Why You Should Stop Deburring By Hand
High Precision Tools
hand deburring
cnc deburring
cnc deburring
A Growing Industry
1. Running It Too Fast or Too Slow
Determining the right speeds and feeds for your tool and operation can be a complicated process, but understanding the ideal speed (RPM) is necessary before you start running your machine. Running a tool too fast can cause suboptimal chip size or even catastrophic tool failure. Conversely, a low RPM can result in deflection, bad finish, or simply decreased metal removal rates. If you are unsure what the ideal RPM for your job is, contact the tool manufacturer.
2. Feeding It Too Little or Too Much
3. Using Traditional Roughing
high efficiency milling
4. Using Improper Tool Holding
tool holding
5. Not Using Variable Helix/Pitch Geometry
variable helix
6. Choosing the Wrong Coating
end mill coatings
7. Using a Long Length of Cut
optimal length of cut
8. Choosing the Wrong Flute Count
flute count
Calculating MRR
Optimizing Efficiency
The Anatomy of an End Mill
Flutes
end mill flutes
Profile
Square Profile
Corner Radius
Ball Profile
cutter diameter
Shank Diameter
end mill neck
Helix Angle
helix angle
Pitch
variable pitch
Helical Part No. 33737
Material 4340 Steel
ADOC 2.545″
RDOC .125″
Speed 2,800 RPM
Feed 78 IPM
Why Flute Count Matters
Tool Geometry Basics
flute count core
Material Considerations
flute count
flute count
