Tag Archive for: machining formula
John Force Racing – Featured Customer
John Force Racing has been dominating the motorsports world for over 30 years, winning 20 championships and hundreds of races in the National Hot Rod Association (NHRA) drag racing series. John Force Racing features both Funny Car and Top Fuel teams, and just recently in 2017 they won both the Funny Car and Top Fuel championships in the same season.
John Force Racing invested in Force American Made to develop and create parts and components that would help drive all the teams to success and safety. The 84,000 square foot shop is located in Brownsburg, Indiana (just outside of Indianapolis) and is the heartbeat of John Force Racing. Thousands of parts are forged by Force American Made and its team of employees every season giving the team a competitive edge that has led to the team’s on-track success.
The Force American Made team has relied on Helical Solutions tooling to get the best performance and quality out of their CNC mills for years. The Harvey Performance Company team was invited out to Indiana to take a tour of Force American Made and spend some time with Tom Warga, Lead Machinist, to talk with him about his experiences with Helical Solutions tooling, his first time trying Machining Advisor Pro, the success they have had using the new Helical tool libraries for Mastercam, and the value their distributor, Dolen Tool, brings to the shop. Check out the video interview below to see the inner-workings of Force American Made and how Helical Solutions tooling has contributed to the success of this motorsports dynasty.
Downloading Tool Libraries
Selecting a Tool
Searching by Tool Number
Fusion 360 Tool Libraries
Harvey Tool Tool Libraries
Searching by Keyword
Searching by Tool Type
CAM Tool Libraries
Searching by Tool Dimensions
CAM Tool Libraries
Using Specialty Profile Tools
Tool NameFusion 360 Name
Back Chamfer CutterDovetail Mill
Chamfer CuttersChamfer Mill
Corner Rounding End Mill – UnflaredRadius Mill
Dovetail CutterDovetail Mill
Drill/End MillSpot Drill
Engraving Cutter/Marking Cutter – Tip RadiusTapered Mill
Engraving Cutter – Tipped Off & PointedChamfer Mill
Keyseat CutterSlot Mill
Runner CutterTapered Mill
Undercutting End MillLollipop Mill
All Other Specialty ProfilesForm Mill
Speeds and Feeds
Harvey Tool Speeds & Feeds
To access speeds and feeds information for your Harvey Tool product, head to http://www.harveytool.com/cms/SpeedsFeeds_228.aspx to find speeds and feeds libraries for every tool.
If you have further questions about speeds and feeds, please reach out to our Technical Support team. They can be reached Monday-Friday from 8 AM to 7 PM EST at 800-645-5609, or by email at [email protected].
To access speeds and feeds information for your Helical Solutions end mills, we recommend using our Machining Advisor Pro application. Machining Advisor Pro (MAP) generates specialized machining parameters by pairing the unique geometries of your Helical Solutions end mill with your exact tool path, material, and machine setup. MAP is available free of charge as a web-based desktop app, or as a downloadable application on the App Store for iOS and Google Play.
To learn more about Machining Advisor Pro and get started today, visit www.machiningadvisorpro.com. If you have any questions about MAP, please reach out to us at [email protected].
If you have further questions about speeds and feeds, please reach out to our Technical Support team. They can be reached Monday-Friday from 8 AM to 7 PM EST at 866-543-5422, or by email at [email protected].
For additional questions or help using tool libraries, please send an email to [email protected]. If you would like to request a Harvey Performance Company tool library be added to your CAM package, please fill out the form here and let us know! We will be sure to notify you when your CAM package has available tool libraries.
machining advisor pro mobile
Deflection Can Result In:
  • Subpar surface finish
Tool Deflection Remedies
Minimize Overhang
extended reach tool
Image Source: @NuevaPrecision
Long Flute vs. Long Reach
tool deflection
tool deflection graph
long reach end mill
Long Reach Tool: Variable Helix End Mills for Exotic Alloys – Ball – Long Reach, Stub Flute
long flute tool
core diameter vs neck diameter
Deflection Summarized
Tool Geometry
flute count for aluminum
Helix Angles
Aluminum Machining end mill helix choices
Tooling Options
Chipbreaker Tooling
Chipbreaker Aluminum
High Balance End Mills
Recent  Advances
Increased Time Savings
Reduced Cycle Times
Improved Consistency
CNC Contouring planes
CNC Contouring ball end mill
Click Here to Download the High Efficiency Milling (HEM) Guidebook
Calculating MRR
Optimizing Efficiency
Axial Depth of CutRadial Depth of CutFeed RateMaterial Removal Rate
 .125″ .200″19.5 IPM .488 in.³/min.
.250″.150″26.2 IPM.983 in.³/min.
.500″.100″41.5 IPM2.08 in.³/min.
.750″.050″89.2 IPM3.35 in.³/min.
1.00″.025″193 IPM4.83 in.³/min.
High Efficiency Milling Material Removal Rate
Speeds and Feeds 101
HEM Guidebook Ad
speeds and feeds formula
speeds and feeds
Speeds and Feeds In Practice
hardness chart
speeds and feeds
Earn an Immediate Boost to Shop Efficiency: Download the HEM Guidebook Today
Spindle Speed Cap
Effective Cutter Diameter
cutter diameter calculation
Non-linear Path
non-linear path
adjusted internal feed
adjusted external feed
Built-In CAM Applications
Importance of Tooling to HEM
Best Tools for HEM:
Multi-Start Thread Reference Guide
A multi-start thread consists of two or more intertwined threads running parallel to one another. Intertwining threads allow the lead distance of a thread to be increased without changing its pitch. A double start thread will have a lead distance double that of a single start thread of the same pitch, a triple start thread will have a lead distance three times longer than a single start thread of the same pitch, and so on.
Shop Harvey Tool’s Comprehensive Offering of Fully Stocked Threadmills
By maintaining a constant pitch, the depth of the thread, measured from crest to root, will also remain constant. This allows multi-start threads to maintain a shallow thread depth relative to their longer lead distance. Another design advantage of a multi-start thread is that more contact surface is engaged in a single thread rotation. A common example is a cap on a plastic water bottle. The cap will screw on in one quick turn but because a multi start thread was used there are multiple threads fully engaged to securely hold the cap in place.
multi-start thread
Figure 1 displays a triple start thread with each thread represented in a different shade. The left side of the image represents a triple start thread with just one of the three threads completed. This unfinished view shows how each individual thread is milled at a specific lead distance before the part is indexed and the remaining threads are milled. The right side of the image displays the completed triple start thread with the front view showing how the start of each thread is evenly spaced. The starting points of a double start thread begin 180° apart and the starting points of a triple start thread begin 120° apart.
multi-start thread
Figure 2 displays the triangle that can be formed using the relationship between the lead distance and the circumference of a thread. It is this relationship that determines the lead angle of a thread. The lead angle is the helix angle of the thread based on the lead distance. A single start thread has a lead distance equal to its pitch and in turn has a relatively small lead angle. Multi-start threads have a longer lead distance and therefore a larger lead angle. The graphic depicted on the right is a view of the lead triangle if it were to be unwound to better visualize this lead angle. The dashed lines represent the lead angle of a single start thread and double start thread of the same pitch and circumference for comparison. The colors represent each of the three intertwined threads of the triple start thread depicted in Figure 1.
Lead Angle Formula
multi-start thread lead angle formula
The charts below display the information for all common UN/Metric threads as well as the lead and lead angle for double and triple start versions of each thread. The lead angle represented in the chart is a function of a thread’s lead and major diameter as seen in the equation above. It is important to be aware of this lead angle when manufacturing a multi-start thread. The cutting tool used to mill the thread must have a relief angle greater than the lead angle of the thread for clearance purposes. All Harvey Tool Single Form Thread Milling Cutters can mill a single, double, and triple start thread without interference.
Machining a Multi-Start Thread
  1. Use the table or equation to determine the pitch, lead, and lead angle of the multi-start thread.
  2. Use a single form thread mill to helically interpolate the first thread at the correct lead. *The thread mill used must have a relief angle greater than that of the multi-start thread’s lead angle in order to machine the thread.
  3. Index to the next starting location and mill the remaining parallel thread/threads.
Click here for the full chart – starting on Page 2.
multi-start thread chart
