1. Running It Too Fast or Too Slow
Determining the right speeds and feeds for your tool and operation can be a complicated process, but understanding the ideal speed (RPM) is necessary before you start running your machine. Running a tool too fast can cause suboptimal chip size or even catastrophic tool failure. Conversely, a low RPM can result in deflection, bad finish, or simply decreased metal removal rates. If you are unsure what the ideal RPM for your job is, contact the tool manufacturer.
2. Feeding It Too Little or Too Much
3. Using Traditional Roughing
high efficiency milling
4. Using Improper Tool Holding
tool holding
5. Not Using Variable Helix/Pitch Geometry
variable helix
6. Choosing the Wrong Coating
end mill coatings
7. Using a Long Length of Cut
optimal length of cut
8. Choosing the Wrong Flute Count
flute count
Calculating MRR
Optimizing Efficiency
The Anatomy of an End Mill
Flutes
end mill flutes
Profile
Square Profile
Corner Radius
Ball Profile
cutter diameter
Shank Diameter
end mill neck
Helix Angle
helix angle
Pitch
variable pitch
1. Keyseat Cutter Geometry
Selecting and utilizing the right tool is often more complicated than identifying the right diameter and dialing in the speeds and feeds. A keyseat cutter’s strength should be considered carefully, especially in tricky applications and difficult materials.
As with any tool, a longer reach will make a keyseat cutter more prone to deflection and breakage. A tool with the shortest allowable reach should be used to ensure the strongest tool possible.
A keyseat cutter’s neck diameter greatly affects its performance. A thinner neck allows for a comparatively larger radial depth of cut (RDOC) and more clearance, but makes for a weaker tool. A thicker neck reduces the keyseat cutter’s RDOC, but greatly strengthens the tool overall. When clearances allow, a keyseat cutter with a thicker neck and larger cutter diameter should be chosen over one with a thinner neck and smaller cutter diameter (Figure 1).
keyseat cutter geometry
2. Radial Depth of Cut
Understanding a keyseat cutter’s RDOC is critical to choosing the correct tool, but understanding how it affects your tool path is necessary for optimal results. While it may be tempting to make a cut using a keyseat cutter’s maximum RDOC, this will result in increased stress on the tool, a worse finish, and potential catastrophic tool failure. It is almost always better to use a lighter depth of cut and make multiple passes (Figure 2).
keyseat cutter RDOC
3. Desired Slot Size
ideal keyseat slot
4. Staggered Tooth Geometry
Having trouble finding the perfect keyseat cutter for your job? Harvey Tool offers over 1,800 keyseat cutter options, with cutter diameters from 1/16” to 1-1/2” and cutter widths from .010” to ½”.
2. Ensure a Secure Connection
tool chatter
decrease tool chatter
Work Hardening and When It Should Scare You
Work Hardening Overview
titanium
Major Problems
work hardening
How To Avoid Work Hardening
Helical Part No. 33737
Material 4340 Steel
ADOC 2.545″
RDOC .125″
Speed 2,800 RPM
Feed 78 IPM
Speeds and Feeds 101
speeds and feeds formula
speeds and feeds
Speeds and Feeds In Practice
speeds and feeds
Spindle Speed Cap
Effective Cutter Diameter
Non-linear Path
non-linear path
adjusted internal feed
adjusted external feed
Why Flute Count Matters
Tool Geometry Basics
flute count core
Material Considerations
flute count
flute count
