Boring is a turning operation that allows a machinist to make a pre-existing hole bigger through multiple iterations of internal boring. It has a number of advantages over traditional drilling methods:
  • A greater finish quality
Geometries
Defining the Geometric Features of Boring Bars:
Breaking and damaging an end mill is oftentimes an avoidable mistake that can be extremely costly for a machine shop. To save time, money, and your end mill it is important to learn some simple tips and tricks to extend your tool’s life.
tool life
tool life
tool life
tool life
Composite Materials
  2. Uncut Fibers
  3. Fiber tear-out
  4. Uneven tool wear
Straight Flute End Mill
straight flute end mill
Compression Cutters
compression cutter end mill
Chipbreaker Cutter
Diamond Cut End Mill
Composite Finisher
Coating or No Coating?
Coolant
Tool Engagement
climb milling
Initial Workpiece Engagement
Gummy Materials Summarized
10 Reasons to Use Flat Bottom Tools
Flat bottom tools, or tools with flat bottom geometry, are useful in a variety of a situations and operations that tools with typical cutting geometry are not. The standard characteristics of drills or end mills are useful for their primary functions, but make them unsuitable for certain purposes. When used correctly, the following flat bottom tools can make the difference between botched jobs and perfect parts.
Flat Bottom Drills
Flat Bottom Drill
Flat Bottom Drill Operations
Thin Plate Drilling
Crosshole Drilling
Angled Drilling
Half Hole Drilling
Flat Bottom Counterbore Operations
Bore & Finish Drilled Holes
Straighten Misaligned Holes
Remove Drill Points
Remove End Mill Dish
