The design and short length of cut of these tools work in tandem with the end geometry to produce a tool with a strong core, further limiting deflection and allowing for tools with greater reach lengths.
https://www.harveyperformance.com/wp-content/uploads/2020/02/High-Feed-Mills-Featured-1.jpg4351155Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2020-02-13 15:25:162021-03-05 13:44:335 Things to Know About Helical’s High Feed End Mills
Separating Two Pieces of Material
If an application calls for cutting a piece of material, such as a rod, in half, then a slitting saw will work well to cut the pieces apart while increasing efficiency.
Undercutting Applications
Saws can perform undercutting applications if mounted correctly, which can eliminate the need to remount the workpiece completely.
Slotting into Material
Capable of creating thin slots with a significant depth of cut, Slitting Saws can be just the right tool for the job!
https://www.instagram.com/p/BvwSC5IpqPV/
While it may look similar to a stainless steel circular saw blade from a hardware store, this tool should neverbe used with construction tools such as a table or circular saw. Brittle saw blades will shatter when used on manual machines, and can cause injury when not used on the proper set up.
https://www.harveyperformance.com/wp-content/uploads/2020/08/Slitting-Saw-Featured.jpg6001599Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2019-09-10 09:30:532021-03-10 16:16:29The Geometries and Purposes of a Slitting Saw
Chip Thinning Awareness
Consider Climb Milling
https://www.harveyperformance.com/wp-content/uploads/2019/10/FeaturedIMG-HeatGeneration.jpg6001599Jeff Rauseohttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngJeff Rauseo2018-10-25 11:26:402021-02-25 11:39:48Effective Ways to Reduce Heat Generation
Question 1: What Material am I Cutting?
Traditional Roughing
Contouring
Plunging
Material:
Application:
The cutter diameter is the dimension that will define the width of a slot, formed by the cutting edges of the tool as it rotates. Selecting a cutter diameter that is the wrong size – either too large or small – can lead to the job not being completed successfully or a final part not being to specifications. For example, smaller cutter diameters offer more clearance within tight pockets, while larger tools provide increased rigidity in high volume jobs.
Length of Cut & Reach
Tool Profile
The most common profile styles for end mills are square, corner radius, and ball. The square profile on an end mill has flutes with sharp corners that are squared off at 90°. A corner radius profile replaces the fragile sharp corner with a radius, adding strength and helping to prevent chipping while prolonging tool life. Finally, a ball profile features flutes with no flat bottom, and is rounded off at the end creating a “ball nose” at the tip of the tool. This is the strongest end mill style. A fully rounded cutting edge has no corner, removing the mostly likely failure point from the tool, contrary to a sharp edge on a square profile end mill. An end mill profile is often chosen by part requirements, such as square corners within a pocket, requiring a square end mill. When possible, opt for a tool with the largest corner radius allowable by your part requirements. We recommend a corner radii whenever your application allows for it. If square corners are absolutely required, consider roughing with a corner radius tool and finishing with the square profile tool.
Question 5: Should I use a Coated Tool?
More Aggressive Running Parameters
Prolonged Tool life
Improved Chip Evacuation
https://www.harveyperformance.com/wp-content/uploads/2018/10/5Questions_Selecting_End_Mills_Featured_Image.jpg6001599Jeff Rauseohttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngJeff Rauseo2018-10-16 09:00:242021-03-10 16:22:205 Questions to Ask Before Selecting an End Mill
Recent Advances
1. Increased Time Savings
2. Reduced Cycle Times
3. Improved Consistency
As a tool rotates and its cutting edge impacts a workpiece, material is sheared off from a part, creating chips. When that cutting process is interrupted, as is the case with breaks in the cutting portion of the tool, chips become smaller in length and are thus easier to evacuate. Because the chipbreakers are offset flute-to-flute, a proper, flat surface finish is achieved as each flute cleans up any excess material left behind from previously passed flutes.
https://www.harveyperformance.com/wp-content/uploads/2017/10/chipbreaker_featured-1.jpg6001599Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2017-10-24 16:52:132021-03-01 16:25:33Optimize Roughing With Chipbreaker Tooling
What is Ramping?
Benefits of Ramping
https://www.harveyperformance.com/wp-content/uploads/2017/05/ramping-to-success-featuredimage.jpg6001600Jeff Rauseohttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngJeff Rauseo2017-05-10 09:00:392021-02-26 08:57:31Ramping to Success
https://www.harveyperformance.com/wp-content/uploads/2017/04/part-finish-featured-image.jpg6001600Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2017-04-25 12:30:242021-02-11 10:44:56How to Avoid Common Part Finish Problems
Avoid Tool Deflection
Achieve Optimal Finish
Although increasing your step-downs and decreasing your ADOC are ideal for roughing in deep cavities, this process oftentimes leaves witness marks at each step down. In order to achieve a quality finish, Long Reach, Long Flute Finishing End Mills (coupled with a light Radial Depth of Cut) are required (Figure 3).
Mill to the Required Depth
Fortunately, your tool holder’s effective reach can be easily increased with Harvey Tool’s Extended Reach Tool Holder, which allows you to reach up to 6 inches deeper.
Evacuate Chips Effectively
that must be avoided.
https://www.harveyperformance.com/wp-content/uploads/2017/04/harvey-deep-cavity-milling.jpg3751000Jeff Rauseohttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngJeff Rauseo2017-03-24 19:08:432021-03-05 14:32:02How to Tackle Deep Cavity Milling the Right Way
