Tag Archive for: tool coating
Choosing the Right Pecking Cycle Approach
What are Pecking Cycles?
High Performance Drills – Flat Bottom
aluminum pecking cycles
hardened steels chart
prehardened steels chart
Using Traditional Roughing
Using a Long Length of Cut
Work Hardening and When it Should Scare You
What Is Work Hardening
Work hardening is often an unintentional part of the machining process, where the cutting tool generates enough heat in one area to harden the workpiece. It results in plastic deformation which alters the physical structure of the metal being machined. This altered structure affects the machinability of the chosen metal and acts similarly to heat treating. When this occurs the generated speeds and feed requirements will be changed, creating a potential for inefficiency. This makes for a much more difficult machining process and can lead to scrapped parts, broken tools, and serious headaches.
Soften Up Work Hardening With Machining Advisor Pro’s Customizable Speeds and Feeds
What Causes Work Hardening
titanium packed ball bearing
Major Problems
Heat Generation
As previously stated, metal work hardening can create some serious problems when machining. The biggest issue is heat generated by the cutting tool and transferring to the workpiece, rather than to the chips. When the heat is transferred to the workpiece, it can cause deformation which will lead to scrapped parts. Stainless Steels and High-Temp Alloys are most prone to work hardening, so extra precaution is needed when machining in these materials.
stringy chips in front of an end mill in the cut
Improper Speeds and Feeds
Harvey tool ad for work hardening and speeds and feeds
How To Avoid Work Hardening
There are a few main keys to avoid work hardening: correct speeds and feeds, performing climb milling, selecting appropriate tool coatings, and proper coolant usage. As a general rule of thumb, talking to your tooling manufacturer and using their recommended speeds and feeds is essential for machining success.
Speeds and Feeds
Speeds and feeds become an even bigger priority when you want to avoid heat and tool rubbing, which can both cause serious work hardening. More cutting power and a constant feed rate keeps the tool moving and prevents heat from building up and transferring to the workpiece. The ultimate goal is to get the heat to transfer to the chips, and minimize the heat that is transferred into workpiece and avoiding any deformation of parts. Prior to machining, you should be setting guidelines for each cutting tool to ensure you receive the highest output without compromising on part finish or tool life.
Conventional milling and climb milling are the two ways to perform CNC cutting operations. In climb milling, the cutter rotates with the feed, while in conventional milling the cutter rotates against the feed. However during conventional milling, the chip width starts at zero then increases thus generating heat at the workpiece. This results in work hardening and faster tool wear over time. On the other hand, climb milling begins at maximum chip width and decreases which transfers heat to the chip rather than the tool or workpiece. Climb milling is advantageous because there is less tool rubbing, minimized chance of chip recutting, and enhanced tool life.
drawing that displays conventional milling vs climb milling in cnc cutting operations
Tool Coating
While friction is often the main culprit of heat generation, the appropriate coating for the material may help combat the severity. Many coatings for ferrous materials reduce the amount of friction generated during cutting action. This added lubricity will reduce the friction on the cutting tool and workpiece, therefore transferring the heat generated to the chip, rather than to the workpiece. Tool coatings also create a natural separation between carbide and the workpiece. This minimizes the internal temperature of the carbide as heat is transferred into the chips and workpiece.
Coolant
Proper coolant usage helps to control the temperature in a cutting operation. Machinists generally choose between using Flooding or High Pressure Coolant options. Flooding the workpiece with coolant may be necessary to maintain the proper temperature, especially when machining in stainless steels and high-temp alloys. This low pressure method creates lubricity to flush chips and avoid chip recutting which commonly damages cutting tools.
high pressure coolant spraying on a part and workpiece during a cnc cutting operation
On the other hand, high pressure coolant delivers enhanced levels of chip evacuation and instant cooling of a part. However, one must be cautious of potentially breaking miniature diameter tooling when using this method due to the higher pressures. Coolant-fed tools can also help to reduce the heat at the contact point, lessening work hardening. While coolant-fed tools are typically a custom modification, saving parts from the scrap heap and using more machine time for the placement part will see the tool pay for itself over time.
What is Chipbreaker Tooling?
up close image of chipbreaker end mill
small metal chips in cnc machine resulting from the use of a chipbreaker end mill
Helical Part No.33737
Material4340 Steel
ADOC2.545″
RDOC.125″
Speed2,800 RPM
Feed78 IPM
Chipbreaker Geometry is often utilized in aluminum jobs and with other materials where long, stringy chips are common. Materials that produce a powdery chip, such as graphite, should not be machined with a chipbreaker tool, as chip evacuation would not be a concern. Helical Solutions’ line of chipbreaker tooling includes a 3-flute option for aluminum and non-ferrous materials, and its reduced neck counterpart. Additionally, Helical offers a 4-flute rougher with chipbreaker geometry for high-temp alloys and stainless steels. Harvey Tool’s expansive product offering includes a composite cutting end mill with chipbreaker geometry.
helical solutions 7 flute chipbreaker end mill cutting edges
Harvey Performance Company’s Jeff Davis Interviewed in Advanced Manufacturing Article
Harvey Performance Company Vice President of Engineering Jeff Davis was interviewed in Advanced Manufacturing’s May 2, 2017 article entitled “Coatings Expand Cutting Tool Capabilities, Reach New Markets,” in which he discusses the proper use of tool coatings.
As the lead engineer for the Harvey Tool and Helical Solutions brands, Davis is well versed in the world of miniature and large diameter tooling, as well as several different coating options.
“Different coatings address different concerns,” said Davis. “Some coatings, when used improperly, can cause problems, including stickiness and galling. Although diamond works well in graphite and composites, ferrous applications could result in excessive thermal build-up, coating breakdown, and damage for both the tool and the part.”
View the article in its entirety.
Harvey Tool Company was also mentioned in Advanced Manufacturing’s post “What Machine Shops Need to Know about Deburring.” For more, click here.
