https://www.harveyperformance.com/wp-content/uploads/2020/02/Feature-Image-5-Things-High-Feed-EMs-IMG-Copy-2.jpg5251400Alexander Beanhttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngAlexander Bean2020-02-13 15:25:162022-06-08 11:22:005 Things to Know About Helical’s High Feed End Mills
Helix Angles Rule of Thumb
One general rule of thumb is that as the helix angle increases, the length of engagement along the cutting edge will decrease. That said, there are many benefits and drawbacks to slow and high helix angles that can impact any machining operation.
Slow Helix Tool <40°
Benefits
Enhanced Strength – A larger core creates a strong tool that can resist deflection, or the force that will bend a tool under pressure.
Reduced Lifting – A slow helix will decrease a part from lifting off of the worktable in settings that are less secure.
Larger Chip Evacuation – The slow helix allows the tool to create a large chip, great for hogging out material.
Drawbacks
Rough Finish – A slow helix end mill takes a large chip, but can sometimes struggle to evacuate the chip. This inefficiency can result in a sub-par part finish.
Slower Feed Rate – The increased radial force of a slow helix end mill requires running the end mill at a slower feed rate.
High Helix Tool >40°
Benefits
Lower Radial Force – The tool will run quieter and smoother due to better shearing action, and allow for less deflection and more stability in thin wall applications.
Efficient Chip Evacuation – As the helix angle increases, the length of cutting edge engagement will decrease, and the axial force will increase. This lifts chips out and away, resulting in efficient chip evacuation.
Improved Part Finish – With lower radial forces, high helix tools are able to cut through material much more easily with a better shearing action, leaving an improved surface finish.
Drawbacks
Weaker Cutting Teeth – With a higher helix, the teeth of a tool will be thinner, and therefore thinner.
Deflection Risk – The smaller teeth of the high helix tool will increase the risk of deflection, or the force that will bend a tool under pressure. This limits how fast you can push high helix tools.
Increased Risk of Tool Failure – If deflection isn’t properly managed, this can result in a poor finish quality and tool failure.
https://www.harveyperformance.com/wp-content/uploads/2020/02/Feature-Image-High-and-Low-Helix-Angles-IMG.jpg6001599Harvey Performance Companyhttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngHarvey Performance Company2020-02-05 16:07:562021-11-22 11:24:27Benefits & Drawbacks of High and Low Helix Angles
WATCH THE HVTI IN ACTION
https://www.harveyperformance.com/wp-content/uploads/2020/01/Feature-Image-HVTI-IMG-1.jpg5251400Harvey Performance Companyhttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngHarvey Performance Company2020-01-03 10:00:302022-06-08 11:24:03High Efficiency Milling for Titanium Made Easy With Helical’s New HVTI Cutter
With the recent addition of the Micro 100 brand to the Harvey Performance Company family, we want to know how you have been utilizing its expansive tooling offering. Has Micro 100’s Micro-Quik system helped you save time and money? Do you have a favorite tool that gets the job done for you every time? Has Micro 100 tooling saved you from a jam? We want to know! Send us a video on Instagram and show us what you #MadeWithMicro100!
How to Participate
Official Contest Rules
Contest Dates:
The contest will run between December 5, 2019 to January 17, 2020. Submit as many entries as you’d like! Entries that are submitted before or after the contest period will not be considered for the top prizes (But we’d still like to see them!)
The Important Stuff:
Take a video of your Micro 100 tool in action, clear and visible.
Share your video on social media using #MadeWithMicro100 and tagging @Micro_100.
Detail the story behind the project (tool number(s), operation, running parameters, etc.)
Prizes
The top five entries will be sent Micro 100’s Micro-Quik tool change system with a few of our quick change tools. The top three entries will be offered a spot as a “Featured Customer” on our “In The Loupe” blog!
The Fine Print:
Please ensure that you have permission from both your employer and customer to post a video.
All entries must be the original work of the person identified in the entry.
No purchase necessary to enter or win. A purchase will not increase your chances of winning.
On January 28, 2020, the top 5 winners will be announced to the public. The Top 5 selected winners will receive a prize. The odds of being selected depend on the number of entries received. If a potential winner cannot be contacted within five (5) days after the date of first attempt, an alternative winner may be selected.
The potential winners will be notified via social media. Each potential winner must complete a release form granting Micro 100 full permission to publish the winner’s submitted video. If a potential winner cannot be contacted, or fails to submit the release form, the potential winner forfeits prize. Potential winners must continue to comply with all terms and conditions of these official contest rules, and winning is contingent upon fulfilling all requirements.
Participation in the contest constitutes entrants’ full and unconditional agreement to and acceptance of these official rules and decisions. Winning a prize is contingent upon being compliant with these official rules and fulfilling all other requirements.
The Micro 100 Video Contest is open to residents in US and Canada who are at least 18 years old at the time of entry.
https://www.harveyperformance.com/wp-content/uploads/2019/12/MadeWithMicro100-Featured.jpg6001599Harvey Performance Companyhttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngHarvey Performance Company2019-12-05 13:13:002022-05-25 10:00:35Show Us What You #MadeWithMicro100
https://www.harveyperformance.com/wp-content/uploads/2017/08/Feature-Image-Uses-of-Chamfer-Mill-IMG.jpg5251400Harvey Performance Companyhttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngHarvey Performance Company2019-11-22 08:20:372021-11-19 08:37:18Selecting the Right Chamfer Cutter Tip Geometry
Separating Two Pieces of Material
If an application calls for cutting a piece of material, such as a rod, in half, then a slitting saw will work well to cut the pieces apart while increasing efficiency.
Undercutting Applications
Saws can perform undercutting applications if mounted correctly, which can eliminate the need to remount the workpiece completely.
Slotting into Material
Capable of creating thin slots with a significant depth of cut, Slitting Saws can be just the right tool for the job!
While it may look similar to a stainless steel circular saw blade from a hardware store, this tool should neverbe used with construction tools such as a table or circular saw. Brittle saw blades will shatter when used on manual machines, and can cause injury when not used on the proper set up.
https://www.harveyperformance.com/wp-content/uploads/2019/09/Feature-Image-Slitting-Saws-IMG.jpg5251400Harvey Performance Companyhttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngHarvey Performance Company2019-09-10 09:30:532021-11-19 08:37:59The Geometries and Purposes of a Slitting Saw
Downloading Tool Libraries
Selecting a Tool
Searching by Tool Number
Searching by Keyword
Searching by Tool Type
Searching by Tool Dimensions
Using Specialty Profile Tools
Tool Name
Fusion 360 Name
Back Chamfer Cutter
Dovetail Mill
Chamfer Cutters
Chamfer Mill
Corner Rounding End Mill – Unflared
Radius Mill
Dovetail Cutter
Dovetail Mill
Drill/End Mill
Spot Drill
Engraving Cutter/Marking Cutter – Tip Radius
Tapered Mill
Engraving Cutter – Tipped Off & Pointed
Chamfer Mill
Keyseat Cutter
Slot Mill
Runner Cutter
Tapered Mill
Undercutting End Mill
Lollipop Mill
All Other Specialty Profiles
Form Mill
Speeds and Feeds
If you have further questions about speeds and feeds, please reach out to our Technical Support team. They can be reached Monday-Friday from 8 AM to 7 PM EST at 800-645-5609, or by email at [email protected].
To access speeds and feeds information for your Helical Solutions end mills, we recommend using our Machining Advisor Pro application. Machining Advisor Pro (MAP) generates specialized machining parameters by pairing the unique geometries of your Helical Solutions end mill with your exact tool path, material, and machine setup. MAP is available free of charge as a web-based desktop app, or as a downloadable application on the App Store for iOS and Google Play.
To learn more about Machining Advisor Pro and get started today, visit www.machiningadvisorpro.com. If you have any questions about MAP, please reach out to us at [email protected].
If you have further questions about speeds and feeds, please reach out to our Technical Support team. They can be reached Monday-Friday from 8 AM to 7 PM EST at 866-543-5422, or by email at [email protected].
For additional questions or help using tool libraries, please send an email to [email protected]. If you would like to request a Harvey Performance Company tool library be added to your CAM package, please fill out the form here and let us know! We will be sure to notify you when your CAM package has available tool libraries.
https://www.harveyperformance.com/wp-content/uploads/2018/09/machiningadvisorpro.jpg6001599David Pichettehttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngDavid Pichette2018-09-13 14:20:202021-09-21 08:23:11Get to Know Machining Advisor Pro
A cutting tool’s shank is one of the more vital parts of a tool, as it’s critical to the collet-tool connection. There are several types of shanks, each with their own tolerances and suitable tool holder methods. One of the most popular and effective tool holding styles is a shrink fit tool holder, which works with h6 shanks, but what does this mean and what are the benefits of it? How is this type of shank different from a shank with standard shank tolerances? To answer these questions, we must first explore the principals of tolerances.
The Principals of Tolerances
Defining Industry Standard Tolerances
There are two categories of shank tolerances that machinists and engineers operating a CNC machine should be familiar with: hole basis and shank (or shaft) basis. The hole basis system is where the minimum hole size is the starting point of the tolerance. If the hole tolerance starts with a capital “H,” then the hole has a positive tolerance with no negative tolerance. The shank basis system is where the maximum shank size is the starting point. This system is relatively the same idea as the hole basis system but instead, if the tolerance starts with a lowercase “h,” the shank has a negative tolerance and no positive tolerance.
Letter Designations
The limits of tolerance for a shank or hole are designated by the appropriate letter indicating the deviation. For instance, the letter “k” has the opposite minimum and maximum designations as “h”. Tolerances beginning with “k” are exclusively positive, while tolerances beginning with “h” are exclusively negative. The number following the given letter denotes the International Tolerance (IT) grade. For example, a tolerance with the number 6 will have a smaller tolerance range than the number 7, but larger than the number 5. This range is based on the size of the shank. A hole that has a 0.030” diameter will have an h6 tolerance of (+0.0000,-0.0002), while a 1.00” hole with have an h6 tolerance band of (+0.0000,-0.0005).
It is important to note that most sources list IT tolerances in millimeters, while the graph below has been translated to inches. Operations that require more precise manufacturing, such as reaming, will have lower IT grades. Operations that do not require manufacturing to be as precise will have higher IT grades.
Preferred Collet Fits
Different types of combinations of hole basis and shank basis tolerances lead to different types of collet fits. The following table offers insight into a few different types of preferred fits and the shank tolerances that are required for each.
Image: Machinery’s Handbook 29th Edition.
Shrink Fit Tool Holders
The shrink fit holder is one of the more popular styles of tool holders because of its ability to be more customizable, as evident in the chart above. In this method, a collet is heated to expand, then cooled to contract around the shank of a tool. At room temperature, a cutting tool should not be able to be inserted into a shrink fit holder – only when the holder has undergone thermal expansion due to the introduction of a significant amount of heat should the tool fit. As the holder cools, the tool is held tighter and tighter in place. Typically, a holder is heated through a ring of coils by an induction heater. It is important to heat the holder uniformly, paying mind to not overheat it. Doing so could cause the shank that is being held to expand within the holder and remain stuck.
Benefits of Shrink Fit Tool Holders
Gripping power. The shank is held flush and uniform against the holder, resulting in a tighter connection.
Low runout. A more secure connection will result in extended tool life, and a higher quality surface finish.
Better balance for high RPM. With a tighter tool-to-holder connection, the opportunity exists for more aggressive running parameters.
Understanding shank tolerances is an intricate part of the machining process as it impacts which tool holder is appropriate for your job. A secure holder connection is vital to the performance of the tool in your application. With an h6 shrink fit holder, the result is a secure connection with stronger gripping power. However, only certain shanks are able to be used with this type of holder. From the letter designation assigned to a shank, to whether that letter is upper or lowercase, each detail is vital to ensuring a proper fit between your tools shank and its corresponding shrink fit holder.
Drill Style vs. Mill Style
The main difference between Drill / End Mill styles is the point geometry. They are defined by how the flutes are designed on the end of the tool, using geometry typically seen on either an end mill or a drill. While mill style tools follow the features of an end mill or chamfer mill, the drill style geometry uses an S-gash at the tip. This lends strength to the tip of the tool, while giving it the ability to efficiently and accurately penetrate material axially. While both styles are capable of OD milling, mill style tools will be better for chamfering operations, while drill style will excel in drilling. The additional option of the Harvey Tool spiral tipped Drill / End Mill is an unprecedented design in the industry. This tool combines end geometry taken from our helical flute chamfer cutters with a variable helix on the OD for enhanced performance. Versatility without sacrificing finish and optimal performance is the result.
Drill Mills: Tool Offering
Mill Style – 2 Flute
Mill Style – 4 Flute
Drill Style – 2 Flute
Helical Tip – 4 Flute
https://www.harveyperformance.com/wp-content/uploads/2018/06/Feature-Image-Drill-vs-Mill-Style-IMG.jpg5251400Robert Keeverhttp://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.pngRobert Keever2018-06-25 14:52:162021-11-05 09:51:33Drill / End Mills: Drill Style vs. Mill Style
