A Corner Rounding End Mill is typically used to add a specific radius to a workpiece, or in a finishing operation to remove a sharp edge or burr. Prior to selecting your Corner Rounding End Mill, mull the following considerations over. Choosing the right tool will result in a strong tool with a long usable life, and the desired dimensional qualities on your part. Choosing wrong could result in part inaccuracies and a subpar experience.
Selecting the Right Pilot Diameter
Flared or Unflared
Front or Back
Choosing between a Corner Rounding End Mill and a Back Corner Rounding End Mill boils down to the location on the part you’re machining. A Back Corner Rounding End Mill should be utilized to put a radius on an area of the part facing the opposite direction as the spindle. While the material could be rotated, and a front Corner Rounding End Mill used, this adds to unnecessary time spent and increased cycle times. When using a Back Corner Rounding End Mill, ensure that you have proper clearance for the head diameter, and that the right reach length is used. If there is not enough clearance, the workpiece will need to be adjusted.
Corner Rounding End Mills are often offered in 2, 3, and 4 flute styles.  2 flute Corner Rounding End Mills are normally used for aluminum and non-ferrous materials, although 3 flutes is quickly becoming a more popular choice for these materials, as they are softer than steels so a larger chip can be taken without an impact on tool life. 4 flutes should be chosen when machining steels to extend tool life by spreading out the wear over multiple teeth. 4 flute Corner Rounding End Mills can also be run at higher feeds compared to 2 or 3 flute tools.
The best corner rounding end mill varies from job-to-job. Generally speaking, opting for a tool with the largest pilot diameter possible is your best bet, as it has the most strength and requires less power due to its larger effective cutter diameter. A flared Corner Rounding End Mill is preferred for blending purposes if the workpiece is allowed to have an incomplete radius as this allows more forgiveness and can save on set up time. If not, however, an unflared Corner Rounding End Mill should be utilized. As is often the case, choosing between number of flutes boils down to user preference, largely. Softer materials usually require fewer flutes. As material gets harder, the number of flutes on your tool should increase.
Composite Materials
  2. Uncut Fibers
  3. Fiber tear-out
  4. Uneven tool wear
Straight Flute End Mill
straight flute end mill
Compression Cutters
compression cutter end mill
Chipbreaker Cutter
Diamond Cut End Mill
Composite Finisher
Coating or No Coating?
Coolant
Tool Engagement
climb milling
Initial Workpiece Engagement
Gummy Materials Summarized
What is a Tolerance?
tolerances
How are Tolerances Used?
tooling tolerance
Spotting Drills
spotting drills
Reamers
miniature reamers
Be Wary of Deflection
Tolerances Summarized
diamond tool coatings
Amorphous Diamond Coating
amorphous diamond coating
CVD Diamond Coating
Polycrystalline Diamond (PCD)
Coating Hardness & Thickness
Flute Styles
PCD Diamond end mill
PCD Ball End Mill
CVD Diamond end mill
CVD Ball End Mill
Proper Uses
Cut to the Point
Deflection Can Result In:
  • Subpar surface finish
Tool Deflection Remedies
Minimize Overhang
extended reach tool
Image Source: @NuevaPrecision
Long Flute vs. Long Reach
tool deflection
tool deflection
Deflection Summarized
Attacking Aluminum: A Machining Guide
Tool Geometry
flute count for aluminum
Helix Angles
Aluminum Machining
Tooling Options
Chipbreaker Tooling
Chipbreaker Aluminum
High Balance End Mills
Among Harvey Tool’s expansive holemaking solutions product offering are several different types of miniature tooling options and their complements. Options range from Miniature Spotting Drills to Miniature High Performance Drills – Deep Hole – Coolant Through. But which tools are appropriate for the hole you aim to leave in your part? Which tool might your current carousel be missing, leaving efficiency and performance behind? Understanding how to properly fill your tool repertoire for your desired holemaking result is the first step toward achieving success.
Choosing The Right Pecking Cycle Approach
Utilizing a proper pecking cycle strategy when drilling is important to both the life of your tool and its performance in your part. Recommended pecking cycles vary depending on the drill being used, the material you’re machining, and your desired final product.
What are Pecking Cycles?
Rather than drill to full drill depth in one single plunge, pecking cycles involve several passes – a little at a time. Pecking aids the chip evacuation process, helps support tool accuracy while minimizing walking, prevents chip packing and breakage, and results in a better all around final part.
pecking cycles
aluminum pecking cycles
hardened steels pecking cycles
prehardened steels pecking cycles
From the above tables, it’s easy to identify how recommended pecking cycles change based on the properties of the material being machined. Unsurprisingly, the harder the material is, the shorter the recommended pecking depths are. As always, miniature drills with a diameter of less than .010″ are extremely fragile and require special precautions to avoid immediate failure. For help with your specific job, contact the Harvey Tool Technical Team at 800-645-5609 or [email protected]
Contouring & 5-Axis Machining
 Recent Contouring Advances
1. Increased Time Savings
2. Reduced Cycle Times
3. Improved Consistency
Contouring Tips
