High Efficiency Milling for Titanium Made Easy With Helical’s New HVTI Cutter
Titanium is a notoriously difficult material to machine, especially in aggressive toolpaths, such as those associated with High Efficiency Milling (HEM). Helical Solutions’ new line of tooling, the HVTI-6 series of end mills, is optimized specifically for this purpose, and proven to provide 20% more tool life than a competitor’s similar tool.
At face level, these new Helical end mills feature corner radius geometry, 6 flutes, and are Aplus coated for optimal tool life and increased cutting performance. But there is much more to these end mills than the typical geometry of standard 6 flute tools. The HVTI-6 was designed with a combination of a unique rake, core, and edge design that give it a leg up over standard 6 flute tools for Titanium while cutting HEM toolpaths. Click here to watch the HVTI-6 in action!
End Mills for Titanium
Helical HVTI Titanium
WATCH THE HVTI IN ACTION
In these tests, the HVTI was able to run HEM toolpaths at 400 SFM and 120 IPM in Ti6Al4V, which served as the baseline for most of the testing.
