Tool Deflection & its Remedies
Deflection Can Result In:
- Shortened tool life and/or tool breakage
- Subpar surface finish
- Part dimensional inaccuracies
Tool Deflection Remedies
Minimize Overhang
Image Source: @NuevaPrecision
Long Flute vs. Long Reach
Deflection Summarized
