Tag Archive for: t-slot
November 15, 2017/2 Comments/in Harvey Tool, Tool Geometry, Tool Information Guides, Tool Selection/by Harvey Performance Company
Keyseat Cutter Geometry
infographic of ideal and non-ideal keyseat sizing and uses based on depth and cutter diameter
two Harvey Tool Keyseats showcasing bottom geometry of tooling
Harvey Tool Keyseat Geometries
Radial Depth of Cut
Understanding a keyseat cutter’s radial depth of cut is critical to choosing the correct tool, but understanding how it affects your tool path is necessary for optimal results. While it may be tempting to make a cut using a keyseat cutter’s maximum RDOC, this will result in increased stress on the tool, a worse finish, and potential catastrophic tool failure. It is almost always better to use a lighter depth of cut and make multiple passes (Figure 2).
ideal and non-deal keyseat radial depth of cut
Desired Slot Size
infographic of desired slot size compared to keyseat sizes and thickness
staggered tooth keyseat geometries
Having trouble finding the perfect keyseat for your job? Harvey Tool offers over 2,100 keyseat cutter options, with cutter diameters from 1/16” to 1-1/2” and cutter widths from .010” to ½”.
https://www.harveyperformance.com/wp-content/uploads/2017/11/Feature-Image-Keyseat-Considerations-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-11-15 15:35:012024-02-12 14:19:164 Important Keyseat Cutter Considerations
