Tag Archive for: tool fragility
How to Select a Spindle
properly selecting a spindle
CNC Workholding Devices
Fixtures and Jigs
The 4 Fixture Bodies
fixture body
Locators
workholding
Supports
cnc material support
Clamps
workholding
Hydraulic Workholding Systems
Pneumatic clamps
Key Guidelines to Follow
Ensure Proper Tolerancing
Bottom Line
machining advisor pro mobile
diamond tool coatings
Amorphous Diamond Coating
amorphous diamond coating
CVD Diamond Coating
Polycrystalline Diamond (PCD)
Coating Hardness & Thickness
Flute Styles
PCD Diamond end mill
PCD Ball End Mill
CVD Diamond end mill
CVD Ball End Mill
Proper Uses
Cut to the Point
Deflection Can Result In:
  • Subpar surface finish
Tool Deflection Remedies
Minimize Overhang
extended reach tool
Image Source: @NuevaPrecision
Long Flute vs. Long Reach
tool deflection
tool deflection graph
long reach end mill
Long Reach Tool: Variable Helix End Mills for Exotic Alloys – Ball – Long Reach, Stub Flute
long flute tool
core diameter vs neck diameter
Deflection Summarized
Choosing the Right Pecking Cycle Approach
What are Pecking Cycles?
High Performance Drills – Flat Bottom
aluminum pecking cycles
hardened steels chart
prehardened steels chart
Using Traditional Roughing
high efficiency milling
tool holding
variable helix
end mill coatings
Using a Long Length of Cut
flute count for tool life
Shut Up Tool Chatter With Harvey Tool’s Material Specific Tooling
helical reduced neck tool
Ensure a Secure Connection
Work Hardening and When it Should Scare You
Soften Up Work Hardening With Harvey Tool’s Speeds and Feeds
Work Hardening Overview
titanium packed ball bearing
Major Problems
work hardening
How To Avoid Work Hardening
