How to Select a Spindle
properly selecting a spindle
multi-form threadmill in holder
What is a Thread?
thread milling
Thread Designations
Metric Thread Designations
M12 x 1.75 – 4h – LH
UN Thread Designations
¾ 10 UNC 2A LH
ACME Thread Designations
A 1 025 20-X
How Are Threads Measured?
Thread Milling Considerations
There is no substitute for adequate tooling. To avoid tool failure and machining mishaps, opt for a quality manufacturer for High Performance Drills for your starter holes, as well as for your thread milling solutions. Harvey Tool fully stocks several types of threadmills, including Single Form, Tri-Form, and Multi-Form Thread Milling Cutters. In addition, the 60° Double Angle Shank Cutter can be used for thread milling.
thread milling
Image Courtesy of  @Avantmfg
3. Ensure You’re Comfortable With Your Tool Path
Just looking at a thread milling tool can be confusing – it is sometimes hard to conceptualize how these tools are able to get the job done. But with proper understanding of call, methods, and best practices, machinists can feel confident when beginning their operation.
Three Key Benefits
Indexing
Increased Feed Rates
Better Part Finish
Opt for a Smoother Operation
What are Pecking Cycles?
Rather than drill to full drill depth in one single plunge, pecking cycles involve several passes – a little at a time. Pecking aids the chip evacuation process, helps support tool accuracy while minimizing walking, prevents chip packing and breakage, and results in a better all around final part.
aluminum pecking cycles
hardened steels chart
prehardened steels chart
From the above tables, it’s easy to identify how recommended  cycles change based on the properties of the material being machined. Unsurprisingly, the harder the material is, the shorter the recommended pecking depths are. As always, miniature drills with a diameter of less than .010″ are extremely fragile and require special precautions to avoid immediate failure. For help with your specific job, contact the Harvey Tool Technical Team at 800-645-5609 or [email protected]
multiaxis machining
Using Traditional Roughing
high efficiency milling
tool holding
variable helix
end mill coatings
Using a Long Length of Cut
flute count for tool life
The Anatomy of an End Mill
Flutes
end mill flute patterns
End Mill Profiles
Square Profile End Mills
Ball Profile End Mills
end mill cutter diameter
Shank Diameter
end mill neck
End Mill Helix Angle
helix angle
Pitch
variable pitch
