Tag Archive for: variable helix
February 5, 2020/0 Comments/in Machining Techniques, Tech Tips, Tool Geometry, Tool Selection/by Harvey Performance Company
Helix Angles Rule of Thumb
Slow Helix Tool <40°
Benefits
Drawbacks
High Helix Tool >40°
Benefits
Drawbacks
https://www.harveyperformance.com/wp-content/uploads/2020/02/Feature-Image-High-and-Low-Helix-Angles-IMG.jpg 600 1599 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2020-02-05 16:07:562021-11-22 11:24:27Benefits & Drawbacks of High and Low Helix Angles
Machining Precious Metals
July 1, 2019/10 Comments/in How-To's, Machining Techniques, Material Specific/by Robert Keever
About the Elements
  1. Ruthenium (Ru)
  2. Rhodium (Rh)
  3. Palladium (Pd)
  4. Silver (Ag)
  5. Osmium (Os)
  6. Iridium (Ir)
  7. Platinum (Pt)
  8. Gold (Au)
periodic table with a box around the 8 precious metals
material properties of precious metals in relation to 6061 and 4140
thermal conductivity of silver, gold, copper, and aluminum
pgm material properties
Tools for Precious Metals
variable helix square aluminum end mill from harvey tool
harvey tool pcd diamond square end mill
Speeds and Feeds charts:
speeds and feeds chart for precious metals
speeds and feeds chart for precious metals with a pcd end mill
https://www.harveyperformance.com/wp-content/uploads/2020/07/Machining-Precious-Metals.jpg 600 1599 Robert Keever http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Robert Keever2019-07-01 12:58:512023-10-24 10:50:51Machining Precious Metals
June 19, 2018/17 Comments/in CNC Machining, Helical Solutions, Material Specific, Tech Tips, Trending Now/by Harvey Performance Company
stainless steel machining
Traditional Roughing
The axial engagement of a tool in a slotting operation should be suitable for the specific tool employed, as depicted in Figure 3. Employing an unsuitable method may result in tool deflection, potential damage, and compromised part quality. Chip evacuation is going to be key for slotting in stainless steel. For this reason, 4 flute tools are the best choice because the lower flute count allows for more efficient chip evacuation. Tools with chipbreaker geometry also make for effective slotting in stainless steel, as the smaller chips are easier to evacuate from the cut.
High Efficiency Milling
High Efficiency Milling (HEM) can be a very effective machining technique in stainless steels if the correct tools are selected. Chipbreaker roughers would make an excellent choice, in either 5 or 7 flute styles, while standard 5-7 flute, variable pitch end mills can also perform well in HEM toolpaths.
HEV-5
Machining Advisor Pro
machining advisor pro ad
https://www.harveyperformance.com/wp-content/uploads/2018/06/Feature-Image-Slaying-Stainless-Steel-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-06-19 15:30:022023-12-15 15:25:56Slaying Stainless Steel: Machining Guide
February 7, 2018/8 Comments/in CNC Machining, Quick Tips, Tech Tips, Trending Now, Troubleshooting Tips/by Harvey Performance Company
Using Traditional Roughing
Using a Long Length of Cut
https://www.harveyperformance.com/wp-content/uploads/2018/02/Featured-Image-Killing-End-Mill-IMG.jpg 393 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-02-07 09:08:092023-10-12 09:59:088 Ways You’re Killing Your End Mill
The Anatomy of an End Mill
December 10, 2017/13 Comments/in CNC Machining, Machining 101, Milling, Tool Geometry, Tool Selection/by Harvey Performance Company
Flutes
end mill flute patterns showing valley size
End Mill Profiles
Square Profile End Mills
Ball Profile End Mills
end mill with arrows showcasing cutter diameter and tool face
Shank Diameter
end mill neck comparison and strength with standard and reduced neck
End Mill Helix Angle
showcase of end mill helix angle compared to core
Pitch
infographic of variable pitch end mill face
https://www.harveyperformance.com/wp-content/uploads/2017/12/Featured-Image-End-Mill-Anatomy-IMG.png 418 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-12-10 18:00:202023-10-24 09:31:29The Anatomy of an End Mill
