What is a thread?
Thread Designations
Metric Thread Designations
M12 x 1.75 – 4h – LH
UN Thread Designations
¾ 10 UNC 2A LH
ACME Thread Designations
A 1 025 20-X
How are threads measured?
Thread Milling Considerations
There is no substitute for adequate tooling. To avoid tool failure and machining mishaps, opt for a quality manufacturer for High Performance Drills for your starter holes, as well as for your thread milling solutions. Harvey Tool fully stocks several types of threadmills, including Single Form, Tri-Form, and Multi-Form Thread Milling Cutters. In addition, the 60° Double Angle Shank Cutter can be used for thread milling.
thread milling
Image Courtesy of  @Avantmfg
3. Ensure You’re Comfortable with Your Tool Path
Just looking at a threading tool can be confusing – it is sometimes hard to conceptualize how these tools are able to get the job done. But with proper understanding of call, methods, and best practices, machinists can feel confident when beginning their operation.
Three Key Benefits
Indexing
Increased Feed Rates
Better Part Finish
Opt for a Smoother Operation
Using MAP
A Corner Rounding End Mill is typically used to add a specific radius to a workpiece, or in a finishing operation to remove a sharp edge or burr. Prior to selecting your Corner Rounding End Mill, mull the following considerations over. Choosing the right tool will result in a strong tool with a long usable life, and the desired dimensional qualities on your part. Choosing wrong could result in part inaccuracies and a subpar experience.
Selecting the Right Pilot Diameter
Flared or Unflared
Front or Back
Choosing between a Corner Rounding End Mill and a Back Corner Rounding End Mill boils down to the location on the part you’re machining. A Back Corner Rounding End Mill should be utilized to put a radius on an area of the part facing the opposite direction as the spindle. While the material could be rotated, and a front Corner Rounding End Mill used, this adds to unnecessary time spent and increased cycle times. When using a Back Corner Rounding End Mill, ensure that you have proper clearance for the head diameter, and that the right reach length is used. If there is not enough clearance, the workpiece will need to be adjusted.
Corner Rounding End Mills are often offered in 2, 3, and 4 flute styles.  2 flute Corner Rounding End Mills are normally used for aluminum and non-ferrous materials, although 3 flutes is quickly becoming a more popular choice for these materials, as they are softer than steels so a larger chip can be taken without an impact on tool life. 4 flutes should be chosen when machining steels to extend tool life by spreading out the wear over multiple teeth. 4 flute Corner Rounding End Mills can also be run at higher feeds compared to 2 or 3 flute tools.
The best corner rounding end mill varies from job-to-job. Generally speaking, opting for a tool with the largest pilot diameter possible is your best bet, as it has the most strength and requires less power due to its larger effective cutter diameter. A flared Corner Rounding End Mill is preferred for blending purposes if the workpiece is allowed to have an incomplete radius as this allows more forgiveness and can save on set up time. If not, however, an unflared Corner Rounding End Mill should be utilized. As is often the case, choosing between number of flutes boils down to user preference, largely. Softer materials usually require fewer flutes. As material gets harder, the number of flutes on your tool should increase.
diamond tool coatings
Amorphous Diamond Coating
amorphous diamond coating
CVD Diamond Coating
Polycrystalline Diamond (PCD)
Coating Hardness & Thickness
Flute Styles
PCD Diamond end mill
PCD Ball End Mill
CVD Diamond end mill
CVD Ball End Mill
Proper Uses
Cut to the Point
1. Running It Too Fast or Too Slow
Determining the right speeds and feeds for your tool and operation can be a complicated process, but understanding the ideal speed (RPM) is necessary before you start running your machine. Running a tool too fast can cause suboptimal chip size or even catastrophic tool failure. Conversely, a low RPM can result in deflection, bad finish, or simply decreased metal removal rates. If you are unsure what the ideal RPM for your job is, contact the tool manufacturer.
2. Feeding It Too Little or Too Much
3. Using Traditional Roughing
high efficiency milling
4. Using Improper Tool Holding
tool holding
5. Not Using Variable Helix/Pitch Geometry
variable helix
6. Choosing the Wrong Coating
end mill coatings
7. Using a Long Length of Cut
optimal length of cut
8. Choosing the Wrong Flute Count
flute count
2. Ensure a Secure Connection
tool chatter
decrease tool chatter
Work Hardening and When It Should Scare You
Work Hardening Overview
titanium
Major Problems
work hardening
How To Avoid Work Hardening
Koenig Knives – Featured Customer
Koenig Knives is a fast-growing, Idaho-based knife manufacturer, recognized by many as one of the premier knife-making companies in the market today. Bill Koenig started the company back in 2013, using his off-days  in between his long shifts working the oil fields in North Dakota to build the business. After 3 years of exploring the craft, building a presence in the market, and saving money, Koenig was able to lease a work space, buy his first Haas machine, and start manufacturing his knives right here in America. The Koenig Knives team has now expanded to include four more employees: Krista, the Director of Operations, Cameron, the Lead Machinist, Doug in Assembly, and Todd, who works on finishing. Koenig Knives is quickly becoming known for their focus on quality, innovation, and consistency, backing all of their knives with a lifetime warranty.
We talked with both Bill and Cameron for this latest Featured Customer profile, exploring the world of CNC knifemaking, how they use High Efficiency Milling (HEM) to improve their machining efficiency, and the effect that the machining community on social media has had on their business.
koenig knives
Tell us about your business and how you got started.
Bill: Koenig Knives was started in 2013. I have always been passionate about knives, starting when I was in the Boy Scouts as a young boy. This passion turned to obsession and I went from a collector/enthusiast to a knife manufacturer in December of 2013 when we released our first batch of knives.
Originally we used an off-site manufacturer, who we worked closely with from 2013 until mid-2016. We continued to grow rapidly, and that is when I made the decision to start handling all manufacturing ourselves. We took delivery of our first machine, a Haas VF2SS, at the end of 2016. The rest is history.
Cameron: I started as a CNC operator at an assault rifle manufacturer. After seeing raw material being machined into a beautiful, functioning gun, I decided to make machining my career and I have never looked back.
Cameron: We currently have two Haas VF2SS machines and an Okamoto.
Which materials do you work with in your shop?
Cameron: We work with wide range of materials, including Grade 5 Titanium, Timascus, Damascus, Carbon Fiber, Micarta, Tool Steel , 6061 Aluminum , CTS-XHP, CTS-204P, and 416 Stainless Steel.
helical chamfer mill
What sets Koenig Knives apart from the competition?
Bill: We are often asked what category we would place ourselves in, whether it be production, custom etc. I always hesitate when answering because I can’t think of a way to categorize Koenig Knives besides “high end production with custom offerings.” We have a high end production line, but we also offer the ability to order your own customized version of one of our knives. This is something that is not too common in the industry. Quality, customer service and innovation are our main goals as a company, and we feel we have done a great job hitting on all three.
What is the most challenging part of the knife-making machining process?
Cameron: I think what makes the machining process unique with our product is the fact that we use some of the most cutting edge steel alloys for our blades. It becomes more challenging because these steel alloys are constantly advancing. Finding the perfect harmony of machining parameters for some of the relatively newer steels can be a challenge at times.
Cameron: When part finishes are extremely crucial and there’s a high quantity of parts needed, having high quality tooling like Helical is essential. Helical tools help us maintain a much higher machining efficiency because of the outstanding tool life, while also achieving more aggressive run times. In addition, we are able to consistently keep high tolerances, resulting in a better final product.
koenig knives
Cameron: I love everything about this career, except cleaning the coolant tank. I could do without that…
Koenig Knives has a great Instagram following. Tell us more about how the machinist social media community has helped grow your business.
Cameron: The machinist social media community has helped us connect with various knife makers all over the world. We learn from each other by sharing techniques and helpful tips, and we inspire each other by sharing our creations online. The machinist community on Instagram has been great – we would recommend any business, even the smallest job shops, to take a look at starting their own accounts.
Why is manufacturing your products in America important to you?
Bill: Buying American has always been very important to me for many reasons. The sense of supporting fellow American workers was instilled in me at a young age.  When I started Koenig Knives, I wanted to make sure everything from the screws to the boxes was made in the US.
koenig knives
Tell us about your favorite project that Helical helped to create.
Cameron: Machining the Arius blades (pictured above) has been my favorite on-going project. Once we switched to all Helical tools, it drastically improved our run times and blade finish, and created an incredible final product.
Have you used High Efficiency Milling techniques in your shop?
Cameron: Absolutely! We couldn’t do without HEM!
What advice do you have for other machinists who want to try High Efficiency Milling?
Cameron: Machining Advisor Pro is an absolute game changer when it comes to HEM, as well as for general machining solutions. The technical milling strategies and information that Helical makes available give machinists everything they need to be successful. When a machinist has a full understanding of what is taking place and what is needed to efficiently and correctly cut material, the sky is the limit.
Cameron: With machining technology advancing at the amazing rate that it is, there is no better time to become a machinist. It is a trade that is constantly improving, and offers so many opportunities for young people.
koenig knives
Photos courtesy of Koenig Knives.
Why Flute Count Matters
Tool Geometry Basics
flute count core
Material Considerations
flute count
flute count
