Tag Archive for: v-groove milling
6 Uses of Double Angle Shank Cutters
June 20, 2017/1 Comment/in CNC Machining, Machining 101, Machining Techniques, Milling, Specialty Tools, Tool Geometry, Tool Selection/by Harvey Performance Company
Thread Milling
thread milling
Chamfering
chamfering with Double Angle Shank Cutter
Back Chamfering
back chamfering
Machining V-Grooves
machining v-grooves
Deburring
deburring with Double Angle Shank Cutter
Countersinking
Countersinking a part  is done so a screw, nail, or bolt is able to sit flush with the part surface. Using specialty profile tooling can help enlarge the rim of a drilled hole and bevel the sides for a screw to sit accurately. A Double Angle Shank Cutter can also perform this operation by using the bottom portion of its cutting face.
Double Angle Shank Cutter for countersinking
https://www.harveyperformance.com/wp-content/uploads/2017/06/Feature-Image-6-Uses-DASC.jpg 300 800 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-06-20 10:25:282024-11-07 13:59:176 Uses of Double Angle Shank Cutters
