Tag Archive for: variable pitch
February 13, 2020/4 Comments/in Helical Solutions, Machining 101, Tool Geometry, Tool Information Guides, Tool Selection/by Alexander Bean
helical solutions high feed end mills ad with both solid round and coolant through options
https://www.harveyperformance.com/wp-content/uploads/2020/02/Feature-Image-5-Things-High-Feed-EMs-IMG-Copy-2.jpg 525 1400 Alexander Bean http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Alexander Bean2020-02-13 15:25:162023-10-05 09:01:485 Things to Know About Helical’s High Feed End Mills
May 15, 2018/1 Comment/in CNC Machining, Machining Techniques, Quick Tips, Tech Tips/by Harvey Performance Company
What is a Tight Tolerance?
harvey tool sample table heading showing tool tolerances in D1 and L2 callouts
How Are Tolerances Used?
tooling tolerances of an end mill in dia and LOC
Spotting Drills
spotting drill with dimension callouts
Reamers
miniature reamers with dimension callouts
Be Wary of Deflection
Maintaining tolerances when machining walls is made difficult by tool deflection, or the curvature a tool experiences when a force is applied to it. Where an angle is appearing on a wall due to deflection, opt for a reached tool to allow for less deflection along the tool’s neck. Further, take more axial depths of cut and machine in steps with finishing passes to exert less pressure on the tool. For surface finish tolerances, a long fluted tool may be required to minimize evidence of a tool path left on a part.infographic showcasing cutting forces and tool deflection in machining
Tolerances Summarized
https://www.harveyperformance.com/wp-content/uploads/2018/05/Featured-Image-Tight-Tolerances-IMG.jpg 525 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-05-15 09:22:382023-10-24 10:25:19Tips for Maintaining Tight Tolerances
February 7, 2018/8 Comments/in CNC Machining, Quick Tips, Tech Tips, Trending Now, Troubleshooting Tips/by Harvey Performance Company
Using Traditional Roughing
Using a Long Length of Cut
https://www.harveyperformance.com/wp-content/uploads/2018/02/Featured-Image-Killing-End-Mill-IMG.jpg 393 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2018-02-07 09:08:092023-10-12 09:59:088 Ways You’re Killing Your End Mill
The Anatomy of an End Mill
December 10, 2017/13 Comments/in CNC Machining, Machining 101, Milling, Tool Geometry, Tool Selection/by Harvey Performance Company
Flutes
end mill flute patterns showing valley size
End Mill Profiles
Square Profile End Mills
Ball Profile End Mills
end mill with arrows showcasing cutter diameter and tool face
Shank Diameter
end mill neck comparison and strength with standard and reduced neck
End Mill Helix Angle
showcase of end mill helix angle compared to core
Pitch
infographic of variable pitch end mill face
https://www.harveyperformance.com/wp-content/uploads/2017/12/Featured-Image-End-Mill-Anatomy-IMG.png 418 1400 Harvey Performance Company http://www.harveyperformance.com/wp-content/uploads/2018/08/Logo_HarveyPerformanceCompany-4.png Harvey Performance Company2017-12-10 18:00:202023-10-24 09:31:29The Anatomy of an End Mill
