Tag Archive for: milling advisor
machining advisor pro mobile
B&R Custom machining
aerospace machining
B&R custom machining
Introducing Machining Advisor Pro
ROWLEY, MA (February 1, 2018) – Harvey Performance Company is proud to announce the release of Machining Advisor Pro (MAP), a tool designed to quickly, seamlessly, and accurately deliver recommended running parameters to machinists using Helical Solutions end mills. This web-based tool works within the capability of a machinists’ machine, tool, and set-up to offer tailored, specific speeds and feed parameters.
MAP is the new and improved version of the Helical Milling Advisor. In style, simplicity, and ease of access, Machining Advisor Pro delivers what the previous tool lacked. Harvey Performance Company engineers have worked for several months to develop a better product – a unique tool that the machining industry could fully rely on.
Machining Advisor Pro (MAP) Highlights
  • New and improved interface for stylistic simplicity and user interaction
  • Works within the capability of a machine, tool, and set-up
  • Optimized for Helical Solutions end mills
  • Provides a PDF summary of recommended parameters to print or save for later use
“This type of tool has the potential to change our customers’ way of life,” said Harvey Performance Company Senior Vice President of Sales Jerry Gleisner. “Our first goal has long been to make our customers more profitable. Feeling confident in your machining parameters, and getting those parameters quickly, is paramount for shop success.”
To get started, please visit www.machiningadvisorpro.com.
http://www.helicaltool.com/cms/MachiningAdvisorPro_415.aspx
