harvey tool slitting saw
  2. Undercutting Applications
  3. Slotting into Material
Tool Deflection & its Remedies
Deflection Can Result In:
  • Subpar surface finish
Tool Deflection Remedies
Minimize Overhang
extended reach tool
Image Source: @NuevaPrecision
Long Flute vs. Long Reach
tool deflection
tool deflection graph
core diameter vs neck diameter
Deflection Summarized
Among Harvey Tool’s expansive holemaking solutions product offering are several different types of miniature tooling options and their complements. Options range from Miniature Spotting Drills to Miniature High Performance Drills – Deep Hole – Coolant Through. But which tools are appropriate for the hole you aim to leave in your part? Which tool might your current carousel be missing, leaving efficiency and performance behind? Understanding how to properly fill your tool repertoire for your desired holemaking result is the first step toward achieving success.
multiaxis machining
The Anatomy of an End Mill
Flutes
end mill flute patterns
Profiles
Square Profile End Mills
Ball Profile End Mills
end mill cutter diameter
Shank Diameter
end mill neck
Helix Angle
helix angle
Pitch
variable pitch
