  1. Drilling
  2. V-Grooving
  3. Milling
  4. Spot Drilling
  5. Chamfering
drill mill operations
drill mills
Drill Mills: Tool Offering
Mill Style – 2 Flute
drill mill
Mill Style – 4 Flute
drill mill
Drill Style – 2 Flute
drill mills drill style
Helical Tip – 4 Flute
Harvey Tool: Behind The Scenes
Many of our end users have had great questions about our manufacturing process, how we keep all of our tools in stock, and more. Now for the first time, we decided to open our doors and show you how we manufacture and fulfill the Harvey Tool product. We partnered with John Saunders from NYC CNC to create a “Factory Tour” video, covering topics like our CNC grinding machines and setups, tool manufacturing, and our warehouse organization and fulfillment procedures.
In the video below, we first toured our Rowley, MA warehouse and fulfillment center with Fulfillment Manager Megan Townsley. After that, we head up to Maine to check out how the Harvey Tool product is manufactured and inspected with VP of Operations Brian McKahan.
We know you’re busy making amazing parts, and might not have time for the entire video. To save you time, here are some of the highlights and facts you should know about Harvey Tool.
When We Say Miniature, We Mean Miniature
Our miniature end mills are in stock in diameters down to .001″. In fact, our Stub and Standard end mills cover every diameter from .001″ to .120″, meaning we will always have you covered when it comes to micro-machining. Although it is hard to see with the naked eye, you can get an up-close look at the famed .001″ end mill by jumping to the 35 minute mark in the tour video.
Micro-Tools Require Precision Grinding
We utilize advanced CNC grinding technology to manufacture our miniature tools at our plant in Maine. Brian MacKahan, VP of Operations, does an excellent job of breaking down our manufacturing process beginning at the 21 minute mark of the tour video. If you just want to see some miniature CNC grinding in action, jump ahead to the 26 minute mark.
Our Inspection Process is Rigourous
All of our tools are sent through an extensive inspection process, both at our plant in Maine and at our headquarters in Massachusetts. To check out the Massachusetts inspection room, head to the 19 minute mark of the video. If you want to see some more in-depth inspection at our facility in Maine, you can jump to the 35 minute mark.
Yes, We Have It In Stock
If you need it, we have it. All 20,000+ tools from our catalog are kept stocked and ready to ship to you the same day. If you need more proof, jump to 15:30 in the tour video, where you will see John Saunders choose a randomly selected Undercutting End Mill from our catalog and find it in our warehouse, in stock and ready to head out to a shop.
We Maintain a 99.8% Order Accuracy Rate
Our fulfillment team handles all of your orders with precision and accuracy. We maintain a 99.8% order accuracy rate, with fulfillment team members checking every order multiple times to ensure you receive exactly what you need. You can learn more about our order fulfillment process and accuracy rates by moving to the 5 minute mark in the video.
We Sell More Than Miniature
Miniature end mills have always been our bread and butter, but did you know that we have many larger diameter tools in stock as well? At the 9 minute mark in the video, you can see John pull out a 3/4″ Long Reach Ball Nose End Mill from our shelves. If you are interested in larger diameter specialty tooling, jump to 12:15 in the video to check out one of our large diameter Corner Rounding End Mills.
When You Call, You’ll Always Talk to An Experienced Tech Expert
Though we didn’t catch it on tape, John Saunders was blown away by our tech team during his visit. He got a chance to pick their brains about a problem he was having and a few minutes later, he received a recommendation for the right compression cutter to tackle his unique operation. This tool was later showcased in one of his “Widget Wednesday” videos.
When you choose Harvey Tool, you will never get an automated system or countless steps before you are able to talk to a real person about your applications. Our industry-leading technical support team is available over the phones or via email every Monday-Friday from 8 AM EST to 7 PM EST. You can reach them by calling 800-645-5609, or by sending an email to [email protected].
We Value Our Distributor Network
We value our large distributor network, and we ask that all orders are placed with your local dealer. To find the closest distributor to you, use the “Find a Distributor” tool on our website.
We’re Hiring!
We are currently hiring for many different positions, including open CNC Machinists positions for all shifts at our manufacturing plant. If you want to be a part of the Harvey Performance Company team, check out our Opportunities page for more information.
A Corner Rounding End Mill is typically used to add a specific radius to a workpiece, or in a finishing operation to remove a sharp edge or burr. Prior to selecting your Corner Rounding End Mill, mull the following considerations over. Choosing the right tool will result in a strong tool with a long usable life, and the desired dimensional qualities on your part. Choosing wrong could result in part inaccuracies and a subpar experience.
Selecting the Right Pilot Diameter
Flared or Unflared
Front or Back
Choosing between a Corner Rounding End Mill and a Back Corner Rounding End Mill boils down to the location on the part you’re machining. A Back Corner Rounding End Mill should be utilized to put a radius on an area of the part facing the opposite direction as the spindle. While the material could be rotated, and a front Corner Rounding End Mill used, this adds to unnecessary time spent and increased cycle times. When using a Back Corner Rounding End Mill, ensure that you have proper clearance for the head diameter, and that the right reach length is used. If there is not enough clearance, the workpiece will need to be adjusted.
Corner Rounding End Mills are often offered in 2, 3, and 4 flute styles.  2 flute Corner Rounding End Mills are normally used for aluminum and non-ferrous materials, although 3 flutes is quickly becoming a more popular choice for these materials, as they are softer than steels so a larger chip can be taken without an impact on tool life. 4 flutes should be chosen when machining steels to extend tool life by spreading out the wear over multiple teeth. 4 flute Corner Rounding End Mills can also be run at higher feeds compared to 2 or 3 flute tools.
The best corner rounding end mill varies from job-to-job. Generally speaking, opting for a tool with the largest pilot diameter possible is your best bet, as it has the most strength and requires less power due to its larger effective cutter diameter. A flared Corner Rounding End Mill is preferred for blending purposes if the workpiece is allowed to have an incomplete radius as this allows more forgiveness and can save on set up time. If not, however, an unflared Corner Rounding End Mill should be utilized. As is often the case, choosing between number of flutes boils down to user preference, largely. Softer materials usually require fewer flutes. As material gets harder, the number of flutes on your tool should increase.
Attacking Aluminum: A Machining Guide
Tool Geometry
flute count for aluminum
Helix Angles
Aluminum Machining
Tooling Options
Chipbreaker Tooling
Chipbreaker Aluminum
High Balance End Mills
Among Harvey Tool’s expansive holemaking solutions product offering are several different types of miniature tooling options and their complements. Options range from Miniature Spotting Drills to Miniature High Performance Drills – Deep Hole – Coolant Through. But which tools are appropriate for the hole you aim to leave in your part? Which tool might your current carousel be missing, leaving efficiency and performance behind? Understanding how to properly fill your tool repertoire for your desired holemaking result is the first step toward achieving success.
TL Technologies – Featured Customer
TL Technologies helps manufacturers reduce time to market and drive down per-piece cost with their unique “Intelligent Design and Planning” processes. Located in Lancaster, Pennsylvania, TL Technologies serves manufacturers throughout the mid-Atlantic from their centrally located, 10,000 sq. ft. facility. Their unique manufacturing processes and services quickly made them stand out in the industry since their inception in 2012.
Jonathon Thompson is the Vice President of Engineering at TL Technologies. Jonathon talked with us about their rigorous manufacturing and inspection processes, the advantage of using high-quality tooling, their unique on-site assembly services, and much more in this Featured Customer interview.
TL Technologies got started in January 2012. Our first customers were firearms and defense based. Since then we have diversified our business through growth within customers and word of mouth. We started with the intent to be precise and accurate in a lights-out or nearly automated fashion.
We use an array of modern equipment. 4 axis Kitamura HX400G Horizontal Mills. Nakamura Tome 9 axis Turn Mill, Star 6 axis, and two 5 axis vertical Hurco Machines. All our machines are optioned out with Renishaw probing and all the bells and whistles required to handle high accuracy runs for 24 hours a day with no process issues. Most of the machines have glass scales and thermal packages.
kitamura cnc machine
Which materials do you most often work with at your shop?
Mostly steels; the usual 4000 and 8000 series steels. Comparatively less 6061 and 7075 aluminum and other common stainless grades. We’ve been fortunate to have many of our materials within a reasonable range of Rockwell so that we may tool accordingly for most of the business.
How has your experience been with multi-axis machining?
Fantastic. Multi axis Machining has been excellent for us. It requires high-level understanding to fully maximize but the benefits are huge.
On your website, you mention that TL Technologies has never delivered a rejected part. What sets your quality apart from the competition?
From day one and job one, we worked with the customer to understand exactly how they were measuring the parts, exactly with what tools, processes, and methods to identically duplicate the process in our shop. After replicating key processes we performed many correlation studies to ensure that our measurements were within single-digit microns of what our customers were seeing on their end during inspection. This methodology was scaled up into our overall quality program and allows us to greater understand and manufacture our goods. Our ISO process coupled with this method truly does prevent bad work from getting out. We have never had a case where a part did not function or perform due to our oversight or bad specs. There have been failures on the customer side of things due to engineering, bad prints, and tolerance stackups, but we have not supplied parts that were flat out incorrect.
TL Technologies
What sort of tolerances do you work in on a daily basis?
Typically single or double-digit microns. .0002” to .003” total is common for a large percentage of specs. It is not unusual for +/-.0002” to run long-term over many fixture stations with no manual adjustment. Our machined products are from 1” to 8” cubed.
What are some of the coolest projects you have had come through the shop?
That’s a good question. TL Technologies sat on the United States Senate committee in 2013 for Small Business and Entrepreneurship. We were featured on the cover of New York Times business section in 2013 as well. Throughout our years we’ve been fortunate to meet many amazing people from high branches in the government, the US Military, top name manufacturers, lenders, and local municipalities. Some of the coolest contacts were folks that formerly operated with US Special Forces. Unfortunately, we cannot comment.
As for projects not covered by an NDA, one of my personal favorites was producing low impact physical therapy products for rehabilitating shoulders after surgery. Though simple in manufacturing, this project provided an array of fun challenges that required high performance tooling, 3D printing, and using our machines with custom cycles. This allowed us to use the equipment very unconventionally. In this way, we were able to provide a cost-effective product utilizing the maximum ability of our equipment with a very short lead-time and low up-front cost.
harvey tool catalog
You also offer assembly services on-site, which is fairly unique in the industry. Can you talk a little bit more about this?
Sure. Both my business partner and I have tremendous experience with assemblies in both hands-on and directorial roles. Whether it was a high precision multi-axis mechanism that ended up being a custom machine, on and off-road vehicles, or even things like child safety seats, we have had our hands in a lot of things over the years. At TL Technologies we’ve provided assistance to machine tool builders, special tooling designers, consumer goods of various types, and most frequently to firearms builders. Mostly we drive out cost, but as we age we’ve been called upon to troubleshoot high-end assemblies where the issues were not immediately apparent. This led to us creating sub-assemblies and even semi-finished OEM products. This includes hand fitting and assembling collectible pistols and precision bolt action rifles. This is usually offered as a temporary solution or process engineering service to larger companies developing new goods or revamping existing ones, and is offered as part of our comprehensive knowledge to attract clients. It has been very successful.
You service a variety of industries, including defense, automotive, agricultural equipment, and consumer products. Do you have a personal favorite?
I’d have to say the products we make that almost every soldier carries and relies on are my favorite. We take great pride in knowing that these parts have not failed due to machining error since we took over the production years ago on the core components.
TL Technologies
Why is American manufacturing important to you?
It’s everything. It’s the heart and soul of all products and by extension facilitates the means with which goods and services exist in our society. By bolstering the skills, knowledge, and experience, we can not only succeed economically but also further the craft and pride of making quality goods. We will always need to be able to make our own goods. The skill and craft to create is more than just economic. We absolutely must embrace and respect the skill and hard work it takes to create. We must pass that knowledge on for posterity so the next generation might find the satisfaction and pride of skilled work.
It’s everything. The old adage, “Garbage in, garbage out,” is accurate for us. We feel that if we invested so much in these high-end machining centers, it would be criminal to put insufficient tooling and holders into them. We found that by selecting the proper tool with the appropriate sciences behind it we have been able to create products with a cost per cut that is not only competitive, but required to stay current. By keeping the quality as high as possible on the part making side of things, we’ve insured as much ease and reliability into our downstream process as we could. Quality tooling also provides predictability and added safety into the workflow. High-quality carbide tooling is the lifeblood of the business.
Have Harvey Tools had an impact on your performance?
Oh man…frequently. Harvey Tools are a mainstay in our company. If I had to think of some key examples it would have to be your variety of Keyseat Cutters, 3 Flute Counterbores, Extended Reach Ball End Mills, and Miniature End Mills under .040”. The 270 degree Lollipop Cutters are excellent for deburring, and we also rely on the 140° spot drills, corner radius forming tools, and more. In short, not only are the tools good, but they provide exactly what we need and the specifications to handle major OEM jobs. We absolutely love metric and you’ve got that too. Your catalogs help us eliminate the need for customs. That is key to cost and lead time.
harvey tool
Embrace the old knowledge and techniques. The manual skills learned with files and hand ground tools translate critically into the concepts you will need to master if CNC becomes your career. Understand how and why materials cut or refuse to cut, what rake angle to use and when, and how to leverage machine physics to help you work smarter instead of harder. Don’t be afraid to jump down the rabbit hole of engineering concepts, materials, physics, elementary chemistry; these all help give you an edge. Machining is done best with comprehensive knowledge of the machines and machining environment. You never stop learning. All that said, keep a fresh perspective. Old knowledge can be great, but operationally each business will likely have its own methods and flow. Try to understand there is more to the overall business picture than you can often see.
Oh definitely! Buy our stuff!! Ha. We are a supplier of choice for OEM, and small batch bolt actions for rifles, pistol components, and pistol slides. We machine to spec and provide cost-competitive options as well as super-premium options.  We are working now to release our own line of aftermarket products in 2018, so keep an eye out for those!
TL Technologies
1. Premature Tool Decay / Tool Failure
tool wear
2. Subpar Part Finish
3. Inefficient Coolant Usage
4. Not Taking Advantage of Tool Versatility
chamfer mills
5. High Machine Downtime
What use is a machine that’s not running? Minimizing machine downtime is a key way to ensure that your shop is reaching its efficiency pinnacle. This can be accomplished a variety of ways, including keeping like-parts together. This allows for a simple swap-in, swap-out of material to be machined by the same cutting tool. This saves valuable time swapping out tooling, and lets your machine to do its job for more time per workday. Production planning is a key factor to running an efficient machine shop.
A Growing Industry
Aspex CNC – Featured Customer
Aspex CNC is a CNC machine shop based out of Poway, California. They offer prototype turning and milling, as well as production level machining. Their quick turnaround times and premium quality have garnered them some serious recognition in the manufacturing industry. Aspex CNC is just one of the four businesses that Gary Colle Jr. currently owns, but they are an essential part of his business ecosystem, creating parts for the other three product-based companies while also offering machining services to outside customers.
We talked to Gary about his unique experiences in the industry, his thoughts on 5 axis machining, his advice for trying High Efficiency Milling, and more!
Tell us a bit about how you got started in machining, your businesses, and how Aspex CNC was formed.
It is a bit of an interesting story. I got started in manufacturing because my father designed, developed, and manufactured one of the first lines of Wheelchair Accessible Vehicle lifts, which allow people in wheelchairs to easily get in and out of their vehicles. The company was called GoldenBoy Mobility and is still one of the four business I currently own and operate today.
At a young age, I was working in my father’s shop, answering phones and doing odd jobs as young as the age of 10. When I got to high school, I worked after school and during the summers in a more hands-on position, welding parts, cutting up cars, and helping on the shop floor. This really inspired my love for metalworking at a young age.
goldenboy mobility
My dad used to let me mess around in the shop at night, so I started welding my own parts and trying to learn as much as I could. One day, someone came in and asked if I could create a “tuna tower” (an accessory for wakeboarding/water skiing) for their boat. I relented at first, but eventually gave in and welded all the parts together for him. After I made that one, word got around that I could create these at night. I started to advertise a little bit locally, and people started ordering more and more. That summer, I ended up making 50 of these towers and got noticed by a couple of big distributors. Scaling up like that made it necessary to outsource some of our parts to local machine shops, which is where I discovered machining. I had very little prior knowledge of machining, but once I stepped into my first machine shop, I was blown away.
As that business grew even larger (now known as DBG Concepts), I needed more parts and needed them faster. We outgrew the local shops and purchased our first machine, a Fadal 4020 CNC Mill, from a local machine salesman, who also helped teach me the ropes. I learned a lot in those first 6 months about machining.
Business kept ramping up, and my father eventually retired and I took over GoldenBoy Mobility. With all the extra parts we needed, we kept machining things in-house, and buying more mills. Eventually, machining became an even larger part of the business than either DBG Concepts or GoldenBoy Mobility, so we formed Aspex CNC to move our machining out of the product line and more into prototype work and production machining for other business. We still machine most of the parts for DBG and GoldenBoy in-house, but we are doing much more for outside sources than we used to.
Right now, we are a Haas-only shop. We currently have eight Haas machines in our shop. Our lineup consists of a couple of lathes (ST10 and ST30), a Super Mini Mill, and five CNC Mills (VF2SS, VF2SSYT, VF4SS, VF5SS, and UMC750SS), with another UMC750 on the way!
aspex cnc
Which materials do you most often work with in your shop?
We work with a lot of the common materials, 6061/7075 Aluminum, 1018/1045 Steel, 303/304/17-4ph Stainless, as well as plastics like Acetal, UHMW, HDPE, and PVC.
How has your experience been with 5 axis machining?
If you don’t keep up with technology, you won’t be able to keep up with business, so learning multi-axis machining was a no-brainer for us. We first started with a Haas HRT210 4th axis rotary, and began to play with that. Over the next two years, we learned everything we could about multi-axis machining and made the decision to upgrade to a 5 axis machine. We actually went to IMTS that year to talk to manufacturers and find the perfect machine for us and ended up sticking with Haas because of their support platform and educational resources.
5 axis can be hard, but there are a lot of tools out there (HSM Works from Autodesk being one) that can help you learn. It does require a little more upfront work and discipline, but it eliminates a lot of setup time, creates new opportunities for our shop, and has been really good for us from a business standpoint. A big part of our business is machining one-off parts, so the 5 axis machine allows for a faster turnaround time for those odd shapes and sizes we come across.
5 axis machining
You are very active on social media promoting your business. How has the online machinist community helped your business?
Honestly, even though it can become a bit of a distraction at times, using social media to share our work and partner up with companies like Harvey Tool and Helical has been a lot of fun. We are still young in the social media space, so we haven’t seen a massive impact yet, but the best is yet to come. We have received a few bites here and there which has led to work, but as with everything, it takes some time. We expect a lot of growth this year as we work on more really neat projects and continue to get our name out there. As we grow, the opportunities are going to come.
aspex cnc
What are some of the coolest projects you have ever worked on?
Unfortunately, we can’t talk about most of the work we do, due to customer confidentiality, but we did just do a project for the State of California building a training vehicle for their driver’s education program. We designed and built a dual steering system that gave the driver’s trainer a second steering wheel on the passenger side of the car to be used during training. Another job we just finished up was some parts for the new Raiders football stadium in Las Vegas. They contacted us in a pinch and needed them in two days, and we made it happen. It is pretty cool to know you played a part in a huge project like that.
Aspex CNC also does a lot of work with racing/off-road vehicle companies, often machining parts for the chassis and suspension components. We have worked on projects for companies like Scarbo Performance, ID Designs, TSCO Racing and a whole list of others.
You can only use one machine for the rest of your life. Do you go with a CNC Milling machine or the Lathe?
I would hate to have to choose between them, but it is 100% the CNC Mill. I love ripping around with end mills and working with the 5 axis machines. It is mind blowing what these things are capable of.
Why is manufacturing products in America important to you?
Growing up in the industry which I did while working under my father (building wheelchair accessible vehicles), we had a lot of customers who were veterans coming back from Vietnam or Desert Storm who had been injured overseas and needed extra accommodations, which we could provide for them. The veterans I have worked with made me so patriotic with their stories and courage. We also get to work on a lot of projects with the US Department of Veteran’s Affairs, which is putting money back into the American economy by supporting companies like ours and contracting us to make these vehicles. It only makes sense that we employ more people here and avoid sending things overseas to support those who have supported us.
aspex cnc
Do you utilize High Efficiency Milling (HEM) techniques in your shop? What advice do you have for those who are getting started with HEM?
Absolutely, all the time!
The biggest thing is listening to your tool manufacturer for recommendations and then cut those in half to start. From there, work your way up until you are comfortable. Just because the tool can handle it doesn’t necessarily mean your machine, work holding and or set up can, so I would advise people to walk before you run when it comes to HEM.
Be conservative and establish good habits from the start. You can get more aggressive as your career starts to take off, but don’t run out and try to run the biggest and baddest machines on day one and try to cut corners. You need to learn what is behind machining; you can get easily lost in all the technology that is available, but you need to understand the core science behind it first. Take it slow, because if you go too fast, you might miss something important along the way.
The best thing is building relationships with companies like Haas, Harvey Tool, and Helical. Not only do they provide great service and support for you, but it quickly becomes a mutually beneficial relationship. As we give feedback to the tool and machine manufacturers, and even our metal supplier, it helps them improve their products, which in turn allows our shop to increase our production and efficiency.
Also, having a good team with good people makes all the difference. No matter how many machines you have and how automated you get, you still need good people on your side. I would put my guys up against any other machine shop out there in terms of skill, and it is a big part of what has made our business so successful.
aspex cnc
Zootility – Featured Customer
Zootility prides themselves on designing products that blend art and function for everyday use. Everything from design to manufacturing to distribution is done at their custom shop in Portland, Maine. Utilizing laser-cutters, laser-etchers, and CNC Machines, their skilled team works 15 hours a day to carry out their mission to get their incredibly thin, extremely useful “zootilitarian” tools into pockets everywhere. Zootility was founded by Nate Barr and was launched on the back of a successful Kickstarter campaign for their first tool, the PocketMonkey. Nate has now expanded Zootility and grown into several more products and brands, including the “WildCard” Wallet (Pocket) Knife, “Open Beer Season” bottle openers, the popular “Headgehog” Wallet Comb, and their new line of “Tülry” multi-tools that disguise as fashionable jewelry.
We visited Zootility at their shop in Maine and talked to Nate and Chris, one of their CNC Machinists, about using Kickstarter campaigns to launch new products, the state of the Manufacturing Industry, machining in very tight tolerances, and more in this latest Featured Customer blog.
Thanks for having us, Nate! Tell us a little bit about your shop and how you got started with Zootility.
Nate: Zootility really started as a maker shop for our first product, PocketMonkey. The goal was always to take the idea behind the PocketMonkey and grow it from just a Kickstarter project so that I could expand the business. I also wanted to make sure that I was learning something new myself every step of the way; I wanted to understand how to make our products, so we could keep production in-house and use our knowledge to expand the business in the future. When we started, I was re-investing all of our proceeds back into the business, allowing us to buy more equipment and really build out the shop. Our shop is fairly unique, where we now have nearly total vertical integration across the board. The only thing we need to do now is buy an iron mine and get our own materials!
How did you come up with the idea for the original Pocket Monkey?
Nate: I came up with the idea for the Pocket Monkey one day while I was locked out of my apartment. I was living in Boston at the time, and I would run out every night to the stores around the corner to buy food for dinner, typically only taking my wallet with me. One night, the door locked behind me, and I was locked out, sitting on my front steps and wishing I had some sort of a shim to slip the lock. I started thinking what that would look like and how it could fit in a wallet for easy carrying and realized that I could add on more tools like bottle openers and screwdrivers while still keeping it slim enough to fit in my wallet. I had studied Mechanical Engineering in college, so I had the background to create what I was envisioning.
Pocket Monkey
You have used Kickstarter campaigns very successfully, not only to launch Zootility, but also to further your product line and expand the business. How was the Kickstarter experience, and would you recommend it to other entrepreneurs looking to launch a new business?
Nate: Our Kickstarter experience was great. We have raised up to $90,000 in a single campaign, and we have figured out a strategy that works for us. We found that if you set a reasonable goal that will allow you to cover start-up costs, say $25,000 rather than $100,000, people are more willing to take the time to invest. A reasonable goal gives people more confidence that the project will be funded, and that it will be successful, leading to more backers and more exposure; it is a great Marketing tool in that regard.
Kickstarter also levels the playing field for smaller companies like Zootility – I consider it to be “The Great Equalizer”. There is no longer a need to have tens of thousands of dollars for upfront costs when starting a business. You can spend a little bit of time creating the campaign and invest a small amount of money into that without taking the huge risk of throwing your life savings into an unproven idea. When I started Zootility, I was still working my day job and did not have the money to put up front, so Kickstarter was a natural fit. We have continued to use Kickstarter for new product lines because we are committed to manufacturing our products in the US, so Kickstarter campaigns allow us to validate new ideas and collect funds up front as we continue to grow the business. I do recommend it for all the entrepreneurs out there, and it has been a great tool that has contributed to our success.
You mentioned your commitment to manufacturing Zootility products in the US. What makes this ideal so important to you?
Nate: Let me start by saying that I think that Globalization is a good thing; it has pulled huge numbers of people across the world out of poverty. However, American policies have essentially allowed large corporations to gut the middle class by moving jobs overseas, especially in more rural areas. This has created unbalanced manufacturing and retail sectors. Personally, I believe things have gone too far, and standing behind our belief in American-made goods allows us to contribute to a more balanced approach to manufacturing. As with all things in life, a balanced approach is the best option. There will never be a time when 100% of goods can be feasibly made in America, so overseas manufacturing will continue, but bringing back more jobs to the middle class here in America is a good thing for the entire industry.
zootility
We have definitely made an effort to re-invest in our local community and the people who live here by manufacturing our products right here in Maine. Offshoring has resulted in a loss of knowledge and a real disconnect from the products that we use every day. Products that were previously considered to be of a high quality are now losing their shine, as less care is put into them and there is less appreciation and understanding of how these things are made. By investing in our local community and ourselves by learning something new every day, we believe we are doing our part to bring this knowledge back and instill more of a sense of pride in our employees and the products that they help to create.
You are originally from the Boston area. What made you decide to move the company and shop to Maine?
Nate: I had originally looked at a few places in the Boston-area, but it just didn’t make sense financially. There is a lot of great technology being developed in Boston by the innovative companies in the area, but to set up a manufacturing business in Boston was cost-prohibitive. By moving our shop to Portland, Maine we were able to save a lot on the space, which helped us in the early stages of the business.
The other thing was the lifestyle change. Portland has a great downtown area with lots of small businesses. There are restaurants, breweries, coffee shops, and plenty of locally-owned shops. It is also easy to get around, either by car or bike, and there is very little traffic throughout the city. I also wanted to locate our shop so that it felt like part of a community. We were able to find a great spot in downtown Portland surrounded by other manufacturers and small businesses. It makes for a great place to come to work every day.
What does the future hold for Zootility?
Nate: Right now, we do as much business in Q4 around the holidays as we do the entire rest of the year, so we have been exploring ways to make better use of the machines during the slower months. As we have completed installing and setting up our new machines, we have begun to do contract manufacturing to fill out the rest of the year. We have the unique ability to create small parts with extremely tight tolerances, and we are willing to do small volume, small batch manufacturing that other shops may turn down. We have been getting business from companies in Boston, who are looking for the “just in time” manufacturing which we can provide. The extra revenue from these projects will allow us to take off the Kickstarter training wheels and expand the business faster on our own.
tulry
From a product standpoint, we are looking to launch more “serious” tools for the outdoor enthusiast. Right now we are in the process of launching our new RNGR brand, which will be a line of minimalist every day carry products, without the whimsical nature of the Zootility Tools products. We also are on the verge of shipping our new TÜLRY brand, which is a series of jewelry infused with every day carry tools.
Chris, you create a lot of very thin products. How does that affect your workholding when working in materials that thin?
Chris: Our workholding has been built entirely custom for our CNC machine, due to the nature of the products. For example, we are currently working on our WildCard knives, which are only .040″ thick. There really isn’t much on the workholding market that will work well for something that small, so our team actually machined our own metal strips on the CNC, held the knives down with small bolts, added some rubber bumpers so we do not have metal on metal contact, and it has worked really well for us so far. We also created custom workholding for the new TÜLRY line tools, which are also extremely thin.
helical solutions
The biggest challenge with our custom workholding is the additional time it adds to each job. Right now, we can run batches of 72 knives per cycle, with a cycle time of 28 minutes. Then, we need 20-25 minutes to unscrew each of the bolts, remove the finished knives, and then insert the new knives and screw the bolts back in. However, it is the only way we can machine products this thin with our tight tolerances, and we can still finish around 600 knives per day.
You mentioned your tight tolerances. What are some of the tolerances you are working in every day?
Chris: Right now, all of our tolerances are in the thousandths. For example, the WildCard knives have a tolerance of just +/- .003″, and the screwdriver tools on the TÜLRY necklace, while one of our highest tolerances, stick to just +/- .005″. The tightest tolerance we are currently working in is on the hex wrench tools for the TÜLRY necklace. The hex wrench tools have to be spot on, or they will be too loose when they go to be used on a hex nut. Right now, we like to keep those tools to a tolerance of +/- .001″.
How has your experience been using Harvey and Helical tools on these projects?
Chris: The Harvey and Helical tools have been great for us. When I started, we had another brand of end mills in stock, and they simply weren’t cutting it (no pun intended) in the types of heat-treated stainless steel which we were working in. We switched over to the Helical 7 flute end mills for roughing and finishing of the knives. Each knife has a very small shelf on it, which allows it to be a removable piece of the WildCard tool. We use a 3/8″ 7 flute Helical end mill with a .020″ corner radius for this cut, with a 3/8″ 7 flute square end mill for finishing. One interesting part of this job is that it requires a very low ADOC because the tools are already so thin, that the roughing we do removes only a very small amount of material.
harvey tool
We also use both Harvey and Helical chamfer mills to create all of the box cutter and hex wrench TÜLRY tools. With the hex wrenches, we have found that the 60° tipped off chamfer mill has been great for creating those intricate cuts. With the box cutters, we needed an edge sharp enough to cut through tape and cardboard, but not sharp enough to cut through the skin. We have found that the 2 flute 120° chamfer mills work best for those cuts.
What is the biggest challenge you face at the CNC machine?
Chris: Right now, we laser cut all of the outlines for the knives from a thin sheet of steel. Then the knives come to us right off the laser cutter for machining. The laser cutting does create a rough finish on some of the knives, which can make them hard to lock down when machining. This can result in some movement, which can lead to the occasional scrapped part. The laser cutter can also leave burrs at the start and stop points, or leave a scorch mark or some slag on the knives, which can make them tougher to machine.
The Zootility shop uses a lot of different equipment. How has the CNC machine in particular impacted the shop as a whole?
Chris: Our CNC machine comes in handy for a lot of different things around the shop. As I previously mentioned, we used it to create our own custom workholding, which has worked very well for us. We also used the CNC machine to create all of our forming dies, which are used to create all of our tools from scratch. As we move into more contract manufacturing for other companies, these machines will get even more use when we are working on the small batch jobs we will (hopefully) be getting.
cnc machinist
