Boring is a turning operation that allows a machinist to make a pre-existing hole bigger through multiple iterations of internal boring. It has a number of advantages over traditional drilling methods:
- The ability to cost-effectively produce a hole outside standard drill sizes
- The creation of more precise holes, and therefore tighter tolerances
- A greater finish quality
- The opportunity to create multiple dimensions within the bore itself
Solid carbide boring bars, such as those offered by Micro 100, have a few standard dimensions that give the tool basic functionality in removing material from an internal bore. These include:
Geometries
Defining the Geometric Features of Boring Bars:
