    • ITC
Tag Archive for: premature tool failure
February 13, 2020/4 Comments/in Helical Solutions, Machining 101, Tool Geometry, Tool Information Guides, Tool Selection/by Alexander Bean
helical solutions high feed end mills ad with both solid round and coolant through options
https://www.harveyperformance.com/wp-content/uploads/2020/02/Feature-Image-5-Things-High-Feed-EMs-IMG-Copy-2.jpg 525 1400 Alexander Bean http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Alexander Bean2020-02-13 15:25:162023-10-05 09:01:485 Things to Know About Helical’s High Feed End Mills
September 13, 2018/2 Comments/in CNC Machining, CNC Programming, Machining 101, Machining Advisor Pro Help, Quick Tips/by David Pichette
machining advisor pro mobile
https://www.harveyperformance.com/wp-content/uploads/2018/09/machiningadvisorpro.jpg 600 1599 David Pichette http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png David Pichette2018-09-13 14:20:202024-02-09 10:27:36Get to Know Machining Advisor Pro
May 3, 2018/6 Comments/in CNC Machining, How-To's, Machining 101, Troubleshooting Tips/by Jacob Concepcion
What is Tool Deflection?
Signs of Tool Deflection
  • Subpar surface finish
Tool Deflection Remedies
Minimize Overhang
extended reach tool in tool holder with overhang depth called out
Image Source: @NuevaPrecision
Long Flute vs. Long Reach
tool deflection in relation to length of tool
tool deflection graph
long reach ball end mill
Long Reach Tool: Variable Helix End Mills for Exotic Alloys – Ball – Long Reach, Stub Flute
long flute end milling tool
core diameter vs neck diameter infographic
Deflection Summarized
https://www.harveyperformance.com/wp-content/uploads/2018/05/Featured-Image-Tool-Deflection-IMG.jpg 525 1400 Jacob Concepcion http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Jacob Concepcion2018-05-03 09:42:392024-03-05 16:25:18Tool Deflection & Its Remedies
February 7, 2018/8 Comments/in CNC Machining, Quick Tips, Tech Tips, Trending Now, Troubleshooting Tips/by Harvey Performance Company
Using Traditional Roughing
Using a Long Length of Cut
https://www.harveyperformance.com/wp-content/uploads/2018/02/Featured-Image-Killing-End-Mill-IMG.jpg 393 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-02-07 09:08:092023-10-12 09:59:088 Ways You’re Killing Your End Mill
December 5, 2017/9 Comments/in CNC Machining, Quick Tips, Tech Tips, Titan USA, Troubleshooting Tips/by Harvey Performance Company
https://www.harveyperformance.com/wp-content/uploads/2017/12/Feature-Image-Coolant-for-CNC-Machining-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-12-05 15:09:342022-04-20 16:52:22What You Need to Know About Coolant for CNC Machining
July 17, 2017/6 Comments/in CNC Machining, CNC Programming, Holemaking, Machining 101, Machining Techniques, Milling, Tech Tips/by Harvey Performance Company
Pre-Drilled Hole
Pre-drilling a hole to full pocket depth (and 5-10% larger than the end mill diameter) is the safest practice of dropping your end mill into a pocket. This method ensures the least amount of end work abuse and premature tool wear. It also facilitates smoother chip evacuation, reducing the risk of chip buildup and potential tool breakage. Machinists often use this technique when working with materials prone to chip welding or built-up edge formation, ensuring consistent machining performance.
tool entry predrill
Helical Interpolation
Helical Interpolation is a very common and safe practice of tool entry with ferrous materials. Employing corner radius end mills during this operation will decrease tool wear and lessen corner breakdown. With this method, use a programmed helix diameter of greater than 110-120% of the cutter diameter. Moreover, helical interpolation offers advantages in achieving precise surface finishes, making it a preferred choice for applications requiring high precision and surface quality, such as aerospace and medical device manufacturing.
Ramping-In
This type of operation can be very successful, but institutes many different torsional forces the cutter must withstand. A strong core is key for this method, as is room for proper chip evacuation. Using tools with a corner radius, which strengthen its cutting portion, will help. Additionally, ramping-in allows for efficient material removal with reduced axial forces, minimizing workpiece distortion and enhancing dimensional accuracy. Machinists often employ this technique in contouring and pocketing operations, where maintaining part integrity is crucial.
ramping
Hard/Ferrous Materials: 1°-3°
This method of tool entry is similar to ramping in both method and benefit. However, while ramping enters the part from the top, arcing does so from the side. The end mill follows a curved tool path, or arc, when milling, this gradually increasing the load on the tool as it enters the part. Additionally, the load put on the tool decreases as it exits the part, helping to avoid shock loading and tool breakage. Machinists often utilize this technique in mold making, die sinking, and 3D contouring operations, enhancing productivity and surface finish quality.
arching with end mill
Straight Plunge
tool entry
Straight Tool Entry
Straight entry into the part takes a toll on the cutter, as does a straight plunge. Until the cutter is fully engaged, the feed rate upon entry is recommended to be reduced by at least 50% during this operation. Machinists often resort to straight tool entry in simple machining operations with limited tool access or where other entry methods are impractical. However, it’s crucial to monitor tool wear and chip evacuation carefully to prevent chip buildup and potential tool breakage. Adjusting cutting parameters based on material properties and part geometry can further enhance machining efficiency and tool life.
tool entry
Roll-In Tool Entry
Rolling into the cut ensures a cutter to work its way to full engagement and naturally acquire proper chip thickness. The feed rate in this scenario should be reduced by 50%. Roll-in tool entry is particularly advantageous in slotting and profiling operations, where maintaining consistent chip thickness is critical for surface finish quality and dimensional accuracy. Machinists often utilize this technique in high-speed machining applications, maximizing material removal rates while minimizing tool wear and heat generation.
tool entry
Mastering various tool entry techniques is essential for machining success. By understanding and implementing these methods effectively, machinists can optimize performance while prolonging the lifespan of their tools. Continual evaluation of cutting conditions and adaptation of entry strategies based on material properties and part geometry are key to achieving superior machining results.
https://www.harveyperformance.com/wp-content/uploads/2017/07/Feature-Image-Tool-Entry-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-07-17 14:53:062024-03-20 11:54:31Most Common Methods of Tool Entry
How to Avoid 4 Major Types of Tool Wear
July 11, 2017/10 Comments/in High Efficiency Milling, How-To's, Milling, Quick Tips, Troubleshooting Tips/by Harvey Performance Company
What Is Tool Wear?
two close up images comparing an end mill with no tool wear and another with excessive tool wear
end mill with excessive tool wear on cutting edge
To prolong tool life, identifying and mitigating the various signs of cutting tool wear is key. Both thermal and mechanical stresses cause tool wear, with heat and abrasion being the major culprits. Learning how to identify the most common types of tool wear and what causes them can help machinists remedy issues quickly and extend tool longevity.
Types of Tool Wear And Their Solutions
Abrasive Wear
Utilizing Proper Tool Coatings
Using a tool coating with a high microhardness rating is crucial to avoiding abrasive wear. Microhardness ratings help determine a cutting tool’s level of wear resistance. For example, bare tungsten carbide has a Vickers Hardness (HV) ranging from 760 HV to 1740 HV while coatings such as TiN have an HV of 2213 or more. Despite facing maximum forces during cutting operations, the addition of coating on a tool significantly improves its ease of material removal due to higher hardness. When hardness in a coating is elevated wear is mitigated due to the stack up.
end mill with abrasive wear on cutting edge
Coolant Usage
If the wear land becomes excessive or causes premature tool failure, reducing the cutting speed and optimizing coolant usage can help. Coolant is directed towards the cutting action of a tool during CNC operations. It prevents tool failure by countering high temperatures. Generally machinists opt for either Flood or High Pressure coolant methods. Flooding allows for low pressure chip flushing by providing lubricity. High Pressure coolant provides almost instant cooling of a part and works to evacuate chips at a faster rate. Both methods improve part finish and minimize chip recutting, which can damage a cutting tool.
High Efficiency Milling (HEM) toolpaths can help reduce wear by spreading the work done by the tool over its entire length of cut. This prevents localized wear and will prolong tool life by using the entire cutting edge available. The image referenced below compares traditional (standard) milling and the newer HEM method. HEM evenly disperses heat across the cutting edge by employing a lower radial depth of cut (RDOC) and a higher axial depth of cut (ADOC). This reduces the likelihood of tool failure and lengthens the tool wear process.
infographic with two end mills comparing the difference between standard milling and high efficiency milling at the workpiece
Chipping
Chipping can be easily identified by a nicked or flaked edge on the cutting tool, or by examining the surface finish of a part. A poor surface finish can often indicate that a tool has experienced some sort of chipping, which can lead to eventual catastrophic tool failure if it is not caught. \When a chipped tool engages with a workpiece the cutting edges are not even leading to high and low spots within the surface finish.
end mill with chipping tool wear
Chipping is typically caused by excessive loads and shock-loading during operation, but it can also be caused by thermal cracking, another type of tool wear which is explored in further detail below.
Reduce Chatter
To counter chipping, ensure the milling operation is completely free of vibration and chatter. Chatter occurs because cutting tools experience high forces during CNC machining operations. While machinists cannot entirely avoid chatter, minimizing it prevents vibration marks and excess wear from appearing along the surface of a tool or part. Taking a look at the speeds and feeds can also help. Interrupted cuts and repeated part entry can also have a negative impact on a tool. Reducing feed rates for these situations can mitigate the risk of chipping.
Thermal Cracking
end mill thermal cracking
Thermal cracking, as its name suggests, is caused by extreme temperature fluctuations during milling. Adding a proper coating to an end mill is beneficial in providing heat resistance and reduced abrasion on a tool.
HEM Toolpaths
HEM toolpaths provide excellent protection against thermal cracking. As previously mentioned, these toolpaths spread the heat across the cutting edge of the tool, reducing the overall temperature and preventing serious fluctuations in heat.
Harvey HEM guidebook ad
Fracture
Fracture is the complete loss of tool usage due to sudden breakage, often as a result of improper speeds and feeds, an incorrect coating, or an inappropriate depth of cut.
Optimal Tool Holding
Tool holder issues or loose work holding can also cause a fracture, as can inconsistencies in workpiece material properties. Establishing a secure connection between the tool and machine reduces the risk of tool runout and scrapped parts. Machinists generally experience improved performance in hydraulic and shrink fit tool holders compared to more mechanical tightening methods.
broken end mill in two pieces from excessive tool wear
Appropriate Depth of Cut
Adjusting the speeds, feeds, and depth of cut and checking the setup for rigidity will help to reduce fracturing. The tool’s axial engagement with a part must be appropriate in order to prevent tool deflection, especially during slotting operations. As pictured below, with increasing slot lengths comes the necessity for longer lengths of cut. Above all, you should choose a tool that offers the highest productivity and least amount of deflection.
drawing of three end mills and their axial depth of cut during cnc slotting operations
Optimizing coolant usage can also be helpful to avoid hot spots in materials which can dull a cutting edge and cause a fracture. HEM toolpaths prevent fracture by offering a more consistent load on a tool. Shock loading is reduced, causing less stress on a tool, which lessens the likelihood of breakage and increases tool life.
https://www.harveyperformance.com/wp-content/uploads/2017/07/Feature-Image-Tool-Wear-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-07-11 16:30:432023-11-17 14:56:39How to Avoid 4 Major Types of Tool Wear
Ramping to Success
May 10, 2017/1 Comment/in CNC Machining, CNC Programming, Machining Techniques, Milling, Tech Tips/by Harvey Performance Company
illustrated end mill ramping into part
Check Out Our Micromachining Webinar to Get More Life Out of Your Miniature Cutting Tools
What is Ramping?
circular and linear ramping
Benefits of Ramping
illustration of end mill arcing tool entry
https://www.harveyperformance.com/wp-content/uploads/2017/05/Featured-Image-Ramping-to-Success-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-05-10 09:00:392023-10-12 08:24:58Ramping to Success
