Helix Angles Rule of Thumb
One general rule of thumb is that as the helix angle increases, the length of engagement along the cutting edge will decrease. That said, there are many benefits and drawbacks to slow and high helix angles that can impact any machining operation.
Slow Helix Tool <40°
Benefits
Enhanced Strength – A larger core creates a strong tool that can resist deflection, or the force that will bend a tool under pressure.
Reduced Lifting – A slow helix will decrease a part from lifting off of the worktable in settings that are less secure.
Larger Chip Evacuation – The slow helix allows the tool to create a large chip, great for hogging out material.
Drawbacks
Rough Finish – A slow helix end mill takes a large chip, but can sometimes struggle to evacuate the chip. This inefficiency can result in a sub-par part finish.
Slower Feed Rate – The increased radial force of a slow helix end mill requires running the end mill at a slower feed rate.
High Helix Tool >40°
Benefits
Lower Radial Force – The tool will run quieter and smoother due to better shearing action, and allow for less deflection and more stability in thin wall applications.
Efficient Chip Evacuation – As the helix angle increases, the length of cutting edge engagement will decrease, and the axial force will increase. This lifts chips out and away, resulting in efficient chip evacuation.
Improved Part Finish – With lower radial forces, high helix tools are able to cut through material much more easily with a better shearing action, leaving an improved surface finish.
Drawbacks
Weaker Cutting Teeth – With a higher helix, the teeth of a tool will be thinner, and therefore thinner.
Deflection Risk – The smaller teeth of the high helix tool will increase the risk of deflection, or the force that will bend a tool under pressure. This limits how fast you can push high helix tools.
Increased Risk of Tool Failure – If deflection isn’t properly managed, this can result in a poor finish quality and tool failure.
https://www.harveyperformance.com/wp-content/uploads/2020/02/Feature-Image-High-and-Low-Helix-Angles-IMG.jpg6001599Harvey Performance Companyhttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngHarvey Performance Company2020-02-05 16:07:562021-11-22 11:24:27Benefits & Drawbacks of High and Low Helix Angles
https://www.harveyperformance.com/wp-content/uploads/2017/08/Feature-Image-Uses-of-Chamfer-Mill-IMG.jpg5251400Harvey Performance Companyhttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngHarvey Performance Company2019-11-22 08:20:372021-11-19 08:37:18Selecting the Right Chamfer Cutter Tip Geometry
https://www.harveyperformance.com/wp-content/uploads/2019/10/Feature-Image-Select-Spindle-IMG-3.jpg5251400Ben Holmhttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngBen Holm2019-10-24 13:21:212022-06-08 11:13:34How to Select a Spindle
What is a Thread?
The primary function of a thread is to form a coupling between two different mechanisms. Think of the cap on your water bottle. The cap couples with the top of the bottle in order to create a water tight seal. This coupling can transmit motion and help to obtain mechanical advantages. Below are some important terms to know in order to understand threads.
Crest – This is that surface of a thread which joins the flanks of the thread and is farthest from the cylinder or cone from which the thread projects.
Thread Designations
Metric Thread Designations
M12 x 1.75 – 4h – LH
UN Thread Designations
¾ 10 UNC 2A LH
For this UN Thread Designation, ¾ refers to the thread’s major diameter, where 10 references the number of threads per inch. UNC stands for the thread series; and 2A means the class of thread. The “A” is used to designate external threads, while “B” is for internal threads. For these style threads, there are 6 other classes of fit; 1B, 2B, and 3B for internal threads; and 1A, 2A, and 3A for external threads.
ACME Thread Designations
A 1 025 20-X
How Are Threads Measured?
Thread Milling Considerations
3. Ensure You’re Comfortable With Your Tool Path
Titan USA Threadmill
Just looking at a thread milling tool can be confusing – it is sometimes hard to conceptualize how these tools are able to get the job done. But with proper understanding of call, methods, and best practices, machinists can feel confident when beginning their operation.
