Tag Archive for: helix diameter
February 5, 2020/0 Comments/in Machining Techniques, Tech Tips, Tool Geometry, Tool Selection/by Harvey Performance Company
Helix Angles Rule of Thumb
Slow Helix Tool <40°
Benefits
Drawbacks
High Helix Tool >40°
Benefits
Drawbacks
https://www.harveyperformance.com/wp-content/uploads/2020/02/Feature-Image-High-and-Low-Helix-Angles-IMG.jpg 600 1599 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2020-02-05 16:07:562021-11-22 11:24:27Benefits & Drawbacks of High and Low Helix Angles
November 22, 2019/1 Comment/in CNC Machining, Harvey Tool, Milling, Specialty Tools, Tool Geometry, Tool Information Guides, Tool Selection/by Harvey Performance Company
Harvey Tool Chamfer Cutters
https://www.harveyperformance.com/wp-content/uploads/2017/08/Feature-Image-Uses-of-Chamfer-Mill-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2019-11-22 08:20:372024-02-12 13:58:50Selecting the Right Chamfer Cutter Tip Geometry
April 24, 2018/11 Comments/in Aluminum, CNC Machining, Helical Solutions, Material Specific, Milling, Tech Tips/by Harvey Performance Company
Tool Geometry
2, 3, and 4 flute count for aluminum
Helix Angles
35, 40, and 45 degree helix choices for Aluminum Machining end mills
Tooling Options
helical solutions end mills for aluminum and non-ferrous materials ad
Chipbreaker Tooling
two Chipbreaker Aluminum end mills
High Balance End Mills
Zoomed in image of helical solutions High Balance coolant through Tool for Aluminum
https://www.harveyperformance.com/wp-content/uploads/2018/04/Featured-Image-Attacking-Aluminum-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-04-24 16:00:122024-11-07 16:32:38Attacking Aluminum: a Machining Guide
February 7, 2018/8 Comments/in CNC Machining, Quick Tips, Tech Tips, Trending Now, Troubleshooting Tips/by Harvey Performance Company
Using Traditional Roughing
Using a Long Length of Cut
https://www.harveyperformance.com/wp-content/uploads/2018/02/Featured-Image-Killing-End-Mill-IMG.jpg 393 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-02-07 09:08:092023-10-12 09:59:088 Ways You’re Killing Your End Mill
The Anatomy of an End Mill
December 10, 2017/13 Comments/in CNC Machining, Machining 101, Milling, Tool Geometry, Tool Selection/by Harvey Performance Company
Flutes
end mill flute patterns showing valley size
End Mill Profiles
Square Profile End Mills
Ball Profile End Mills
end mill with arrows showcasing cutter diameter and tool face
Shank Diameter
end mill neck comparison and strength with standard and reduced neck
End Mill Helix Angle
showcase of end mill helix angle compared to core
Pitch
infographic of variable pitch end mill face
https://www.harveyperformance.com/wp-content/uploads/2017/12/Featured-Image-End-Mill-Anatomy-IMG.png 418 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-12-10 18:00:202023-10-24 09:31:29The Anatomy of an End Mill
December 5, 2017/9 Comments/in CNC Machining, Quick Tips, Tech Tips, Titan USA, Troubleshooting Tips/by Harvey Performance Company
https://www.harveyperformance.com/wp-content/uploads/2017/12/Feature-Image-Coolant-for-CNC-Machining-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-12-05 15:09:342022-04-20 16:52:22What You Need to Know About Coolant for CNC Machining
