Tag Archive for: Heat Management
What to Know About Harvey Tool’s TiB2 Coating
Explore More TiB2 Tooling With Harvey Tool’s End Mills for Aluminum
What is Harvey Tool’s TiB2 Coating?
TiB2 Coating Specification chart
TiB2 is identified in Harvey Tool’s product catalog with a “-C8” following the sku number. It can be found offered in Harvey Tool’s lines of Variable Helix End Mills for Aluminum Alloys and Miniature High Performance Drills for Aluminum Alloys.
When Should a Machinist Use TiB2 Coating?
Chip Evacuation Concerns
Large Production Runs
Extremely Abrasive Materials
Extremely Soft Materials
When Finish Is Vital
Understanding the Two Styles
Chipbreaker End Mills
Knuckle Roughers
tool life
tool life
helical end mill
tool life
heat generation in HEM
Chip Thinning Awareness
Consider Climb Milling
heat generation
tool wear Shop Inefficient
Subpar Part Finish
Inefficient Coolant Usage
chamfer mills
Using Traditional Roughing
high efficiency milling
tool holding
variable helix
end mill coatings
Using a Long Length of Cut
flute count for tool life
Work Hardening and When it Should Scare You
Soften Up Work Hardening With Harvey Tool’s Speeds and Feeds
Work Hardening Overview
titanium packed ball bearing
Major Problems
work hardening
How To Avoid Work Hardening
Benefits of HEM:
  • Faster cycle times.
  • Overall cost savings
small harvey tool end mill for micromachining
micromachining
