Tag Archive for: Tool Life
Locking Depths of Cut
Machining Advisor Pro Mobile
Smoother User Experience
Show Us What You #MadeWithMicro100
With the recent addition of the Micro 100 brand to the Harvey Performance Company family, we want to know how you have been utilizing its expansive tooling offering. Has Micro 100’s Micro-Quik system helped you save time and money? Do you have a favorite tool that gets the job done for you every time? Has Micro 100 tooling saved you from a jam? We want to know! Send us a video on Instagram and show us what you #MadeWithMicro100!
How to Participate
Official Contest Rules
Contest Dates:
  • The contest will run between December 5, 2019 to January 17, 2020. Submit as many entries as you’d like! Entries that are submitted before or after the contest period will not be considered for the top prizes (But we’d still like to see them!)
The Important Stuff:
  1. Take a video of your Micro 100 tool in action, clear and visible.
  2. Share your video on social media using #MadeWithMicro100 and tagging @Micro_100.
  3. Detail the story behind the project (tool number(s), operation, running parameters, etc.)
Prizes
The top five entries will be sent Micro 100’s Micro-Quik tool change system with a few of our quick change tools. The top three entries will be offered a spot as a “Featured Customer” on our “In The Loupe” blog!
The Fine Print:
  • Please ensure that you have permission from both your employer and customer to post a video.
  • All entries must be the original work of the person identified in the entry.
  • No purchase necessary to enter or win. A purchase will not increase your chances of winning.
  • On January 28, 2020, the top 5 winners will be announced to the public. The Top 5 selected winners will receive a prize. The odds of being selected depend on the number of entries received. If a potential winner cannot be contacted within five (5) days after the date of first attempt, an alternative winner may be selected.
  • The potential winners will be notified via social media. Each potential winner must complete a release form granting Micro 100 full permission to publish the winner’s submitted video. If a potential winner cannot be contacted, or fails to submit the release form, the potential winner forfeits prize. Potential winners must continue to comply with all terms and conditions of these official contest rules, and winning is contingent upon fulfilling all requirements.
  • Participation in the contest constitutes entrants’ full and unconditional agreement to and acceptance of these official rules and decisions. Winning a prize is contingent upon being compliant with these official rules and fulfilling all other requirements.
  • The Micro 100 Video Contest is open to residents in US and Canada who are at least 18 years old at the time of entry.
Harvey Tool Chamfer Cutters
How to Select a Spindle
properly selecting a spindle
  • A greater finish quality
Micro100 Continues to Set the Standard for Boring Bars, Shop Today.
Geometries
boring bar geometric features
harvey tool slitting saw
  2. Undercutting Applications
  3. Slotting into Material
What to Know About Harvey Tool’s TiB2 Coating
Explore More TiB2 Tooling With Harvey Tool’s End Mills for Aluminum
What is Harvey Tool’s TiB2 Coating?
TiB2 Coating Specification chart
TiB2 is identified in Harvey Tool’s product catalog with a “-C8” following the sku number. It can be found offered in Harvey Tool’s lines of Variable Helix End Mills for Aluminum Alloys and Miniature High Performance Drills for Aluminum Alloys.
When Should a Machinist Use TiB2 Coating?
Chip Evacuation Concerns
Large Production Runs
Extremely Abrasive Materials
Extremely Soft Materials
When Finish Is Vital
tool life
tool life
helical end mill
tool life
CNC Workholding Devices
Fixtures and Jigs
The 4 Fixture Bodies
fixture body
Locators
workholding
Supports
cnc material support
Clamps
workholding
Hydraulic Workholding Systems
Pneumatic clamps
Key Guidelines to Follow
Ensure Proper Tolerancing
Bottom Line
