The design and short length of cut of these tools work in tandem with the end geometry to produce a tool with a strong core, further limiting deflection and allowing for tools with greater reach lengths.
harvey tool slitting saw
  2. Undercutting Applications
  3. Slotting into Material
https://www.instagram.com/p/BvwSC5IpqPV/
heat generation in HEM
Chip Thinning Awareness
Consider Climb Milling
heat generation
https://www.instagram.com/p/BhHWF5eh1o9/?hl=en&taken-by=helicaltools
axes for high balance machining
high balance end mills
Utilizing Tap Testers
What Tap Testers Do
How Tap Testing Works
High balance
Recent  Advances
1. Increased Time Savings
2. Reduced Cycle Times
3. Improved Consistency
CNC Contouring planes
CNC Contouring ball end mill
https://www.instagram.com/p/BVu7uHwByR5/?taken-by=helicaltools
metal chips in cnc mill form chipbreaking
Helical Part No. 33737
Material 4340 Steel
ADOC 2.545″
RDOC .125″
Speed 2,800 RPM
Feed 78 IPM
tapered end mills
tapered end mills
Tapered Reach
following pros and cons:
• Increased tool strength
• Reduced tool deflection
• Less chatter, better finish
• Increased productivity
• Reduced clearance
tapered end mills
Tapered Length of Cut
tapered end mills
