Tag Archive for: Cutting Tools
March 24, 2017/0 Comments/in CNC Machining, CNC Programming, How-To's, Machining Techniques, Milling, Troubleshooting Tips/by Harvey Performance Company
Three Harvey tool extended reach tool holders in 3, 5, and 6 inch lengths
Avoid Tool Deflection
Infographic showing result of tool deflection and excess overhang on a part's finish
Infographic showing progressive step drilling procedures and depths of cut with varied length of tools
Achieve Optimal Finish
Inforgraphic showing Deep Cavity Milling and witness marks from multiple step downs
Mill to the Required Depth
Confidently Machine Deeper With Harvey Tool’s Extended Reach Tool Holders
Evacuate Chips Effectively
that must be avoided.
Deep Cavity Milling image showing result of failed chip evacuation when milling
https://www.harveyperformance.com/wp-content/uploads/2017/03/Featured-Image-Deep-Cavity-Milling-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-03-24 19:08:432023-09-21 13:36:43How to Tackle Deep Cavity Milling the Right Way
How to Combat Chip Thinning
March 13, 2017/2 Comments/in CNC Machining, CNC Programming, High Efficiency Milling, How-To's, Machining Techniques, Quick Tips/by Tom Pyle
Defining Chip Thinning
Chip Thinning is a phenomenon that occurs with varying Radial Depths Of Cut (RDOC), and relates to chip thickness and feed per tooth. While these two values are often mistaken as the same, they are separate variables that have a direct impact on each other.
cnc machining setup covered in chips
Radial Depth of Cut
Radial Depth of Cut denotes the distance that a tool advances into a workpiece, also known as Stepover, Cut Width, or XY.
Feed Per Tooth
Feed per tooth translates directly to your tool feed rate, and is commonly referred to as Inches Per Tooth (IPT) or chip load.
Chip Thickness
How Chip Thinning Occurs
comparison of radial chip thinning and feed per tooth
IPT chip thinning formula
radial chip thinning adjustment profiles
Lasting Benefits
High efficiency milling guidebook download
https://www.harveyperformance.com/wp-content/uploads/2017/03/Feature-Image-Chip-Thinning-IMG-1.jpg 525 1400 Tom Pyle http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Tom Pyle2017-03-13 18:49:392024-02-27 10:32:43How to Combat Chip Thinning
Page 10 of 10«‹8910
