Tag Archive for: Diamond Coated End Mill
July 15, 2025/0 Comments/in Large Featured, Milling, Specialty Tools, Tool Selection/by Harvey Performance Company
Mold, Tool, and Die manufacturing demands a high level of precision. Whether you’re machining hardened tool steels, creating detailed mold cavities, or producing dies with complex geometries, the tooling used plays a critical role in ensuring consistent, repeatable results. To explore the full selection of tools relevant to this industry, including application-specific geometries and coatings, visit Harvey Tool’s Mold, Tool & Die Featured Solutions page.
Harvey Tool offers a comprehensive range of tools specifically engineered to meet the unique challenges of the Mold, Tool & Die industry. From tools designed to reach deep cavities to those that maintain surface finish in demanding materials, this offering is built to support precision and reliability throughout the machining process.
Tools included in this lineup are:
  • CVD Diamond End Mills– This Harvey Tool lineup of Diamond Tooling for Non-Ferrous Materials features true crystalline CVD diamond on a solid carbide substrate, making it ideal for machining graphite, composites, green carbide, and green ceramics.
  • End Mills for Hardened Steels– Engineered for hardened steels from 46Rc to 68Rc, this tool includes the latest generation AlTiN Nano coating for enhanced hardness and thermal resistance.
  • End Mills for Aluminum Alloys– We know a part is only as successful as its finish. That’s why our aluminum finishing solutions are crafted for mirror-like surface quality.
  • End Mills for Medium Alloy Steels– Engineered for versatility, these CNC-ground, AlTiN-coated tools excel in machining stainless, tool, and medium alloy steels.
  • Miniature Tapered End Mills– Tackling deep part features? Harvey Tool’s tapered Miniature End Mills offer unique geometries that take the challenge out of tough-to-reach cuts.
Diamond End Mills for Abrasive and Non-Ferrous Materials
Diamond tooling is essential to many moldmaking processes, particularly during electrode production and when machining non-metallic materials. Harvey Tool’s offering includes a wide selection of Diamond End Mills designed for use in abrasive and non-ferrous materials such as graphite, green carbide, green ceramics, and composites—materials commonly encountered in mold and die work.
These tools feature a CVD (Chemical Vapor Deposition) coating to promote longer tool life and uphold tight tolerances over extended machining cycles.
Highlighted tooling includes:
  • Finishers – Ball Profile (CVD Diamond)
    With available radii as small as 0.005″, these tools are ideal for finishing high-detail electrodes and intricate features.
  • Finishers – Corner Radius (CVD Diamond)
    Designed for applications requiring edge strength and tight tolerances, available with corner radii from 0.005″ to 0.0625″.
  • Standard Ball and Square Profiles (CVD Diamond)
    Feature reduced neck geometries for improved clearance in deep cavity or long-reach work.
Diamond End Mills are frequently used in electrode machining for EDM (Electrical Discharge Machining), where precision in non-metallic workpieces directly influences final mold quality.
All tools in the Mold, Tool & Die offering are fully stocked and available to ship same day, helping to reduce lead times and keep your production on schedule.
To view the full offering, including tools with specialized geometries and coatings, visit the Mold, Tool & Die Solutions page.
https://www.harveyperformance.com/wp-content/uploads/2025/07/Mold-Tool-Die-Featued-Image.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2025-07-15 08:02:462025-11-10 10:42:08Supporting Precision in Mold, Tool & Die Applications
Grappling With Graphite: A Machining Guide
April 1, 2020/1 Comment/in Material Specific, Milling, Tech Tips/by Harvey Performance Company
Despite being a softer material, graphite is actually one of the most difficult materials to machine. There are many considerations machinists need to make in terms of tooling, coolant use, and personal safety when it comes to machining these parts. This “In The Loupe” post will examine the material properties, key machining techniques to consider, and tips for properly selecting cutting tools to achieve success in this tricky material.
graphite machining efficiency speeds and feeds chart
What is Graphite?
While graphite is an allotrope of carbon, the two terms are not simply interchangeable. Carbon is an element that can form into several different allotropes including graphite, diamond, and fullerite. Graphite happens to be the most stable form of carbon, and is the most common, as carbon naturally occurs as graphite under standard conditions.
Graphite is most recognized for its superior conductivity and resistance to high heat and corrosion. This makes it a common material in high heat, high-pressure situations in the aerospace, electrode, nuclear, energy, and military industries.
zoomed in image of graphite cnc material
Even though graphite can handle intense high-pressure situations with ease, it is actually a very soft, abrasive, and brittle material. This can cause serious challenges when machining, as graphite can eat up cutting tools, and severely minimize a tool’s usable life. However, with the proper tooling and techniques, there are ways to optimize graphite machining to be more cost-effective than the competition.
Graphite Machining Techniques
Since graphite is such a soft and brittle material, special consideration needs to be made when machining to avoid chipping it. To get a good cut, it is recommended that you take light chip loads and use lower feed rates in graphite. If you were to take a heavy cut at a fast feed rate, you would start chipping the graphite and could cause it to fracture completely. To give a comparison point, chip loads for graphite are similar to those for Aluminum materials, but with less than half the feed rate.
To give you an idea of speeds and feeds for graphite, here is an example using a 1/4″ Harvey Tool CVD Diamond Coated, 4 flute Square End Mill. If that tool was running at a standard RPM of 12,000 at 780 SFM, the recommended chip load would be .00292 for a feed rate of 140 IPM.
electrode machining
In terms of machine setup, the one major tip to remember is to always avoid using coolant. Graphite is a fairly porous material, and so it can absorb coolant and act as a “coolant sponge,” which will cause problems with finished parts. Inside the machine and on the tooling, the coolant can actually react with the graphite dust and create an abrasive slurry, which will cause problems while machining. A vacuum system is recommended for clearing material while machining graphite. Otherwise, coated tools should be able to run dry.
Another thing to note when machining graphite is that because graphite does not produce chips, but rather a cloud of very abrasive dust, it can be harmful to operators and machines without proper care. Operators should be wearing a protective mask to avoid inhaling the graphite dust. Proper ventilation and maintaining air quality in the shop is also key for the protection of machinists when working in graphite.
Since the graphite dust is also extremely conductive, it can easily damage non-protective circuits inside your CNC machine, which can cause major electrical issues. While coolant is not recommended, a vacuum system can help to remove the dust, keeping it from accumulating too much inside the machine and preventing serious problems.
Increase Your Graphite Machining Efficiency – Tap Into Harvey Tool’s Speeds and Feeds Charts Today
Cutting Tools for Graphite Machining
As previously mentioned, graphite is a notorious cutting tool-killer due to its extremely abrasive nature. Even the highest quality carbide end mills, if left uncoated, will wear quickly on most jobs. This extreme wear may force a tool change during an operation, which could lead to an imperfection in the part when trying to restart the operation where the worn tool left off.
graphite cutting tools
When selecting a cutting tool for graphite machining, the coating and cutting edge is the most important consideration. Flute count, helix angles, and other key features of the tool geometry ultimately come second to the coating when purchasing tooling.
For graphite machining, a CVD (Chemical Vapor Deposition) diamond coating is recommended whenever possible to maximize tool life and tool performance. These coatings are grown directly into the carbide end mill, improving the hardness and leaving the tool with a coating layer that is 5 times thicker than a PVD Diamond Coating. While not the sharpest edge, the CVD diamond coating provides much longer tool life than other diamond coatings due to the thicker diamond layer.
cvd diamond layer coating drawing to portray increased wear resistance
Even though initial tooling costs may be higher with CVD coated tools versus uncoated tools, since CVD coated tools see considerably longer tool life than uncoated tools, this makes the cost per part shrink significantly. In difficult, abrasive materials like graphite, the uncoated carbide tool will last a short time before the abrasiveness of the graphite completely wears down the cutting edge. Having a CVD coated tool will give you a leg up over the competition, keep your machine running with less downtime for tool changes, and ultimately deliver substantial cost savings.
cvd diamond coated harvey tool end mill for graphite
CVD Diamond Coated End Mill from Harvey Tool
Overall, graphite can be a difficult material to machine, but with the right cutting tools and proper speeds and feeds you will be making quality parts in no time. Harvey Tool offers a wide selection of CVD coated end mills in various diameters, reaches, and lengths of cut to ensure you have what you need for any job that comes your way.
https://www.harveyperformance.com/wp-content/uploads/2020/04/Grappling-With-Graphite.jpg 435 1155 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2020-04-01 10:58:432023-10-05 09:00:52Grappling With Graphite: A Machining Guide
Machining Precious Metals
July 1, 2019/10 Comments/in How-To's, Machining Techniques, Material Specific/by Robert Keever
About the Elements
  1. Ruthenium (Ru)
  2. Rhodium (Rh)
  3. Palladium (Pd)
  4. Silver (Ag)
  5. Osmium (Os)
  6. Iridium (Ir)
  7. Platinum (Pt)
  8. Gold (Au)
periodic table with a box around the 8 precious metals
material properties of precious metals in relation to 6061 and 4140
thermal conductivity of silver, gold, copper, and aluminum
pgm material properties
Tools for Precious Metals
variable helix square aluminum end mill from harvey tool
harvey tool pcd diamond square end mill
Speeds and Feeds charts:
speeds and feeds chart for precious metals
speeds and feeds chart for precious metals with a pcd end mill
https://www.harveyperformance.com/wp-content/uploads/2020/07/Machining-Precious-Metals.jpg 600 1599 Robert Keever http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Robert Keever2019-07-01 12:58:512023-10-24 10:50:51Machining Precious Metals
February 1, 2019/0 Comments/in CNC Machining, Harvey Tool, Machining 101, Material Specific, Tool Geometry, Tool Information Guides, Tool Selection/by Harvey Performance Company
  • Increased tool life.
single flute end mill for pastics
While many manufacturers will specially coat a standard end mill at your request, this takes added time and cost. In its Material Specific catalog sections, Harvey Tool offers coated tools stocked and ready to ship. For instance, their Hardened Steels and Exotic Alloys categories utilize AlTiN Nano coating. This is a unique nanocomposite coating that has a max working temperature of 2,100° F and shows improved performance in materials such as Hardened Steels, Titanium Alloys, and Inconel, among others.
Miniature End Mill
Part Number: 836408
Material: 6061 Aluminum
Application: Slotting
Speed: 10,000 RPM
Chip Load: .00124 IPT
Linear Feed: 37.2 IPM
DOC: .04375
harvey tool miniature end mill
Part Number: 942308
Speed: 10,000 RPM
Chip Load: .00165 IPT
Linear Feed: 49.5 IPM
DOC: .0625
harvey tool miniature variable helix end mill
Extensive Cost Savings
material specific tooling benefit chart in cost savings
https://www.harveyperformance.com/wp-content/uploads/2019/02/Feature-Image-Material-Specific-Tooling-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2019-02-01 08:43:172024-11-07 16:17:45How Material Specific Tooling Pays Off
University of Michigan Formula SAE Racing Team
July 9, 2018/0 Comments/in Featured Customer/by Harvey Performance Company
Featured Image Courtesy of University of Michigan Formula SAE Racing Team
Formula SAE is a student design competition that began in 1980. The competition was founded by the SAE (Society of Automotive Engineers) branch at the University of Texas. Each year, hundreds of universities across the world spend months designing and manufacturing their best Formula style car before putting them to the test in competitions.
Alex Marshalek is the Team Captain of the University of Michigan’s Formula SAE team, MRacing. The team was originally founded in 1986, and has been very successful over the years. In the 2017 season, they finished 5th at the Formula SAE Michigan event, and took home a 1st place finish at Formula North. They are hoping to continue riding that momentum into another successful season in 2018.
Mracing
Photo Courtesy of: University of Michigan Formula SAE Racing Team
Alex reached out to Harvey Tool and Helical earlier this year, and after some conversation, the decision was made to sponsor their team’s efforts by supplying cutting tools and providing technical support. With competitions on the horizon and a new build coming over the summer, Alex was kind enough to find some time to talk with us about his experiences as a student learning the ropes in engineering, manufacturing, and design, the importance of quality tooling and maintaining a superior part finish for competition, and challenges he has faced during this process.
Hi Alex. Thanks for taking the time to talk with us today. When you were looking into college degree programs, what initially interested you in manufacturing and engineering?
I have always had an interest in Aerospace Engineering, but it was nothing more than a personal interest until I started college. My high school unfortunately did not have any machine shop or manufacturing type classes, so a lot of what I knew, I learned from my dad. My dad worked as a Mechanical Engineer at an axle manufacturing company, and he used to always be doing things around the house and showing me the basics of engineering and design.
When it came time to choose a school, I knew that Michigan had an impressive Aerospace Engineering department, and I liked the feel of the campus and community better than other schools I had toured.
How did you first get involved with the Formula SAE team?
I knew going into school that I wanted to get involved in a design team and advance my learning in that way. We have about a dozen different design teams at Michigan, but the Formula SAE team really stood out to me as a really cool project to get involved in.
I started with the team in Fall of 2016, helping out with the design and manufacturing of the vehicle’s suspension. Now, for the upcoming 2018 season, I am taking over the role of Team Captain. There will be a little bit less hands-on design and manufacturing work for me as it is more of an administrative/outreach role.
michigan racing
How does a typical FSAE season run?
So FSAE seasons are constantly running, and nearly overlapping with each other. For example, we are currently finishing up competitions from the 2018 season, but at the same time we are beginning the design of the vehicle for the 2019 season. Typically, the design work is done over the summer, and finalized in October. After that, the major manufacturing begins and lasts until about March, with spare parts and additions being added as we go. Testing begins in March, where we fine tune the vehicle and optimize the design for performance. Then, the rest of the Spring and early Summer is competition time, and the process starts all over again!
What sort of machines do you have in the shop?
Right now, we have three manual Bridgeport mills, two retro-fit CNC Bridgeport mills, 2 manual lathes, 1 retro-fit CNC lathe, and a Haas VF-2SS and Haas SL-20. For the vast majority of what we are machining, we are using the Haas. We do most of our work in Aluminum, with some parts made out of steel or titanium, and the Haas has been great for everything.
We are also using AutoDesk’s Fusion 360 software for our CAD/CAM, and we love it.
What has been the most difficult part of the build?
Time is really the biggest challenge. We are all full-time students, so time is already hard to find, but we also don’t have an overabundance of machinists so the operators can get overburdened. It all works out in the end and our machinists are great, but time management is truly the biggest challenge.
michigan formula sae
The composite materials we work with are also very challenging to machine. We constructed the vehicle’s monocoque (the structural “skin”, often seen in Formula One cars) out of carbon fiber. While we cut a lot of it on the water jet machine, we needed more precise holes than a water jet could offer, so we went to the Haas for that. We were using HSS drills and only getting 10-12 holes at a time before they wore out. However, we had Don Grandt (Harvey Performance Company Application Engineer) stop in the shop and he sent us a few Harvey Tool diamond coated drills, which should make this a much faster and more precise process!
You mentioned Don stopped in to give you guys a visit. What were some of your biggest takeaways?
Don was great. He stopped by and we gave him a tour of the facility and showed off some of the parts we were designing. We talked shop for quite a bit, and he gave us a bunch of great tips and tricks we could use to really optimize our machining. As I mentioned, he also went through the catalogs with us and helped us find exactly what we need for tooling. The Harvey Tool diamond coated drills are going to be a life saver for carbon fiber. I guess the biggest takeaway was just all of the knowledge we received from Don and how helpful that was to have someone direct from the tooling manufacturer sharing everything we knew with us.
Now that you have the Harvey and Helical tools in the shop, how have they helped you complete this project and get a leg up on your competition?
One of the most impressive things for us have been the finishing end mills we received. The Helical finishers for Aluminum are giving us some of the best finishes we have ever seen. For us, that is a point of pride. We not only want to have the fastest and most well-designed vehicle, but we also want to have the best looking parts. Subpar finishes reflect poorly on the entire build, and first impressions mean a lot in these competitions.
We have also been blown away by the Chipbreaker roughers. We absolutely love those tools and push them to the limits with great results. In fact, the first time we ran them, we used Machining Advisor Pro to dial in our speeds and feeds, and the numbers seemed insane to us. We were nervous, but we pushed the button and let it run. It was amazing to see that we could push a tool that fast without tool failure.
How has your experience been using Machining Advisor Pro?
We use Machining Advisor Pro every time we picked up the Helical end mills. MAP was actually one of the main reasons we were looking for Helical to sponsor us. We had heard a lot about MAP and your level of technical support, which was important to us as we are learning more about manufacturing and machining. Machining Advisor Pro has quickly become one of our best learning tools in the shop.
The nice thing about MAP is that is takes a look at all of the parameters. A lot of applications only give you numbers on your speeds and feeds, but MAP takes a look at the depth of cut, chip thinning, engagement angle, and all of the other parameters that are so essential to a successful run. As a result, we have been able to get very aggressive with the end mills. We are not a huge production shop, so cycle times are not as important, but we still want to get the most out of our tools in the least amount of possible time.
So, let’s break down some specs. What are you all working with on this year’s build?
Right now our car features a 4 cylinder Honda 600 CBR engine, with a Turbo and 600cc displacement. We are one of the few teams that run a turbo in competition. As we mentioned, the monocoque is completely carbon fiber, and the car features a full aero package with an undertray. The max speed is around 80 MPH, and the car weighs 420 pounds without the driver.
Once the build is complete, how does a typical competition work?
Most of the Formula SAE competitions are multi-day events, with a few static events, and then dynamic events where the car is running. For static events, we first have a Design portion. We validate and argue for our design in front of judges who are engineers in the industry. Then, we get into a Cost presentation, as one of the goals is to build the cheapest possible car with a high level of performance. That balance of cost vs. performance is a critical part of the build. The last static event is a Business presentation, where we introduce a business/manufacturing plan on how to get this design to a production level of 100 units in a year.
For the dynamic events, we have 4 different tests. First, we have the Accel Run, which is a 75 meter sprint, and the fastest cars win. From there we go to the Skip Pad event, which is centered on turning radius and the stiffness of the chassis as we do tight figure eight turns with the car.
Then we have the AutoCross, a one lap race, which determines our placement in the final event; Endurance. For the Endurance event, we drive the cars around a 22km track, and the goal is to finish the race without any mechanical or design failures in the quickest time possible. Only around 50% of participants actually complete this event. If a single part falls off, or breaks, you are disqualified. Many times we see things like the suspension, powertrain, or wings falling off. It is disappointing when it happens, but it allows us to easily identify any flaws and fix them for the next event.
What is next for you after school? Any future plans or goals?
I am currently majoring in Aerospace Engineering, and would like to stay within that industry. I am leaning towards working on aircraft. Designing either aircraft structures or the aerodynamics would be very cool. I really like the size and scale of working on commercial aircraft, but I could see myself doing something more specialty like working in Defense as well.
Alex and his team had a very successful 2018 season. They recently placed 9th overall in a competition at the Michigan International Speedway. In the dynamic events, they placed 4th in Skidpad, and 7th in Autocross. The high placement in the Autocross event allowed them to race head to head against top teams in the world, and they ended up placing 4th in Endurance out of 104 cars!
The MRacing team also competed at Formula North, a competition in Ontario, Canada, where they achieved a top ranking of 2nd place overall. They passed all of the technical inspections on the first try and placed 1st in Acceleration, 2nd in Skidpad and Endurance, 3rd in Autocross, and 4th in Efficiency.
michigan Formula SAE
https://www.harveyperformance.com/wp-content/uploads/2018/07/Featured-Image-Michigan-SAE-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-07-09 15:30:532025-11-20 09:51:35University of Michigan Formula SAE Racing Team
May 21, 2018/0 Comments/in CNC Machining, Composites, Material Specific, Tool Selection/by Harvey Performance Company
Composite Materials
  2. Uncut Fibers
  3. Fiber tear-out
  4. Uneven tool wear
Straight Flute End Mill
straight flute end mill
Compression Cutters
compression cutter end mill
Chipbreaker Cutter
Diamond Cut End Mill
Composite Finisher
Coating or No Coating?
https://www.harveyperformance.com/wp-content/uploads/2018/05/Feature-Image-Machining-Composites-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-05-21 15:10:122025-09-08 11:13:01Ideal Tooling for Machining Composites
