A High Feed End Mill is designed to take a large radial depth of cut (65% to 100% of the cutter diameter) with a small axial depth of cut (2.5% to 5% diameter) depending on the application. This makes High Feed End Mills perfect for face milling, roughing, slotting, deep pocketing, and 3D milling. Where HEM toolpaths involve light radial depths of cut and heavy axial depths of cut, High Feed End Mills utilize high radial depths of cut and smaller axial depths of cut.
The end profile of a High Feed End Mill is designed to direct cutting forces upward along the axis of the tool and into the spindle. This reduces radial cutting forces which cause deflection, allowing for longer reach tools while reducing chatter and other issues that may otherwise lead to tool failure. The reduction of radial cutting forces makes this tool excellent for use in machines with lower horsepower, and in thin wall machining applications.
The design and short length of cut of High Feed End Mills work in tandem with the end geometry to produce a tool with a strong core, further limiting deflection and allowing for tools with greater reach lengths.
In high RDOC, low ADOC applications, High Feed End Mills can be pushed significantly faster than traditional end mills, saving time and money over the life of the tool.
In summary, High Feed End Mill tools with specialized end geometry that utilizes chip thinning and light axial depths of cut to allow for significantly increased feed rates in face milling, slotting, roughing, deep pocket milling, and 3D milling applications. The end profile of a High Feed End Mill applies cutting forces back up into the spindle, reducing radial forces that lead to deflection in long reach applications. Combining this end geometry with a stubby length of cut results in a tool that is incredibly rigid and well suited for harder, difficult to machine materials.
https://www.harveyperformance.com/wp-content/uploads/2020/02/High-Feed-Mills-Featured-1.png4351155Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2020-02-13 15:25:162021-03-01 11:29:485 Things to Know About Helical’s High Feed End Mills
Locking Depths of Cut
Smoother User Experience
If you have any feedback or questions about MAP, please contact Harvey Performance Company at [email protected].
https://www.harveyperformance.com/wp-content/uploads/2020/01/MAP-1.5-Featured.jpg6001599Jeff Rauseohttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngJeff Rauseo2020-01-30 10:55:552021-02-25 08:22:59Machining Advisor Pro Updated With New Improvements
Axis CNC Inc was founded in 2012 in Ware, Massachusetts, when Dan and Glenn Larzus, a father and son duo, decided to venture into the manufacturing industry. Axis CNC Inc has provided customers with the highest quality manufacturing, machining, and programming services since they’ve opened. They specialize in manufacturing medical equipment and have a passion for making snowmobile parts.
We sat down with Axis CNC Inc to discuss how they got started and what they have learned over there years in the manufacturing world. Watch our video below to see our full interview.
https://www.harveyperformance.com/wp-content/uploads/2019/12/Axis-CNC.png4351155Guy Petrillohttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngGuy Petrillo2019-12-16 17:00:192020-04-03 16:01:20Axis CNC Inc. – Featured Customer
With the recent addition of the Micro 100 brand to the Harvey Performance Company family, we want to know how you have been utilizing its expansive tooling offering. Has Micro 100’s Micro-Quik™ system helped you save time and money? Do you have a favorite tool that gets the job done for you every time? Has Micro 100 tooling saved you from a jam? We want to know! Send us a video on Instagram and show us what you #MadeWithMicro100!
How to Participate
Official Contest Rules
Contest Dates:
The contest will run between December 5, 2019 to January 17, 2020. Submit as many entries as you’d like! Entries that are submitted before or after the contest period will not be considered for the top prizes (But we’d still like to see them!)
The Important Stuff:
Take a video of your Micro 100 tool in action, clear and visible.
Share your video on social media using #MadeWithMicro100 and tagging @Micro_100.
Detail the story behind the project (tool number(s), operation, running parameters, etc.)
Prizes
The top five entries will be sent Micro 100’s Micro-Quik™ tool change system with a few of our quick change tools. The top three entries will be offered a spot as a “Featured Customer” on our “In The Loupe” blog!
The Fine Print:
Please ensure that you have permission from both your employer and customer to post a video.
All entries must be the original work of the person identified in the entry.
No purchase necessary to enter or win. A purchase will not increase your chances of winning.
On January 28, 2020, the top 5 winners will be announced to the public. The Top 5 selected winners will receive a prize. The odds of being selected depend on the number of entries received. If a potential winner cannot be contacted within five (5) days after the date of first attempt, an alternative winner may be selected.
The potential winners will be notified via social media. Each potential winner must complete a release form granting Micro 100 full permission to publish the winner’s submitted video. If a potential winner cannot be contacted, or fails to submit the release form, the potential winner forfeits prize. Potential winners must continue to comply with all terms and conditions of these official contest rules, and winning is contingent upon fulfilling all requirements.
Participation in the contest constitutes entrants’ full and unconditional agreement to and acceptance of these official rules and decisions. Winning a prize is contingent upon being compliant with these official rules and fulfilling all other requirements.
The Micro 100 Video Contest is open to residents in US and Canada who are at least 18 years old at the time of entry.
https://www.harveyperformance.com/wp-content/uploads/2019/12/MadeWithMicro100-Featured.jpg6001599Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2019-12-05 13:13:002019-12-19 11:54:36Show Us What You #MadeWithMicro100
https://www.instagram.com/p/By7ps3cAM9A/
https://www.harveyperformance.com/wp-content/uploads/2019/10/Spindle-Featured.jpg6001599Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2019-10-24 13:21:212021-02-25 08:52:55How to Select a Spindle
When a machinist needs to cut material significantly deeper than wide, a Slitting Saw is an ideal choice to get the job done. A Slitting Saw is unique due to its composition and rigidity, which allows it to hold up in a variety of both straightforward and tricky to machine materials.
A Slitting Saw is a flat (with or without a dish), circular-shaped saw that has a hole in the middle and teeth on the outer diameter. Used in conjunction with an arbor, a Slitting Saw is intended for machining purposes that require a large amount of material to be removed within a small diameter, such as slotting or cutoff applications.
Other names for Slitting Saws include (but are not limited to) Slitting Cutters, Slotting Cutters, Jewelers Saws, and Slitting Knives. Both Jewelers Saws and Slitting Knives are particular types of Slitting Saws. Jewelers Saws have a high tooth count enabling them to cut tiny, precise features, and Slitting Knives are Slitting Saws with no teeth at all. On Jewelers Saws, the tooth counts are generally much higher than other types of saws in order to make the cuts as accurate as possible.
Separating Two Pieces of Material
If an application calls for cutting a piece of material, such as a rod, in half, then a slitting saw will work well to cut the pieces apart while increasing efficiency.
Undercutting Applications
Saws can perform undercutting applications if mounted correctly, which can eliminate the need to remount the workpiece completely.
Slotting into Material
Capable of creating thin slots with a significant depth of cut, Slitting Saws can be just the right tool for the job!
https://www.instagram.com/p/BvwSC5IpqPV/
While it may look similar to a stainless steel circular saw blade from a hardware store, a Slitting Saw should neverbe used with construction tools such as a table or circular saw. Brittle saw blades such as slitting saws will shatter when used on manual machines, and can cause injury when not used on the proper set up.
https://www.harveyperformance.com/wp-content/uploads/2020/08/Slitting-Saw-Featured.jpg6001599Tim Limahttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngTim Lima2019-09-10 09:30:532021-02-25 08:59:21The Geometries and Purposes of a Slitting Saw
About the Elements
Ruthenium (Ru)
Rhodium (Rh)
Palladium (Pd)
Silver (Ag)
Osmium (Os)
Iridium (Ir)
Platinum (Pt)
Gold (Au)
Machining Precious Metals
Tools for Precious Metals
Speeds and Feeds charts:
Downloading Tool Libraries
Selecting a Tool
Searching by Tool Number
Searching by Keyword
Searching by Tool Type
Searching by Tool Dimensions
Using Specialty Profile Tools
Tool Name
Fusion 360 Name
Back Chamfer Cutter
Dovetail Mill
Chamfer Cutters
Chamfer Mill
Corner Rounding End Mill – Unflared
Radius Mill
Dovetail Cutter
Dovetail Mill
Drill/End Mill
Spot Drill
Engraving Cutter/Marking Cutter – Tip Radius
Tapered Mill
Engraving Cutter – Tipped Off & Pointed
Chamfer Mill
Keyseat Cutter
Slot Mill
Runner Cutter
Tapered Mill
Undercutting End Mill
Lollipop Mill
All Other Specialty Profiles
Form Mill
Speeds and Feeds
If you have further questions about speeds and feeds, please reach out to our Technical Support team. They can be reached Monday-Friday from 8 AM to 7 PM EST at 800-645-5609, or by email at [email protected].
To access speeds and feeds information for your Helical Solutions end mills, we recommend using our Machining Advisor Pro application. Machining Advisor Pro (MAP) generates specialized machining parameters by pairing the unique geometries of your Helical Solutions end mill with your exact tool path, material, and machine setup. MAP is available free of charge as a web-based desktop app, or as a downloadable application on the App Store for iOS and Google Play.
To learn more about Machining Advisor Pro and get started today, visit www.machiningadvisorpro.com. If you have any questions about MAP, please reach out to us at [email protected].
If you have further questions about speeds and feeds, please reach out to our Technical Support team. They can be reached Monday-Friday from 8 AM to 7 PM EST at 866-543-5422, or by email at [email protected].
For additional questions or help using tool libraries, please send an email to [email protected]. If you would like to request a Harvey Performance Company tool library be added to your CAM package, please fill out the form here and let us know! We will be sure to notify you when your CAM package has available tool libraries.
Machinists have a number of variables to consider when setting up workholding devices for a machining operation. When it comes to cnc workholding, there are some major differences between holding a loosely toleranced duplicate part with a 10-minute cycle time and holding a tightly toleranced specialized part with a 10-hour cycle time. Determining which method works best for your machining job is essential to maintaining an efficient operation.
CNC Workholding Devices
Ideal workholding devices have easily repeatable setups. For this reason, some machines have standard workholding devices. Vises are generally used with milling machines while chucks or collets are used when running a lathe machine. Sometimes, a part may need a customized cnc workholding setup in order to secure the piece properly during machining. Fixtures and jigs are examples of customized cnc workholding devices.
Fixtures and Jigs
The 4 Fixture Bodies
Locators
Supports
Clamps
Hydraulic Systems
Pneumatic clamps
Pneumatic clamps attain their gripping force from the power created by a compressed gas (usually air). These systems are generally bulkier and are used for smaller workpieces that require less room on the worktable. Power clamping offers a few advantages over conventional clamping. First, these systems can be activated and deactivated quickly to save on changeover time. Second, they place uniform pressure on the part, which help prevent errors and deformation. A significant disadvantage they pose is the cost of a system but this can be quickly offset by production time saved.
Key Guidelines to Follow
Lastly, there are a few guidelines to follow when choosing the appropriate fixture or jig setup.
Ensure Proper Tolerancing
Place Clamps in Correct Locations
Bottom Line
Three Key Benefits
Indexing
Increased Feed Rates
Better Part Finish
Opt for a Smoother Operation
https://www.harveyperformance.com/wp-content/uploads/2019/09/featureimg_StaggerToothKeyseat.jpg6001599Jeff Rauseohttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngJeff Rauseo2018-09-19 10:35:552021-01-14 14:17:45Experience the Benefits of Staggered Tooth Keyseats
