Tag Archive for: metal removal rate
February 5, 2020/0 Comments/in Machining Techniques, Tech Tips, Tool Geometry, Tool Selection/by Harvey Performance Company
Helix Angles Rule of Thumb
Slow Helix Tool <40°
Benefits
Drawbacks
High Helix Tool >40°
Benefits
Drawbacks
https://www.harveyperformance.com/wp-content/uploads/2020/02/Feature-Image-High-and-Low-Helix-Angles-IMG.jpg 600 1599 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2020-02-05 16:07:562021-11-22 11:24:27Benefits & Drawbacks of High and Low Helix Angles
Axis CNC Inc. – Featured Customer
December 16, 2019/0 Comments/in Featured Customer/by Guy Petrillo
Featured Image Courtesy of Axis CNC Inc
Axis CNC Inc was founded in 2012 in Ware, Massachusetts, when Dan and Glenn Larzus, a father and son duo, decided to venture into the manufacturing industry. Axis CNC Inc has provided customers with the highest quality manufacturing, machining, and programming services since they’ve opened. They specialize in manufacturing medical equipment and have a passion for making snowmobile parts.
We sat down with Axis CNC Inc to discuss how they got started and what they have learned over there years in the manufacturing world. Watch our video below to see our full interview.
https://www.harveyperformance.com/wp-content/uploads/2019/12/Axis-CNC-1-1.jpg 435 1013 Guy Petrillo http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Guy Petrillo2019-12-16 17:00:192021-08-27 09:31:58Axis CNC Inc. – Featured Customer
September 19, 2018/0 Comments/in CNC Machining, Tool Information Guides, Tool Selection/by Harvey Performance Company
face of a staggered tooth keyseat cutter
Three Key Benefits
Indexing
Increased Feed Rates
Better Part Finish
staggered tooth keyseat cutter working in a cnc machine
Opt for a Smoother Operation
https://www.harveyperformance.com/wp-content/uploads/2018/09/Featured-Image-Benefits-of-Staggered-Tooth-Keyseats-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-09-19 10:35:552023-10-24 10:45:04Experience the Benefits of Staggered Tooth Keyseats
September 13, 2018/2 Comments/in CNC Machining, CNC Programming, Machining 101, Machining Advisor Pro Help, Quick Tips/by David Pichette
machining advisor pro mobile
https://www.harveyperformance.com/wp-content/uploads/2018/09/machiningadvisorpro.jpg 600 1599 David Pichette http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png David Pichette2018-09-13 14:20:202024-02-09 10:27:36Get to Know Machining Advisor Pro
August 23, 2018/0 Comments/in Featured Customer/by Harvey Performance Company
B&R Custom machining
aerospace machining
B&R custom machining
https://www.harveyperformance.com/wp-content/uploads/2018/08/Featured-Image-BR-Customer-Machining-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-08-23 09:30:262021-08-20 14:02:02B&R Custom Machining- Featured Customer
August 20, 2018/1 Comment/in CNC Machining, Helical Solutions, High Efficiency Milling, How-To's, Machining Techniques, Tool Selection/by Harvey Performance Company
infographic showcasing all aspects axii for high balance machining
cnc high balance end mills in both 2 and 3 flute designs
  • Longer tool life
  • Longer spindle lifetime
  • Reduced machine down time
Utilizing Tap Testers
What Tap Testers Do
How Tap Testing Works
how to properly tap test a cnc tool
https://www.harveyperformance.com/wp-content/uploads/2018/08/Featured-Image-Maximize-High-Balance-End-Mills-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-08-20 14:08:412023-10-24 10:46:29How to Maximize High Balance End Mills
April 24, 2018/11 Comments/in Aluminum, CNC Machining, Helical Solutions, Material Specific, Milling, Tech Tips/by Harvey Performance Company
Tool Geometry
2, 3, and 4 flute count for aluminum
Helix Angles
35, 40, and 45 degree helix choices for Aluminum Machining end mills
Tooling Options
helical solutions end mills for aluminum and non-ferrous materials ad
Chipbreaker Tooling
two Chipbreaker Aluminum end mills
Zoomed in image of helical solutions High Balance coolant through Tool for Aluminum
https://www.harveyperformance.com/wp-content/uploads/2018/04/Featured-Image-Attacking-Aluminum-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-04-24 16:00:122024-11-07 16:32:38Attacking Aluminum: a Machining Guide
February 19, 2018/3 Comments/in CNC Machining, CNC Machining Videos, CNC Programming, Machining 101, Machining Techniques, Tools In Action/by Jacob Concepcion
infographic showing x, y and z axii
https://www.harveyperformance.com/wp-content/uploads/2018/02/Featured-Image-Multiaxis-Machining-IMG.jpg 525 1400 Jacob Concepcion http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Jacob Concepcion2018-02-19 11:45:102023-10-12 14:31:04The Advances of Multiaxis Machining
