Helical Solutions High Feed End Mill
Using Traditional Roughing
high efficiency milling
tool holding
variable helix
end mill coatings
Using a Long Length of Cut
flute count for tool life
Work Hardening and When it Should Scare You
Work Hardening Overview
titanium packed ball bearing
Major Problems
work hardening
How To Avoid Work Hardening
conventional milling
Climb Milling (Figure 3)
climb milling
Cutting With Dovetails
Avoiding Tool Failure
dovetail cutters
nondrop-hole dovetail cutters
dovetail cutters with different neck diameters
microdovetailing with dovetail cutter
5. Failing to Climb Mill.
6. Improper Chip Flushing.
7. Giving the Job Away.
Part Finish Reference Guide
Common Finishing Problems
  • Burrs
  • Scallop marks
  • Chatter Marks
Factors That Influence Part Finish
  • Specific material and hardness
  • Cutting tool speeds & feeds
  • Tool design and deployment
  • Tool projection and deflection
  • Tool-to-workpiece orientation
  • Rigidity of workholding
  • Coolant and lubricity
  • Final-pass depth of cut
Finishing Problem Solutions
  • Tools with high helix angles and flute counts work best for finishing operations. Softer materials show great results with higher helices, while harder materials can benefit greatly from increased flute counts.
  • Increase your RPM and lower your IPT (Figure 2).
  • Ensure that tool runout is extremely minimal.
  • Use precision tool holders that are in good condition, are undamaged, and run true.
  • Opt for a climb milling machining method.
  • Use tooling with Variable Pitch geometry to help reduce chatter.
  • A proper radial depth of cut (RDOC) should be used. For finishing operations, the RDOC should be between 2 and 5 percent of the tool’s Cutter Diameter.
  • For long reach walls, use reduced neck tooling which help to minimize deflection (Figure 3).
  • Extreme contact finishing (3x cutter diameter), may require a 50% feed rate reduction.
part finish guide
length of cut
Common Surface Finish Nomenclature
Ra = Roughness average
Rq = RMS (Root Mean Square) = Ra x 1.1
Rz = Ra x 3.1
part finish guide
How to Combat Chip Thinning
Defining Chip Thinning
Chip Thickness
How Chip Thinning Occurs
radial chip thinning
IPT chip thinning formula
Lasting Benefits
