Tag Archive for: tool failure
How to Select a Spindle
properly selecting a spindle
machining advisor pro mobile
The Importance of Tolerances
stacking tolerances
stacking tolerances
standard deviation
tolerance stacking
standard deviation
root sum
Click Here to Learn More
Use Worst Case Analysis:
For the left corner radius
.125” – .001” = .124”
For the flat section
.250” – .002” = .248”
For the right corner radius
.124” + .248” + .124” = .496”
.125” + .001” = .126”
.250” + .002” = .252”
.126” + .252” + .126” = .504”
Coolant
Tool Engagement
climb milling
Initial Workpiece Engagement
Gummy Materials Summarized
diamond tool coatings
Amorphous Diamond Coating
amorphous diamond coating
CVD Diamond Coating
Polycrystalline Diamond (PCD)
Coating Hardness & Thickness
Flute Styles
PCD Diamond end mill
PCD Ball End Mill
CVD Diamond end mill
CVD Ball End Mill
Proper Uses
Cut to the Point
Deflection Can Result In:
  • Subpar surface finish
Tool Deflection Remedies
Minimize Overhang
extended reach tool
Image Source: @NuevaPrecision
Long Flute vs. Long Reach
tool deflection
tool deflection graph
long reach end mill
Long Reach Tool: Variable Helix End Mills for Exotic Alloys – Ball – Long Reach, Stub Flute
long flute tool
core diameter vs neck diameter
Deflection Summarized
Choosing the Right Pecking Cycle Approach
What are Pecking Cycles?
High Performance Drills – Flat Bottom
aluminum pecking cycles
hardened steels chart
prehardened steels chart
Using Traditional Roughing
high efficiency milling
tool holding
variable helix
end mill coatings
Using a Long Length of Cut
flute count for tool life
