Tag Archive for: Tool Holder
Key Tool Holding Considerations
Types of Tool Holding
The basic concept of any tool holder is to create a compression force around the cutting tool’s shank that is strong, secure, and rigid. These come in a variety of styles, each with its own spindle interface, taper for clearance, and compression force methods.
Mechanical Spindle Tightening
The most basic way in which spindle compression is generated is by simple mechanical tightening of the holder itself, or a collet within the holder. The downside of this mechanical tightening method of the spindle is its limited number of pressure points. With this style, segments of a collet collapse around the shank, and there is no uniform, concentric force holding the tool around its full circumference.
end mill in tool holder within a cnc machine
Hydraulic Tool Holders
Shrink Fit Tool Holders
Shrink fit tool holders are another high quality tool holding mechanism. This method works by using the thermal properties of the device to expand its opening slightly larger than the shank of the tool. The tool is placed inside the holder, after which the holder is allowed to cool, contracting down close to its original size and creating a tremendous compressive force around the shank. Since the expansion of the bore in the tool holder is minuscule, a tight tolerance is needed on the shank to ensure it can fit every time. Shank diameters with h6 tolerances ensure the tool will always work properly and reliably with a shrink fit holder.
Types of Shank Modifications
Weldon Flats
ToughGRIP Shanks
Haimer Safe-Lock™
haimer safe-lock tool holder up close
While choosing a proper cutter and running it at appropriate running parameters are key factors to a machining operation, so too is the method used. If opting for an improper tool holding method, one can experience tool pull-out, tool runout, and scrapped jobs. Effective tool holding will prevent premature tool failure and allow machinists to feel confident while pushing the tool to its full potential.
Titanium Varieties
Titanium 6AL4V chips with helical hvti end mill
Titanium Concerns
Workholding
Heat Generation
mitsubishi evo camshaft cutters machine from titanium with helical solutions end mill
Galling and Built-Up Edge
Titanium Solutions
Tooling Solutions
machining titanium
Three Harvey tool extended reach tool holders in 3, 5, and 6 inch lengths
Avoid Tool Deflection
Infographic showing result of tool deflection and excess overhang on a part's finish
Infographic showing progressive step drilling procedures and depths of cut with varied length of tools
Achieve Optimal Finish
Inforgraphic showing Deep Cavity Milling and witness marks from multiple step downs
Mill to the Required Depth
Confidently Machine Deeper With Harvey Tool’s Extended Reach Tool Holders
Evacuate Chips Effectively
that must be avoided.
Deep Cavity Milling image showing result of failed chip evacuation when milling
