What are Pecking Cycles?
Rather than drill to full drill depth in one single plunge, pecking cycles involve several passes – a little at a time. Pecking aids the chip evacuation process, helps support tool accuracy while minimizing walking, prevents chip packing and breakage, and results in a better all around final part.
aluminum pecking cycles
hardened steels chart
prehardened steels chart
From the above tables, it’s easy to identify how recommended  cycles change based on the properties of the material being machined. Unsurprisingly, the harder the material is, the shorter the recommended pecking depths are. As always, miniature drills with a diameter of less than .010″ are extremely fragile and require special precautions to avoid immediate failure. For help with your specific job, contact the Harvey Tool Technical Team at 800-645-5609 or [email protected]
Pre-Drilled Hole
tool entry predrill
Helical Interpolation
helical interpolation
Ramping-In
ramping
Hard/Ferrous Materials: 1°-3°
arching with end mill
Straight Plunge
tool entry
Straight Tool Entry
tool entry
Roll-In Tool Entry
tool entry
tapered end mills
tapered end mills
Tapered Reach
following pros and cons:
• Increased tool strength
• Reduced tool deflection
• Less chatter, better finish
• Increased productivity
• Reduced clearance
tapered end mills
Tapered Length of Cut
tapered end mills
