avoid 4 Major Types of Tool Wear I Intro to Trochoidal Milling
With multiple techniques being described with somewhat similar terms, there is some confusion as to what each is referring to. High Efficiency Milling (HEM) and High Speed Machining (HSM) are two commonly used terms and techniques that can often be confused with one another. Both describe techniques that lead to increased material removal rates and boosted productivity.  However, the similarities largely stop there.
High speed machining is often used as an umbrella term for all high productivity machining methods including HEM. However, HEM and HSM are unique, separate machining styles. HSM encompasses a technique that results in higher production rates while using a much different approach to depth of cut and speeds and feeds. While certain HEM parameters are constantly changing, HSM uses constant values for the key parameters. A very high spindle speed paired with much lighter axial depths of cut results in a much higher allowable feed rate. This is also often referred to as feed milling. Depths of cut involve a very low axial and high radial components. The method in general is often thought of as z-axis slice machining, where the tool will step down a fixed amount, machine all it can, then step down the next fixed amount and continue the cycle.
Check out the video below to see HEM in action!
Titanium Varieties
Titanium 6AL4V
Titanium Concerns
Workholding
Heat Generation
cutting tools for titanium
Galling and Built-Up Edge
Titanium Solutions
machining titanium
Pre-Drilled Hole
tool entry predrill
Helical Interpolation
helical interpolation
Ramping-In
ramping
Hard/Ferrous Materials: 1°-3°
Straight Plunge
tool entry
Straight Tool Entry
tool entry
Roll-In Tool Entry
tool entry
Corner Engagement
corner engagement
corner engagement
corner engagement
