Tag Archive for: Thin Wall Milling
What is a Tight Tolerance?
tolerances
How Are Tolerances Used?
tooling tolerance
Spotting Drills
spotting drills
Reamers
miniature reamers
Be Wary of Deflection
Tolerances Summarized
Use Proper Tooling
Axial Depth of Cut (ADOC)
To support the walls during thin wall milling, keep a wide-cross section behind it. We recommend utilizing a “stepped down” approach, which divides the total wall height to manageable depths while working each side of the wall. The Axial Depth of Cut (ADOC) dimension will vary depending on the material (and its hardness) being cut.
ADOC in thin wall milling
Radial Depth of Cut (RDOC)
RDOC in thin wall milling
  • Climb milling will help to keep tool pressure to a minimum.
  • Manual vibration dampening and wall stabilization can be achieved by using thermoplastic compounds, or wax, which can be thermally removed.
  • The use of ultra-high performance tool paths can optimize tool performance.
