Helical Solutions High Feed End Mill
High Efficiency Milling for Titanium Made Easy With Helical’s New HVTI Cutter
End Mills for Titanium
Helical HVTI Titanium
WATCH THE HVTI IN ACTION
Harvey Tool: Behind the Scenes
Many of our end users have had great questions about our manufacturing process, how we keep all of our tools in stock, and more. Now for the first time, we decided to open our doors and show you how we manufacture and fulfill the Harvey Tool product. We partnered with John Saunders from NYC CNC to create a “Factory Tour” video, covering topics like our CNC grinding machines and setups, tool manufacturing, and our warehouse organization and fulfillment procedures.
In the video below, we first toured our Rowley, MA warehouse and fulfillment center with Fulfillment Manager Megan Townsley. After that, we head up to Maine to check out how the Harvey Tool product is manufactured and inspected with VP of Operations Brian McKahan.
We know you’re busy making amazing parts, and might not have time for the entire video. To save you time, here are some of the highlights and facts you should know about Harvey Tool.
When We Say Miniature, We Mean Miniature
Our miniature end mills are in stock in diameters down to .001″. In fact, our Stub and Standard end mills cover every diameter from .001″ to .120″, meaning we will always have you covered when it comes to micro-machining. Although it is hard to see with the naked eye, you can get an up-close look at the famed .001″ end mill by jumping to the 35 minute mark in the tour video.
Micro-Tools Require Precision Grinding
We utilize advanced CNC grinding technology to manufacture our miniature tools at our plant in Maine. Brian MacKahan, VP of Operations, does an excellent job of breaking down our manufacturing process beginning at the 21 minute mark of the tour video. If you just want to see some miniature CNC grinding in action, jump ahead to the 26 minute mark.
Our Inspection Process is Rigourous
All of our tools are sent through an extensive inspection process, both at our plant in Maine and at our headquarters in Massachusetts. To check out the Massachusetts inspection room, head to the 19 minute mark of the video. If you want to see some more in-depth inspection at our facility in Maine, you can jump to the 35 minute mark.
Yes, We Have It In Stock
If you need it, we have it. All 20,000+ tools from our catalog are kept stocked and ready to ship to you the same day. If you need more proof, jump to 15:30 in the tour video, where you will see John Saunders choose a randomly selected Undercutting End Mill from our catalog and find it in our warehouse, in stock and ready to head out to a shop.
We Maintain a 99.8% Order Accuracy Rate
Our fulfillment team handles all of your orders with precision and accuracy. We maintain a 99.8% order accuracy rate, with fulfillment team members checking every order multiple times to ensure you receive exactly what you need. You can learn more about our order fulfillment process and accuracy rates by moving to the 5 minute mark in the video.
We Sell More Than Miniature
Miniature end mills have always been our bread and butter, but did you know that we have many larger diameter tools in stock as well? At the 9 minute mark in the video, you can see John pull out a 3/4″ Long Reach Ball Nose End Mill from our shelves. If you are interested in larger diameter specialty tooling, jump to 12:15 in the video to check out one of our large diameter Corner Rounding End Mills.
When You Call, You’ll Always Talk to An Experienced Tech Expert
Though we didn’t catch it on tape, John Saunders was blown away by our tech team during his visit. He got a chance to pick their brains about a problem he was having and a few minutes later, he received a recommendation for the right compression cutter to tackle his unique operation. This tool was later showcased in one of his “Widget Wednesday” videos.
When you choose Harvey Tool, you will never get an automated system or countless steps before you are able to talk to a real person about your applications. Our industry-leading technical support team is available over the phones or via email every Monday-Friday from 8 AM EST to 7 PM EST. You can reach them by calling 800-645-5609, or by sending an email to [email protected].
We Value Our Distributor Network
We value our large distributor network, and we ask that all orders are placed with your local dealer. To find the closest distributor to you, use the “Find a Distributor” tool on our website.
We’re Hiring!
We are currently hiring for many different positions, including open CNC Machinists positions for all shifts at our manufacturing plant. If you want to be a part of the Harvey Performance Company team, check out our Opportunities page for more information.
diamond tool coatings
Amorphous Diamond Coating
amorphous diamond coating
CVD Diamond Coating
Polycrystalline Diamond (PCD)
Coating Hardness & Thickness
Flute Styles
PCD Diamond end mill
PCD Ball End Mill
CVD Diamond end mill
CVD Ball End Mill
Proper Uses
Cut to the Point
multiaxis machining
Built-In CAM Applications
Importance of Tooling to HEM
Best Tools for HEM:
Harvey Tool Voted #1 Top End Mill Brand
Rowley, MAHarvey Tool is proud to announce that for the second consecutive year, it has been voted #1 Most Popular End Mill Brand by participants of the 2016 CNC Cookbook End Mill Survey, a questionnaire meant to gauge machinists’ most preferred manufacturers.
Of the nearly 1,300 votes cast for more than 90 different end mill brands, Harvey Tool earned the top spot with 90.3 percent of voters listing the Rowley-based company as a top choice end mill manufacturer. Following behind were Niagara (whom Harvey Tool tied with for the top spot last year), OSG, Accupro, Garr, SGS, Kennametal, and Micro100.
While the survey focused on overall brand popularity, it also asked respondents to rank end mill brands based on the categories of “combined value and performance” and “highest performance.” Harvey Tool was named the top choice for both categories, tallying 7.9 percent of votes for highest performance and 6.8 percent for combined value and performance. Simply, participants voted Harvey Tool the first choice for tools if money was no factor, while also listing them as having the best balance of performance and value.
Helical Solutions, whom Harvey Tool acquired in 2015, also performed well in the CNC Cookbook End Mill Survey, ranking in the top position within the Tier 2 list of end mill brands. This marks the first year that Helical has been named and ranked in this annual survey.
“We’re extremely proud of this accomplishment as it works to affirm the hard work and commitment our team exhibits every day for our customers,” said Harvey Tool Vice President of Marketing Garth Ely. “The results of this survey clearly express that Harvey Tool is a top choice for machinists, and there’s no better feeling than that.”
“Each member of our team played a vital role in making this possible,” Ely said. “It’s truly a cross functional effort here, which makes an accomplishment of this magnitude so much greater.”
“For us, this is just another accomplishment in what has been a tremendous year of growth and achievement,” said Harvey Tool Senior Vice President of Sales Jerry Gleisner. “To see both Harvey Tool and Helical Solutions perform so well is only added motivation for us to continue to push for an even better product for our customers in 2017.”
