Using MAP
B&R Custom machining
aerospace machining
B&R custom machining
How To Maximize High Balance End Mills
https://www.instagram.com/p/BhHWF5eh1o9/?hl=en&taken-by=helicaltools
Utilizing Tap Testers
What Tap Testers Do
How Tap Testing Works
High balance
Stainless steel can be as common as Aluminum in many shops, especially when manufacturing parts for the aerospace and automotive industries. It is a fairly versatile material with many different alloys and grades which can accommodate a wide variety of applications. However, it is also one of the most difficult to machine. Stainless steels are notorious end mill assassins, so dialing in your speeds and feeds and selecting the proper tool is essential for machining success.
Category Properties Popular Grades Common Uses
Austenitic Non-magnetic, outstanding corrosion and heat resistance. 304, 316 Food processing equipment, gutters, bolts, nuts, and other fasteners.
Ferritic Magnetic, lower corrosion and heat resistance than Austenitic. 430, 446 Automotive parts and kitchen appliances.
Martensitic Magnetic, moderate corrosion resistance – not for severe corrosion. 416, 420, 440 Knives, firearms, surgical instruments, and hand tools.
Precipitation Hardened (PH) Strongest grade, heat treatable, severe corrosion resistance. 17-4 PH, 15-5 PH Aerospace components.
Duplex Stronger mixture of both Austenitic and Ferritic. 244, 2304, 2507 Water treatment plants, pressure vessels.
Traditional Roughing
stainless steel machining
stainless steel
HEV-5
Stainless steel machining doesn’t have to be hard. By identifying the proper material grade for each part, selecting the perfect cutting tool, and optimizing running parameters, stainless steel machining headaches can be a thing of the past.
Attacking Aluminum: A Machining Guide
Tool Geometry
flute count for aluminum
Helix Angles
Aluminum Machining
Tooling Options
Chipbreaker Tooling
Chipbreaker Aluminum
https://www.instagram.com/p/Bd0i51bBHYv/
Why You Should Stop Deburring By Hand
High Precision Tools
hand deburring
cnc deburring
cnc deburring
1. Premature Tool Decay / Tool Failure
tool wear
2. Subpar Part Finish
3. Inefficient Coolant Usage
https://www.instagram.com/p/BY-_UWqAYVM/?hl=en&taken-by=harveytool
4. Not Taking Advantage of Tool Versatility
chamfer mills
5. High Machine Downtime
What use is a machine that’s not running? Minimizing machine downtime is a key way to ensure that your shop is reaching its efficiency pinnacle. This can be accomplished a variety of ways, including keeping like-parts together. This allows for a simple swap-in, swap-out of material to be machined by the same cutting tool. This saves valuable time swapping out tooling, and lets your machine to do its job for more time per workday. Production planning is a key factor to running an efficient machine shop.
1. Running It Too Fast or Too Slow
Determining the right speeds and feeds for your tool and operation can be a complicated process, but understanding the ideal speed (RPM) is necessary before you start running your machine. Running a tool too fast can cause suboptimal chip size or even catastrophic tool failure. Conversely, a low RPM can result in deflection, bad finish, or simply decreased metal removal rates. If you are unsure what the ideal RPM for your job is, contact the tool manufacturer.
2. Feeding It Too Little or Too Much
3. Using Traditional Roughing
4. Using Improper Tool Holding
tool holding
5. Not Using Variable Helix/Pitch Geometry
variable helix
6. Choosing the Wrong Coating
end mill coatings
7. Using a Long Length of Cut
optimal length of cut
8. Choosing the Wrong Flute Count
flute count
1. Keyseat Cutter Geometry
Selecting and utilizing the right tool is often more complicated than identifying the right diameter and dialing in the speeds and feeds. A keyseat cutter’s strength should be considered carefully, especially in tricky applications and difficult materials.
As with any tool, a longer reach will make a keyseat cutter more prone to deflection and breakage. A tool with the shortest allowable reach should be used to ensure the strongest tool possible.
A keyseat cutter’s neck diameter greatly affects its performance. A thinner neck allows for a comparatively larger radial depth of cut (RDOC) and more clearance, but makes for a weaker tool. A thicker neck reduces the keyseat cutter’s RDOC, but greatly strengthens the tool overall. When clearances allow, a keyseat cutter with a thicker neck and larger cutter diameter should be chosen over one with a thinner neck and smaller cutter diameter (Figure 1).
keyseat cutter geometry
2. Radial Depth of Cut
Understanding a keyseat cutter’s RDOC is critical to choosing the correct tool, but understanding how it affects your tool path is necessary for optimal results. While it may be tempting to make a cut using a keyseat cutter’s maximum RDOC, this will result in increased stress on the tool, a worse finish, and potential catastrophic tool failure. It is almost always better to use a lighter depth of cut and make multiple passes (Figure 2).
keyseat cutter RDOC
3. Desired Slot Size
ideal keyseat slot
4. Staggered Tooth Geometry
Having trouble finding the perfect keyseat cutter for your job? Harvey Tool offers over 1,800 keyseat cutter options, with cutter diameters from 1/16” to 1-1/2” and cutter widths from .010” to ½”.
Work Hardening and When It Should Scare You
Work Hardening Overview
titanium
Major Problems
work hardening
How To Avoid Work Hardening
