Locking Depths of Cut
Machining Advisor Pro Mobile
Smoother User Experience
Simplify Your Cutting Tool Orders
With the launch of the new Helical Solutions website, Harvey Performance Company is proud to introduce a new way to order Helical cutting tools. Now, users of our new website are able to send a “shopping cart” of Helical tools they’re interested in directly to their distributor to place an order, or share it with a colleague. Let’s dive into the details about this functionality and learn how you can take advantage of the time savings associated with sending a “shopping cart” to your distributor for simplified ordering.
Get Started with a HelicalTool.com Account
First, you must create an account on HelicalTool.com. Having an account on the Helical website allows you to save and edit “shopping carts,” which can be sent to a distributor to place an order; choose a preferred distributor; auto-fill your information in any important forms; and to manage your shipping information.
Create Helical Account for Helical Shopping Cart
Now that you have an account, it is time to start creating your first “shopping cart.”
Creating a “Shopping Cart”
To begin creating a new shopping cart, simply click on the “My Carts” text in the top right menu. This will take you to the management portal, where you can add a new “shopping cart” by selecting “Create New Shopping Cart.”
Helical Solutions Order
Once complete, you can name your “shopping cart” anything you would like. One example might be creating a collection of tools for each of your jobs, or for different machines in the shop. In this case, we will name it “Aluminum Roughing Job.” You can create as many different “shopping carts” as you would like; they’ll never be removed from your account unless you choose to delete them, allowing you to go back to past tooling orders whenever you’d like.
Helical Solutions Website
Now that you have a “shopping cart” created, it is time to start adding tools to it!
Adding Tools to Your Helical “Shopping Cart”
There are multiple ways to add tooling to your “shopping cart,” but the easiest method is by heading to a product table. In this example, we will be adding tooling from our 3 Flute, Corner Radius – 35° Helix product line. We want to add a quantity of 5 of EDP #59033 to our “shopping cart.” To do this, simply click on the “Add To Cart” icon located in the table row next to pricing and tool descriptions. This will open up a small window where we can manage our selection. The first step will be to choose which “shopping cart” we want to add this tool to, so we will select our “Aluminum Roughing Job” collection.
Helical Online Ordering
Since this tool is offered uncoated and Zplus coated, we need to select which option we would like from the drop down menu. For this example, we will select the Zplus coated tool. Now, we simply need to update our quantity to “5”, and click “Add To Cart.” That tool will now appear in your “shopping cart” in the quantity selected.
If you need more information on a tool, you can click on an EDP number to be brought to the tool details page, where you can also add that EDP to your collection.
If you know the EDP number you need and want to check stock levels, use our Check Stock feature to check quantities on hand, and then add the tools to your “shopping cart” right from the Check Stock page.
Helical Shopping Cart checking stock
Now, it is time to send the “shopping cart” to place an order with your distributor!
Placing An Order With Your Distributor
Once you have completed adding tools to your Helical “shopping cart,” navigate back to the My Carts page to review it. From here, you can update quantities, see list pricing, and access valuable resources.
On the right side of the My Cart screen, you will see an option to “Send to Distributor.” Click on the text to expand the drop down. If you have previously added a preferred distributor from your account page and they are participating in our Shopping Cart Program, you will see their information in this area.
If you have not yet selected a preferred distributor, select “Update My Distributor.” This will bring you to a new page where you can select your state and see all participating distributors in your area. Select one distributor as your preferred distributor, and then head back to the My Cart page.
Now that you have a distributor selected, you can do a final review of the “shopping cart,” and then simply click “Send Cart.” This will send an email order directly to your distributor with all of your shipping information, your list of tools and requested quantities, and your contact information. You will also receive a copy of this email for your records.
Helical Shopping Cart Distributor
Within 1 business day, the distributor will follow up with you to confirm the order, process payment, and get the tools shipped out and on the way to your shop. No more phone calls or emails – just a single click, and your order is in the hands of our distributor partners.
To get started with this exciting new way to shop for Helical cutting tools, click here to begin creating an account on HelicalTool.com!
How to Advance Your Machining Career: 8 Tips From Machining Pros
Since we began shining a light on Harvey Performance Company brand customers via “In the Loupe’s,” Featured Customer posts, more than 20 machinists have been asked to share insight relevant to how they’ve achieved success. Each Featured Customer post includes interesting and useful information on a variety of machining-related subjects, including prototyping ideas, expanding a business, getting into machining, advantages and disadvantages of utilizing different milling machine types, and more. This post compiles 8 useful tips from our Featured Customers on ways to advance your machining career.
Tip 1: Be Persistent – Getting Your Foot in the Door is Half the Battle
With machining technology advancing at the amazing rate that it is, there is no better time to become a machinist. It is a trade that is constantly improving, and offers so many opportunities for young people. Eddie Casanueva of Nueva Precision first got into machining when he was in college, taking a job at an on-campus research center for manufacturing systems to support himself.
“The research center had all the workings of a machine shop,” Eddie said. “There were CNC mills, lathes, injection molding machines, and more. It just looked awesome. I managed to get hired for a job at minimum wage sweeping the shop floor and helping out where I could.
As a curious student, I would ask a million questions… John – an expert machinist – took me under his wing and taught me lots of stuff about machining. I started buying tools and building out my toolbox with him for a while, absorbing everything that I could.”
One of the best things about becoming a machinist is that there is a fairly low entry barrier. Many machinists start working right out of high school, with 12-18 months of on-the-job training or a one to two year apprenticeship. Nearly 70% of the machinist workforce is over the age of 45. The Bureau of Labor Statistics is predicting a 10% increase in the machinist workforce with opportunities for 29,000 additional skilled machinists by 2024, so it is certainly a great time to get your foot in the door.
Tip 2: Keep an Open Mind – If You Can Think of It, You Can Machine It
Being open-minded is crucial to becoming the best machinist you can be. By keeping an open mind, Oklahoma City-based company Okluma’s owner Jeff Sapp has quickly earned a reputation for his product as one of the best built and most reliable flashlights on the market today. Jeff’s idea for Okluma came to him while riding his motorcycle across the country.
“I had purchased what I thought was a nice flashlight for $50 to carry with me on the trip. However, two days in to the trip the flashlight broke. Of course, it was dark and I was in the middle of nowhere trying to work on my bike. I’m happy to pay for good tools, but that wasn’t what happened. Not only was there no warranty for replacement, there was no way to fix it. It was just made to be thrown away. That whole attitude makes me angry. When I got home, I decided I was going to put my new skills to work and design and build my own flashlight, with the goal of never running into an issue like I had on my trip ever again. I started by making one for myself, then four, then twenty. That was four years ago. Now I have my own business with one employee and two dogs, and we stay very busy.”
An awesome side benefit to working as a machinist is that you have all the resources to create anything you can dream of, like Jeff did with Okluma.
machining career
Image courtesy of Okluma.
Tip 3: Be Patient – Take Time to Ensure Your Job is Setup Correctly before Beginning
The setup process is a huge part of machining, but is often overlooked. Alex Madsen, co- owner of M5 Micro in Minnesota, has been working in manufacturing for more than 11 years. Alex is also a part owner of World Fabrication, and owns his own job shop called Madsen Machine and Design. Alex has spent countless hours perfecting his setup to improve his part times.
“It is certainly challenging to use little tools, but the key is to not get discouraged. You should plan on lots of trial and error; breaking tools is just a part of the game. You may buy ten end mills and break six, but once you dial one in it will last the rest of the job.
You should also make sure to put extra time and effort into understanding your machine when working on micromachining jobs. You need to know where there is any backlash or issues with the machine because with a tiny tool, even an extra .0003” cut can mean the end of your tool. When a difference of one tenth can make or break your job, you need to take your time and be extra careful with your machine, tool inspection, and programming before you hit run.”
Tip 4: Effort Pays Off – Long Hours Result in Shop Growth
Success isn’t earned overnight. That is especially true in the machining world. Becoming a good machinist takes a great deal of sacrifice, says Josh from Fleet Machine Co. in Gloucester, MA.
“Opening your own shop involves more than learning how to program and machine. You also need to be willing to sacrifice some of your free time by working long hours to build your business from the ground up. Being a great machinist is important, but you also need to understand the basics of business, and you need to be able to sell your service and maintain a certain level of quality to keep your customers coming back.”
Working hard is a common theme we hear from our featured customers. Brothers Geordan and Nace Roberts of Master Machine Manufacturing have similar advice.
“We often need to work odd hours of the day to maintain the business, but we do it in a way that makes sure we have our family time. There are many times where we will go home, have dinner and hang out with the family, and wait until they are all sleeping to go back to work until two or three a.m. We will get back home later that morning to sleep a little and have breakfast with the family and send them on their way before heading back into the shop.” Starting and growing a business takes time. Every machinist starts from the beginning and through hard work and determination, grows their business.
Liberty Machine cnc mill
Image courtesy of Liberty Machine Inc.
Tip 5: Utilize Tooling from Quality Manufacturers – All Tooling Isn’t Created Equal
When it comes down to it, tooling is singlehandedly the biggest choice you will make as a machinist. Grant Hughson, manufacturing engineer at Weiss Watch Company who works as a manufacturing instructor in his spare time, reflected on the importance of tooling.
“Tool to tool accuracy and performance is vital in this business, especially with our extremely tight tolerances. High quality tools make sure that we get the same performance time after time without needing to scrap parts. This saves us valuable time and money.”
While opting for cheaper tooling can appear to be beneficial when just starting out, before long, machinists are losing time and money because of unpredictability. Jonathan from TL Technologies echoed this point, saying:
“We feel that if we invested so much in these high-end machining centers, it would be criminal to put insufficient tooling and holders into them. We found that by selecting the proper tool with the appropriate sciences behind it we have been able to create products with a cost per cut that is not only competitive, but required to stay current. By keeping the quality as high as possible on the part making side of things, we’ve insured as much ease and reliability into our downstream process as we could. Quality tooling also provides predictability and added safety into the workflow. High-quality carbide tooling is the lifeblood of the business.”
Additional Thoughts Regarding Boosting Your Machining Career With Tooling:
Don’t Cheap Out
  • “The additional cost is always worth the payoff in the end knowing that you have a tool that will produce quality parts and shave valuable minutes off your cycle times. The slightly higher cost of the Harvey/Helical product is small change compared to the long term cost savings associated with their performance” – Seth, Liberty Machine
Consistency is Key
  • “We know the performance we are going to get from the tools is consistent, and we can always rely on getting immaculate finishes. While using the Harvey Tool and Helical product, we can confidently walk away from the machine and come back to a quality finished part every time.” – Bennett, RIT Baja SAE
Superior Specialty Tools
  • “One of the greatest things that I’ve experienced over the past year and a half is flexibility. We’ve asked for some specific tools to be made typically, the lead times that we found were beyond what we needed. We went through the Helical specials division and had them built within a couple of weeks. That was a game changer for us.” – Tom, John Force Racing
“Having high quality tooling like Helical is essential. Helical tools help us maintain a much higher machining efficiency because of the outstanding tool life, while also achieving more aggressive run times. In addition, we are able to consistently keep high tolerances, resulting in a better final product.” – Cameron, Koenig Knives
Tip 6: Get With the Times – Join the Social Media Community
Social media is a valuable tool for machinists. With ever-increasing popularity in networks such as Facebook, LinkedIn, Twitter, and Instagram, there will always be an audience to showcase new and unique products to. We asked a few of our featured customers how they incorporated social media into their machining and the benefits that come along with it.
“A lot of our sales come through Instagram or Facebook, so I would recommend those platforms to anyone who is trying to start a business,” Jeff from Okluma said. “We have also had a lot of success collaborating with others in the community. Typically it is something we couldn’t do ourselves, or they couldn’t do themselves, so we share the labor and collaborate on some really cool items.”
Tip 7: Value Your Customers – Always Put Them First
“In the Loupe’s” featured customers repeatedly emphasized the importance of putting customers first. It’s a simple concept to master, and pays off immensely. Repeat customers tell you that you are doing something right, said Brian Ross, owner of Form Factory.
“We have kept our customers happy and consistently deliver parts on time, so we get a lot of repeat business. Word definitely gets around on how you treat people so we try to treat everyone with respect and honesty which is key to running a good business.” Jeff from Okluma takes great pride in his customer service, saying “we only sell direct to consumers through our website so we can control our lifetime warranty. It has worked really well for us so far, so we have no plans to change that right now. I care more about our customers than any retailer is able to.”
man examining machined part for machining career
Image courtesy of MedTorque.
Tip 8: Never Stop Learning – Ask Questions Whenever You Can
Hopefully some of these tips from our featured customers stuck with you. To leave you with a quote from of Seth Madore, owner of Liberty Machine, “Don’t stop learning. Keep your ears open and your mouth shut,” “That old guy in the shop has likely forgotten more than you will ever learn. The amount of tools in your Kennedy box doesn’t mean you’re a good machinist. Some of the best toolmakers I knew had small boxes with only the common tools. Learn how to excel with limited resources. Ask questions, and own up to your mistakes.”
Aspex CNC – Featured Customer
Featured Image Courtesy of Aspex Cnc
Aspex CNC is a CNC machine shop based out of Poway, California. They offer prototype turning and milling, as well as production level machining. Their quick turnaround times and premium quality have garnered them some serious recognition in the manufacturing industry. Aspex CNC is just one of the four businesses that Gary Colle Jr. currently owns, but they are an essential part of his business ecosystem, creating parts for the other three product-based companies while also offering machining services to outside customers.
We talked to Gary about his unique experiences in the industry, his thoughts on 5 axis machining, his advice for trying High Efficiency Milling, and more!
Tell us a bit about how you got started in machining, your businesses, and how Aspex CNC was formed.
It is a bit of an interesting story. I got started in manufacturing because my father designed, developed, and manufactured one of the first lines of Wheelchair Accessible Vehicle lifts, which allow people in wheelchairs to easily get in and out of their vehicles. The company was called GoldenBoy Mobility and is still one of the four business I currently own and operate today.
At a young age, I was working in my father’s shop, answering phones and doing odd jobs as young as the age of 10. When I got to high school, I worked after school and during the summers in a more hands-on position, welding parts, cutting up cars, and helping on the shop floor. This really inspired my love for metalworking at a young age.
goldenboy mobility
Photo Courtesy of: Aspex CNC
My dad used to let me mess around in the shop at night, so I started welding my own parts and trying to learn as much as I could. One day, someone came in and asked if I could create a “tuna tower” (an accessory for wakeboarding/water skiing) for their boat. I relented at first, but eventually gave in and welded all the parts together for him. After I made that one, word got around that I could create these at night. I started to advertise a little bit locally, and people started ordering more and more. That summer, I ended up making 50 of these towers and got noticed by a couple of big distributors. Scaling up like that made it necessary to outsource some of our parts to local machine shops, which is where I discovered machining. I had very little prior knowledge of machining, but once I stepped into my first machine shop, I was blown away.
As that business grew even larger (now known as DBG Concepts), I needed more parts and needed them faster. We outgrew the local shops and purchased our first machine, a Fadal 4020 CNC Mill, from a local machine salesman, who also helped teach me the ropes. I learned a lot in those first 6 months about machining.
Business kept ramping up, and my father eventually retired and I took over GoldenBoy Mobility. With all the extra parts we needed, we kept machining things in-house, and buying more mills. Eventually, machining became an even larger part of the business than either DBG Concepts or GoldenBoy Mobility, so we formed Aspex CNC to move our machining out of the product line and more into prototype work and production machining for other business. We still machine most of the parts for DBG and GoldenBoy in-house, but we are doing much more for outside sources than we used to.
Right now, we are a Haas-only shop. We currently have eight Haas machines in our shop. Our lineup consists of a couple of lathes (ST10 and ST30), a Super Mini Mill, and five CNC Mills (VF2SS, VF2SSYT, VF4SS, VF5SS, and UMC750SS), with another UMC750 on the way!
aspex cnc
Which materials do you most often work with in your shop?
We work with a lot of the common materials, 6061/7075 Aluminum, 1018/1045 Steel, 303/304/17-4ph Stainless, as well as plastics like Acetal, UHMW, HDPE, and PVC.
How has your experience been with 5 axis machining?
If you don’t keep up with technology, you won’t be able to keep up with business, so learning multi-axis machining was a no-brainer for us. We first started with a Haas HRT210 4th axis rotary, and began to play with that. Over the next two years, we learned everything we could about multi-axis machining and made the decision to upgrade to a 5 axis machine. We actually went to IMTS that year to talk to manufacturers and find the perfect machine for us and ended up sticking with Haas because of their support platform and educational resources.
5 axis can be hard, but there are a lot of tools out there (HSM Works from Autodesk being one) that can help you learn. It does require a little more upfront work and discipline, but it eliminates a lot of setup time, creates new opportunities for our shop, and has been really good for us from a business standpoint. A big part of our business is machining one-off parts, so the 5 axis machine allows for a faster turnaround time for those odd shapes and sizes we come across.
5 axis machining
You are very active on social media promoting your business. How has the online machinist community helped your business?
Honestly, even though it can become a bit of a distraction at times, using social media to share our work and partner up with companies like Harvey Tool and Helical has been a lot of fun. We are still young in the social media space, so we haven’t seen a massive impact yet, but the best is yet to come. We have received a few bites here and there which has led to work, but as with everything, it takes some time. We expect a lot of growth this year as we work on more really neat projects and continue to get our name out there. As we grow, the opportunities are going to come.
aspex cnc
What are some of the coolest projects you have ever worked on?
Unfortunately, we can’t talk about most of the work we do, due to customer confidentiality, but we did just do a project for the State of California building a training vehicle for their driver’s education program. We designed and built a dual steering system that gave the driver’s trainer a second steering wheel on the passenger side of the car to be used during training. Another job we just finished up was some parts for the new Raiders football stadium in Las Vegas. They contacted us in a pinch and needed them in two days, and we made it happen. It is pretty cool to know you played a part in a huge project like that.
Aspex CNC also does a lot of work with racing/off-road vehicle companies, often machining parts for the chassis and suspension components. We have worked on projects for companies like Scarbo Performance, ID Designs, TSCO Racing and a whole list of others.
You can only use one machine for the rest of your life. Do you go with a CNC Milling machine or the Lathe?
I would hate to have to choose between them, but it is 100% the CNC Mill. I love ripping around with end mills and working with the 5 axis machines. It is mind blowing what these things are capable of.
Why is manufacturing products in America important to you?
Growing up in the industry which I did while working under my father (building wheelchair accessible vehicles), we had a lot of customers who were veterans coming back from Vietnam or Desert Storm who had been injured overseas and needed extra accommodations, which we could provide for them. The veterans I have worked with made me so patriotic with their stories and courage. We also get to work on a lot of projects with the US Department of Veteran’s Affairs, which is putting money back into the American economy by supporting companies like ours and contracting us to make these vehicles. It only makes sense that we employ more people here and avoid sending things overseas to support those who have supported us.
aspex cnc
Do you utilize High Efficiency Milling (HEM) techniques in your shop? What advice do you have for those who are getting started with HEM?
Absolutely, all the time!
The biggest thing is listening to your tool manufacturer for recommendations and then cut those in half to start. From there, work your way up until you are comfortable. Just because the tool can handle it doesn’t necessarily mean your machine, work holding and or set up can, so I would advise people to walk before you run when it comes to HEM.
Be conservative and establish good habits from the start. You can get more aggressive as your career starts to take off, but don’t run out and try to run the biggest and baddest machines on day one and try to cut corners. You need to learn what is behind machining; you can get easily lost in all the technology that is available, but you need to understand the core science behind it first. Take it slow, because if you go too fast, you might miss something important along the way.
The best thing is building relationships with companies like Haas, Harvey Tool, and Helical. Not only do they provide great service and support for you, but it quickly becomes a mutually beneficial relationship. As we give feedback to the tool and machine manufacturers, and even our metal supplier, it helps them improve their products, which in turn allows our shop to increase our production and efficiency.
Also, having a good team with good people makes all the difference. No matter how many machines you have and how automated you get, you still need good people on your side. I would put my guys up against any other machine shop out there in terms of skill, and it is a big part of what has made our business so successful.
aspex cnc
Anderson Prototypes – Featured Customer
Featured Image Courtesy of Anderson Prototypes
Anderson Prototypes is a custom machine shop in Port Moody, British Columbia. Working with everything from Titanium to Bamboo, they create mechanical mechanisms and working prototypes of new technology. By applying 25 years of experience with manual and CNC machinery, they craft amazing parts, some even bordering on impossible. The team at Anderson Prototypes works in a variety of industries, ranging from large-scale prototype work to small batch production, machine repair, and even movie and TV props.
Jim Anderson, a 30 year veteran of the manufacturing industry, is the Founder and Owner of Anderson Prototypes. We caught up with Jim and talked to him about some of the “impossible” projects his team likes to take, his experiences in the film industry, and his advice for the aspiring machinist.
I started in machining in 1985, as a full-time student in a machining class at a local community college. I spent years working in jobbing shops, plastic mold injection shops, and specialized start-up companies, scratch building a range of things from high-speed water “pouch” filling machines to hydrogen fuel-cells. Today I work with a wide range of clients including 3 submarine companies, a military contractor, companies that use custom built or modified ROVs and drones, food packaging companies, production companies needing film and TV props, and more.
I have always been an actively creative person, and I enjoyed wood and machine shop in high school. I found a creative outlet for my talents to build and fix things inside the machine shop environment. I continue to study machines and items, to understand how they were made, and how it could be made better or simplified.
anderson prototypes
Photo Courtesy of: Anderson Prototypes
What is your favorite part of this profession?
I always enjoy creating something for a client that they have been dreaming of, sometimes for years. They come to me with a sketch on a napkin or a verbal idea, and I turn that dream into reality. When they come to pick it up and see it for the first time, the emotions are tremendous!
I have 2 Tormach 1100 CNC mills, one 4 axis and the other 3 axis, a Sherline 2000, 4 axis CNC mill, a Frankenstein CNC lathe with a 8 station tool changer for small work, a Milltronics ML-17 CNC lathe, a Colchester Student Engine Lathe, and a smaller manual milling machine. I also have drill presses, tapping heads and tons of specialized fixturing and work holding devices, as well as a 60 ton hydraulic press and the specialized equipment that comes with it.
micro machining
Which materials do you work with in your shop?
Just about everything. Lots of plastics, PEEK, Delrin and Acrylic, aluminum, steels, stainless steels, carbon fiber, different woods, laminates, and more.
What sets Anderson Prototypes apart from the competition?
We often take on jobs that other shops won’t, due to our team’s large vision. We stand behind every piece we make and have zero returned items to date. Embodying both old-school traditions and cutting-edge technology, Anderson Prototypes believes that “Impossible is just an Opinion”. We work with a project from the very beginning to the time it is up and running at the client’s facility. We work with building very small detailed machines to unique and weird items that someone dreamed up and could not find anyone able to make. We also love to give back to the community. We have sponsored local high school and university students in competitions, and we have played a part in the Maker Community since Day One. We also made and donated a doggy wheelchair to a dog in need (YouTube), and we sponsor a local softball league.
How did you get into the entertainment/prop business?
Vancouver has a huge movie industry, and there are many people in my network that work in the industry. The need for various props, new equipment, and repairs can go up and down as movies are being filmed. The first job I did (I think), was for a movie called Space Buddies, the 4th or 5th entry in the Air Bud movie series. I made the Doggles (dog goggles), that the dog is wearing on the DVD cover. Most movies require a Non-Disclosure Agreements before any work is done, so I can’t talk about much, but I have made my impact on the screen, behind the scenes, and even live on stage. I also did a major prop for an Australian TV show that was apparently popular down under, so you never know where this work will take you!
micro machined
Who is the most famous contact that you have worked on a project with?
I have met many directors and producers of large budget films and TV shows. Unfortunately, because of the Non-Disclosure Agreements, I cannot mention any names.
I buy all my tooling from North America. I am lucky enough to have a solid carbide tooling manufacturer 5 miles from my shop, so I get quality endmills, made to order. When I need something specialized, Harvey is the only company I go to. When a tool does more than I expect, I make more money and have less stress. I count on that and become a return customer. For example, I used a .018″ Miniature End Mill (#73018-C3) on some acrylic parts I was making. There were 40 parts in total, all around the size of a stamp, with lots of tiny details, high tolerances, and very small features. I had the machine running at 15,500 RPM for 3 weeks, and I only broke one tool in that entire run. What a great tool!
I really enjoy making something I have never worked on before, that new challenge. Often it seems that I am designing new items now more than ever. I have to do things that are not being done commercially and I stand behind it. So I might run the manual lathe, the CNC mill and then the CNC lathe on one part. I enjoy the variety.
anderson prototypes
Why is manufacturing your products in North America important to you?
American and Canadian-made products are very important to me. I purchase North American-made products like steel and aluminum, and bearings and fasteners all of kinds. I also access services locally, such as laser cutting, anodizing and powder coating, to support these local businesses. I feel its very important to the customer making the purchase that these are products my neighbors are helping to build.
Take the time to take an accredited machine shop training course, like I did. It will give you all the groundwork to understand the real world of machining. I know a few fellas with small CNCs that can’t make a living because they don’t understand the depth of set-ups or work holding, for example, because they never learned from an expert. They can’t make parts fast enough, they charge 1/2 of what I do, and it takes then 3 times as long, so they simply can’t compete with me. Just be aware that it doesn’t happen overnight; I was a Journeyman Machinist for over 30 years, and still ask for help from my mentors occasionally. Oh, and find yourself a quality machine. Find a good used HAAS, or OKK, or something made in the US, UK or Europe. Your clients will respect you more and it will work longer and more accurately.
I am grateful for the education I have received from the many journeyman machinists, engineers, mechanics, electricians, pilots, sea captains and more who I have worked beside in my years. I am happy to share and offer problem-solving, sometimes for free, other times at consultation rates. When a young eager person asks me a question, I do the best I can to answer it in a way that benefits them long term. Sometimes they don’t like the answer, but I tell them to come back in 6 months and tell me how it went. That’s when the rubber hits the road.
anderson prototypes
Photos courtesy of Anderson Prototypes.
Harvey Performance Company Announces Partnership With Summit Partners
ROWLEY, MA (October 17, 2017) – The Harvey Performance Company team is excited to announce a growth equity investment from Summit Partners, a global growth equity investor based in Boston, MA. The funding will be used to foster continued growth, generate ongoing product development, and advance new initiatives.
“This funding will support Harvey Performance Company’s ongoing product innovation efforts, allowing us to sustain our tremendous growth we’ve enjoyed over the last several years,” said Pete Jenkins, Harvey Performance Company Chief Executive Officer. “We’re so appreciative of the Summit team for sharing our vision of growth, and the importance of continued outstanding customer service.”
Founded in 1984, Summit (www.summitpartners.com) has become the investment partner of choice for many of the best growth companies in the world. Its leadership team, averaging more than 13 years of experience, has proven results with aiding businesses reach new, exceptional heights. Summit partners with hundreds of companies, including Uber, NetBrain Technologies, Fuze, and MarketLogic, among others.
Summit’s investment in Harvey Performance Company is its third such partnership in its history. Most recently in 2014, prior to the inception of Harvey Performance Company, The Riverside Company (www.riversidecompany.com) invested in Harvey Tool Company. With its help, Harvey Tool’s acquisition of Helical Solutions and the creation of Harvey Performance Company, was made possible.
“With Riverside’s tremendous partnership over the last three years, we’ve accomplished so much,” Jenkins said. “We can’t wait for more great things to come with Summit.”
Harvey Performance Hosts Local Students for Manufacturing Day Tour
Harvey Performance Company welcomed dozens of local high school students to its Gorham, ME manufacturing facility for an educational tour as part of “Manufacturing Day,” a national day of celebration of modern manufacturing meant to promote, inform, and inspire.
As part of the tour, students were led around the facility by Harvey Performance Company engineers, receiving valuable insight on how a state-of-the-art CNC grinding machine turns a carbide blank into specialty tooling.  The event concluded with a question and answer segment led by Plant Manager Adam Martin.
“It was a thrill for me to meet with the participating students, and to see just how enthusiastic they were about manufacturing,” Martin said. “The Harvey Performance team really had a great time celebrating Manufacturing Day with them.”
harvey performance company
Nationwide, more than 2,800 events took place for current and aspiring machinists as part of Manufacturing Day, held the first week of October every year. In 2016, 84 percent of participants in a Manufacturing Day event were more convinced that manufacturing provides interesting and rewarding careers, according to data from Deloitte and the Manufacturing Institute.
Harvey Performance Company remains committed to its goal of highlighting the best of the manufacturing industry via its “Plunge Into Machining” campaign.
How to Become a Machinist
Machining is one of the fastest growing occupations in the US, with thousands of open positions listed all across various job boards and websites. Because graduating students are more likely to head to college than join the trades, there is currently a major shortage in the workforce for machinists. As the “Baby Boomer” generation inches closer to retirement, this shortage will only continue to grow. According to American Machinist, nearly 70% of the current machinist workforce is over the age of 45, which means there is a great need for younger workers over the next two decades. The Bureau of Labor Statistics (BLS) is predicting a 10% increase in the machinist workforce with opportunities for 29,000 additional skilled machinists by 2024, so it is certainly an exciting time to start thinking about the available career opportunities in the machining industry.
Getting Started
One of the best things about becoming a machinist is that there is a fairly low barrier to entry level positions. Many machinists start working right out of high school, with 12-18 months of on-the-job training or a 1-2 year apprenticeship. This path generally does not require any experience past a high school education, but prospective machinists are encouraged to take math classes including geometry and trigonometry, and participate in metalworking, drafting, and blueprint reading classes if possible. Chris Metayer, a CNC Operator with Helical Solutions, took this same route to begin his career. “I didn’t know anything about machining when I started, but I trained side by side with other employees. I am a hands-on learner, so it was a perfect learning experience for me.” said Metayer. In the end, most of an entry-level machinists’ learning will be done hands-on in the machine shop while getting paid to learn the craft.
machinist
Others may take a two-year machining-based program at a community college or technical school, where they can learn more advanced skills like Computer Numerical Control (CNC) Machining and Computer Aided Design (CAD) or Computer Aided Manufacturing (CAM) programming.  They would then enter the workforce following the completion of an associate’s degree. These machinists tend to earn higher salaries and are more apt to advance to a management role, but they will also need to pay for the costs of their continued education and will still require some hands-on training before they can jump into their new positions. However, there are added benefits to continuing your education. Jake Barnes, another member of the CNC team at Helical, earned his associates degree in Integrated Manufacturing Technology at Southern Maine Community College, and has worked in various departments since joining Helical. Jake started as a manual grinder, then moved to inspection before landing with the CNC team. “I personally recommend going to a trade school” said Barnes, “You will get exposure to many different classes, which opens up new career opportunities across the industry.”
Some machinists who want to work in more advanced industries like aerospace or tech may attend a four-year college and take advanced courses in calculus, physics, and engineering. All of these options are widely accepted in the machining community, so it is more a matter of personal preference and an individual’s specific situation that determine which path to take.
Location Matters
While there are open jobs for machinists all over the country, there are certainly a few areas that would be considered machinist “hot spots.” These areas of the country have increased job openings in the industry and often pay better wages, since machining skills are in higher demand. The Great Lakes Region (Michigan, Ohio, Illinois, Indiana, Upstate New York, Pennsylvania), and the Southeast (The Carolinas, Louisiana, Georgia, Alabama, Mississippi) are great places to look for work, with over 150,000 currently employed machinists. Most of the work in the Great Lakes Region is dominated by the automotive industry, especially in Michigan. In the Southeast US, there has been a recent influx of manufacturing jobs after plants owned by Apple, Boeing, General Electric, Haier, and LeNovo all opened in the area. In fact, Mississippi offers the highest annual salaries for machinists of any state in the country.
Texas, California, and Washington (especially Seattle) are also hot spots for machining jobs. The west coast holds some of the world’s largest aerospace manufacturing plants, so these areas have plenty of job opportunities for machining and manufacturing.
Salary Expectations
A career as a machinist can be rewarding and fun, especially when it comes to working with different materials and creating amazing and intricate parts. But in the end, compensation matters as well. What is often misunderstood most about this industry is that the salary range for machinists is above the national median.
The Bureau of Labor Statistics (BLS) reported in 2016 that those in the workforce with a high school diploma earned an annual median salary of $36,000, while those with an associate’s degree earned $42,000 across all occupations. The BLS also reported the median salaries for machinists in 2016, with median earnings at $43,200, across all levels of education.
The top 10% of machinists earn over $62,500, and depending on what projects they work on, those wages can go even higher. For example, someone working in the aerospace industry or tech industry can expect to make a higher salary as a machinist, but will likely need to have a more extensive education, which can get costly. Experience also matters, as salaries are likely to increase as machinists get more years under their belts. However, many entry level machinist jobs require little to no educational cost and no experience, so the return on investment can be very high once hired into the industry.
Machinist Career Paths
There are quite a few career paths that a machinist can take once they begin working on their craft. Some machinists will work their way up the shop ladder, going from an entry level CNC operator, to a full-on CNC machinist, and possibly finding themselves in a shop management position at some point in their careers. Others may transition away from machining and begin to work with CAD/CAM or CNC Programming applications, working with the machinists on the floor to program and troubleshoot the machines and design new parts to be created. Many machinists also move into careers in inspection, quality control, or production planning, which can be an excellent way to move up the corporate ladder.
machinist
Working in Inspection is a possible career path for a machinist.
Those who do earn an associate’s degree in a machining-based program should consider a path in engineering. The experiences learned as a machinist translate well to this field, and having an associate’s degree allows for the flexibility of going back to school to finish up a Bachelor’s degree in mechanical engineering. For those who may be unable to go to school full-time, there are many online and part-time courses available. These courses make it possible to work full-time or part-time to advance your skills and attain hands-on experience while earning a degree. Both Barnes and Matayer talked about heading back to school to complete an engineering program at some point, taking advantage of the Harvey Performance Company tuition reimbursement program to advance their education and careers.
The skills learned as a machinist also lay a foundation for becoming an entrepreneur or starting a business. Some machinists will open their own machine shops, manufacturing outsourced parts from other companies, while others will take their skills and create a unique product to fulfill a need they identify in the market.
Do Your Research
As the manufacturing industry continues to grow in America, the shortage of machinists in the workforce will become an incredible source of opportunity for our youth. Breaking into the industry now can set young machinists up for great career opportunities. The skills learned as a machinist also translate well to many different jobs, especially in manufacturing and engineering.
machinist
However, not every machine shop should be treated equal. Potential machinists will want to research shops in their area to find the right fit. As Matayer puts it, “Finding the right shop matters. You want to find a place with newer equipment, great benefits, and clean air in a safe environment.” Poor air quality or unsafe working conditions can directly affect a machinist’s long-term health, so doing the proper research before accepting a position can prevent any serious issues.
If you are curious and want to learn more, reach out to your local trade school or college, talk to a machinist, check out some online forums, and read about the profession. You should also check out the machinist community on Instagram, which is full of amazing customer projects, helpful tips and tricks, and videos that will give you a better idea of what is possible in this field! Machinists are always more than happy to share their experiences, but the biggest thing you can do is try. Get out there, start creating, and see where it takes you – the possibilities are endless!
