The Anatomy of an End Mill
Flutes
End Mill Profiles
Square Profile End Mills
Ball Profile End Mills
Shank Diameter
The overall reach of an end mill, or length below shank (LBS), is a dimension that describes the necked length of reached tools. It is measured from the start of the necked portion to the bottom of the cutting end of the tool. The neck relief allows space for chip evacuation and prevents the shank from rubbing in deep-pocket milling applications. This is illustrated in the photo below of a tool with a reduced neck.
End Mill Helix Angle
Pitch
