- Drilling
- V-Grooving
- Milling
- Spot Drilling
- Chamfering
The main difference between Drill / End Mill styles is the point geometry. They are defined by how the flutes are designed on the end of the tool, using geometry typically seen on either an end mill or a drill. While mill style tools follow the features of an end mill or chamfer mill, the drill style geometry uses an S-gash at the tip. This lends strength to the tip of the tool, while giving it the ability to efficiently and accurately penetrate material axially. While both styles are capable of OD milling, mill style tools will be better for chamfering operations, while drill style will excel in drilling. The additional option of the Harvey Tool spiral tipped Drill / End Mill is an unprecedented design in the industry. This tool combines end geometry taken from our helical flute chamfer cutters with a variable helix on the OD for enhanced performance. Versatility without sacrificing finish and optimal performance is the result.
Drill Mills: Tool Offering
Mill Style – 2 Flute
Mill Style – 4 Flute
Drill Style – 2 Flute
Helical Tip – 4 Flute
