While similar on the surface, Half-round Engraving Cutters and Marking Cutters are actually very different. Both tools are unique in the geometries they possess, the benefits they offer, and the specific purposes they’re used for. Below are the key differences between Engraving Cutters and Marking Cutters that all machinists must know, as the engraving on a part is often a critical step in the machining process.
All Marking Cutters are Engraving Cutters, but not all Engraving Cutters are Marking Cutters. This is because Marking Cutters are a “type” of engraving tool. By virtue of their sturdier geometry, Marking Cutters are suited for applications requiring repetition such as the engraving of serial numbers onto parts. Harvey Tool has been able to customize specific tool geometries for ferrous and non-ferrous applications, offering Marking Cutters for material specific purposes.
engraver
engraver
Historically, Engraving Cutters have been made as a half round style tool. This tool allows for a true point, which is better for fine detail, but can easily break if not run correctly. Because of this, Engraving Cutters have performed well in softer materials such as aluminum and wood, especially for jobs that require an artistic engraving with fine detail.
engraver
Harvey Tool Product Offering
engraver
Marking Cutters are fully stocked in tip radius or tipped-off options, and are designed specifically for either ferrous or non-ferrous materials. Marking Cutters are offered in included angles from 20° to 120°.
Built-In CAM Applications
Importance of Tooling to HEM
Best Tools for HEM:
Defining Chip Thinning
Chip Thickness
How Chip Thinning Occurs
radial chip thinning
IPT chip thinning formula
Lasting Benefits
