Machining Precious Metals
About the Elements
  1. Ruthenium (Ru)
  2. Rhodium (Rh)
  3. Palladium (Pd)
  4. Silver (Ag)
  5. Osmium (Os)
  6. Iridium (Ir)
  7. Platinum (Pt)
  8. Gold (Au)
machining metals
precious metals
machining metals
machining metals
Tools for Precious Metals
machining metals
machining metals
Speeds and Feeds charts:
machining metals
machining metals
Understanding the Two Styles
Chipbreaker End Mills
Knuckle Roughers
The Importance of Tolerances
stacking tolerances
stacking tolerances
standard deviation
tolerance stacking
standard deviation
root sum
Click Here to Learn More
Use Worst Case Analysis:
For the left corner radius
.125” – .001” = .124”
For the flat section
.250” – .002” = .248”
For the right corner radius
.124” + .248” + .124” = .496”
.125” + .001” = .126”
.250” + .002” = .252”
.126” + .252” + .126” = .504”
diamond tool coatings
Amorphous Diamond Coating
amorphous diamond coating
CVD Diamond Coating
Polycrystalline Diamond (PCD)
Coating Hardness & Thickness
Flute Styles
PCD Diamond end mill
PCD Ball End Mill
CVD Diamond end mill
CVD Ball End Mill
Proper Uses
Cut to the Point
Drill/End Mills
drill mills
drill mill operations
Undercutting End Mills
undercutting end mills
Double Angle Shank Cutters
double angle shank cutters
Flat Bottom Tools
flat bottom tools
flat bottom tools
Adjustable Chamfer Cutters
adjustable chamfer cutters
chamfer cutter inserts
High Precision Tools
hand deburring
cnc deburring
cnc deburring
tool wear Shop Inefficient
Subpar Part Finish
Inefficient Coolant Usage
chamfer mills
