High Efficiency Milling for Titanium Made Easy With Helical’s New HVTI Cutter
Titanium is a notoriously difficult material to machine, especially in aggressive toolpaths, such as those associated with High Efficiency Milling (HEM). Helical Solutions’ new line of tooling, the HVTI-6 series of end mills, is optimized specifically for this purpose, and proven to provide 20% more tool life than a competitor’s similar tool.
At face level, these new Helical end mills feature corner radius geometry, 6 flutes, and are Aplus coated for optimal tool life and increased cutting performance. But there is much more to these end mills than the typical geometry of standard 6 flute tools. The HVTI-6 was designed with a combination of a unique rake, core, and edge design that give it a leg up over standard 6 flute tools for Titanium while cutting HEM toolpaths. Click here to watch the HVTI-6 in action!
End Mills for Titanium
Helical HVTI Titanium
WATCH THE HVTI IN ACTION
In these tests, the HVTI was able to run HEM toolpaths at 400 SFM and 120 IPM in Ti6Al4V, which served as the baseline for most of the testing.
Machining Precious Metals
About the Elements
  1. Ruthenium (Ru)
  2. Rhodium (Rh)
  3. Palladium (Pd)
  4. Silver (Ag)
  5. Osmium (Os)
  6. Iridium (Ir)
  7. Platinum (Pt)
  8. Gold (Au)
machining metals
precious metals
machining metals
machining metals
Tools for Precious Metals
machining metals
machining metals
Speeds and Feeds charts:
machining metals
machining metals
What To Know About Helical Solution’s Zplus Coating
zplus coating
zplus coating
Large Production Runs
https://www.instagram.com/p/BtQz9WJBimC/
Finishing Applications
What to Know About Harvey Tool’s TiB2 Coating
What is Harvey Tool’s TiB2 Coating?
TiB2 Specifications
TiB2 is identified in Harvey Tool’s product catalog with a “-C8” following the sku number. It can be found offered in Harvey Tool’s lines of Variable Helix End Mills for Aluminum Alloys, Double Angle Shank Cutters, and Miniature High Performance Drills for Aluminum Alloys.
When Should a Machinist Use TiB2?
Chip Evacuation Concerns
https://www.instagram.com/p/Buo1qFmlV1d/
Extremely Abrasive Materials
Extremely Soft Materials
When Finish Is Vital
  • Increased tool life.
While many manufacturers will specially coat a standard end mill at your request, this takes added time and cost. In its Material Specific catalog sections, Harvey Tool offers coated tools stocked and ready to ship. For instance, their Hardened Steels and Exotic Alloys categories utilize AlTiN Nano coating. This is a unique nanocomposite coating that has a max working temperature of 2,100° F and shows improved performance in materials such as Hardened Steels, Titantium Alloys, and Inconel, among others.
Miniature End Mill
Part Number: 836408
Material: 6061 Aluminum
Application: Slotting
Speed: 10,000 RPM
Chip Load: .00124 IPT
Linear Feed: 37.2 IPM
DOC: .04375
Part Number: 942308
Speed: 10,000 RPM
Chip Load: .00165 IPT
Linear Feed: 49.5 IPM
DOC: .0625
Extensive Cost Savings
